back4more70 Posted June 6, 2023 Report Posted June 6, 2023 I am looking a dual band (2m / 70cm) antenna, NMO mount, less than 18 inches or so, and under $30-$40 for use with my < 20 watt mobile radio. Does not need to be great for GMRS, but it would be nice to receive decently. Is there such a beast? Quote
marcspaz Posted June 6, 2023 Report Posted June 6, 2023 Man... that is a really tough thing to accomplish... maybe impossible. The Comet SBB-1NMO or SBB-2NMO.... maybe. Still almost $50 each, though. I have a SBB-1 (UHF, not NMO) and they are a compromise on 2m for sure. Quote
kidphc Posted June 6, 2023 Report Posted June 6, 2023 Really kinda tough like Marc says.Mainly because 1/2 wave 2m ⁵/8 over ⁵/8 uhf is going to be about 31".Really, any 1/4 wave 2m , 3/4 70cm antenna will work. ³/4 wave is just terrible from my real world testing but mostly on the transmit side, it received well. So any of the company's that build it will work equally (about) as well. Tram browning larsen etc. They are all going to about 18-20 inches.Sent from my SM-S901U using Tapatalk marcspaz 1 Quote
kidphc Posted June 6, 2023 Report Posted June 6, 2023 Should mention 18-20" 2m antenna is going to be 1/4 wave and 3/4 on 70cm. They will almost always require a groundplane.Sent from my SM-S901U using Tapatalk Quote
back4more70 Posted June 6, 2023 Author Report Posted June 6, 2023 Thank you for the responses. The ground plane will not be an issue, since it would be on my vehicle roof. However, I am moving in about a month, which means I lose my enclosed garage, so I think I will wait since height will no longer be an issue at that point. I'll also decide if I prefer VHF or UHF to make things easier Quote
kidphc Posted June 6, 2023 Report Posted June 6, 2023 Thank you for the responses. The ground plane will not be an issue, since it would be on my vehicle roof. However, I am moving in about a month, which means I lose my enclosed garage, so I think I will wait since height will no longer be an issue at that point. I'll also decide if I prefer VHF or UHF to make things easier If you can run a 1/2, 5/8 over 5/8. You can get both bands nicely. 31" sounds like a lot but if it is a flexible type then it won't matter.Can't tell you how much abuse my larsen 2/70b took when it was on the roof of my suburban. Most parking garaged by me are 6' to max 7' clearances.Now try to add gmrs into the antenna mix. Slim pickings and most are incredibly stiff to get the coverage from 2m-70cm-gmrs. They end up being chunky inflexible antennas with barely acceptable performance.Nowadays I try to avoid tri-band antennas. They sacrifice too much, especially in performance.Sent from my SM-S901U using Tapatalk Quote
back4more70 Posted June 6, 2023 Author Report Posted June 6, 2023 4 minutes ago, kidphc said: If you can run a 1/2, 5/8 over 5/8. You can get both bands nicely. 31" sounds like a lot but if it is a flexible type then it won't matter. I'm sure I'll end up with something like this. I'm not too concerned about GMRS, mainly because where I am moving (Wyoming) there are barely any GMRS repeaters in the whole state (I think three, and only one is open?). kidphc 1 Quote
BoxCar Posted June 6, 2023 Report Posted June 6, 2023 Try this one: Super-Elastic Signal Stalk — Signal Stuff TwistedSquirrell88 and wayoverthere 2 Quote
tweiss3 Posted June 6, 2023 Report Posted June 6, 2023 36 minutes ago, kidphc said: If you can run a 1/2, 5/8 over 5/8. You can get both bands nicely. 31" sounds like a lot but if it is a flexible type then it won't matter. Can't tell you how much abuse my larsen 2/70b took when it was on the roof of my suburban. Most parking garaged by me are 6' to max 7' clearances. Now try to add gmrs into the antenna mix. Slim pickings and most are incredibly stiff to get the coverage from 2m-70cm-gmrs. They end up being chunky inflexible antennas with barely acceptable performance. Nowadays I try to avoid tri-band antennas. They sacrifice too much, especially in performance. Sent from my SM-S901U using Tapatalk Agreed. My truck is 6'5" to the roof, add the 2/70B spring, and I'm not concerned about the 7'2" garage heights I am stuck with. Sure, it hits, but still looks brand new. Quote
kidphc Posted June 6, 2023 Report Posted June 6, 2023 Try this one: Super-Elastic Signal Stalk — Signal StuffUnfortunately ³/4 wave on 70cm. My testing showed.. meh.Going to buy another to mount as 1/4 vhf, cut down to fit a ⁵/8 gmrs coil. I need the flexibility. Plus a lot cheaper then 2x sti flexi.Sent from my SM-S901U using Tapatalk Quote
marcspaz Posted June 6, 2023 Report Posted June 6, 2023 2 hours ago, kidphc said: If you can run a 1/2, 5/8 over 5/8. You can get both bands nicely. 31" sounds like a lot but if it is a flexible type then it won't matter. Looking for a low price point stopped me from recommending that style of antenna. My personal vehicle has a Diamond NR770HB, with that design spec. kidphc 1 Quote
kidphc Posted June 6, 2023 Report Posted June 6, 2023 Looking for a low price point stopped me from recommending that style of antenna. My personal vehicle has a Diamond NR770HB, with that design spec.It is rough... since yes it's 2x the cost of a tram/browning of similar design.But built at a different level. So might as well throw it out there, especially with "best" being at the top of the list.He will have to decide his budget. I think the Diamond is a better antenna. But I WANTED survivability, which influenced my choice heavily.Sent from my SM-S901U using Tapatalk marcspaz 1 Quote
back4more70 Posted September 28, 2023 Author Report Posted September 28, 2023 Thanks all. I ended up with a Tram 1181 140mhz-170mhz + 430mhz-470mhz Dual Band Nmo Antenna. Pretty happy so far. AdmiralCochrane 1 Quote
WRPA509 Posted December 23, 2023 Report Posted December 23, 2023 Thanks all. I ended up with a Tram 1181 140mhz-170mhz + 430mhz-470mhz Dual Band Nmo Antenna. Pretty happy so far.I got this antenna about six months ago and have been VERY pleased with its performance. It works as well as much longer dual band antennas. The SWR is good in the ham bands all the way up into the GMRS frequencies. Truly a hidden gem of an antenna.Sent from my SM-S908U using Tapatalk tweiss3 1 Quote
