WRXR374 Posted June 23, 2023 Report Posted June 23, 2023 I'm pretty sure my HOA isn't going to sign off on an antenna. Looking for my options if that's the case. Quote
1 kidphc Posted June 23, 2023 Report Posted June 23, 2023 I'm pretty sure my HOA isn't going to sign off on an antenna. Looking for my options if that's the case.Similar problem with my hoa.For hf I resorted to a bird feeder with a "perching line". The other hf antenna, I will be putting up a 1/4 hf antenna with a flag on top. They allow flag poles up to 25 feet.For my gmrs and uhf/vhf antennas. I have resorted to in the attic. Which presents other problems. Plus, they don't work fantastic. But any antenna is better then non. Though about putting up a vertical mobile antenna, with a base ground plane made for mobile antennas on the eveaes of the house.My hoa doest allow tv antennas. Although that is in violation of the FCC OTA rules. They also only allow small satellite dishes under 16".There are ways around the rules. Most are not optimal. I wish I had trees on my lot, because, you can hide verticals reasonably well in a tree with green paint.Sent from my SM-S901U using Tapatalk Quote
1 kidphc Posted June 23, 2023 Report Posted June 23, 2023 I don't believe that an HOA can legally prohibit you from installing an antenna. Maybe start here: https://www.fcc.gov/consumers/guides/installing-consumer-owned-antennas-and-satellite-dishesThat only applies to tv antennas. They do and can restrict you from putting radio antennas and towers. Sent from my SM-S901U using Tapatalk Quote
1 SteveShannon Posted June 23, 2023 Report Posted June 23, 2023 16 minutes ago, WRXR374 said: I'd love to see a statute or case cited. I've always heard that was only for digital TV antennas. The rule for TV antennas is part of OTARD, which is an acronym for "Over The Air Reception Devices". It's described here: https://www.fcc.gov/consumers/guides/installing-consumer-owned-antennas-and-satellite-dishes#:~:text=The FCC requires fixed wireless,be professionally installed are permissible. But this line describes how it affects two way radio usage: "Antennas used for AM/FM radio, amateur ("ham") radio, CB radio, or digital audio radio services are not covered by the rule." That doesn't mean that some other rule doesn't do what Marc's friend needed, possibly even a state rule, but it's not this one. There was a petition a couple decades ago arguing "reasonable allowances" that was denied: https://www.fcc.gov/wireless/bureau-divisions/mobility-division/amateur-radio-service/prb-1-1999 It was review again and denied again in this decision: https://www.fcc.gov/wireless/bureau-divisions/mobility-division/amateur-radio-service/prb-1-2001 However, there is this rule (rule b) regarding amateur radio and state or local authorities (does that include HOAs? I would guess not): § 97.15 Station antenna structures. (a) Owners of certain antenna structures more than 60.96 meters (200 feet) above ground level at the site or located near or at a public use airport must notify the Federal Aviation Administration and register with the Commission as required by part 17 of this chapter. (b) Except as otherwise provided herein, a station antenna structure may be erected at heights and dimensions sufficient to accommodate amateur service communications. (State and local regulation of a station antenna structure must not preclude amateur service communications. Rather, it must reasonably accommodate such communications and must constitute the minimum practicable regulation to accomplish the state or local authority's legitimate purpose. See PRB–1, 101 FCC 2d 952 (1985) for details.) (c) Antennas used to transmit in the 2200 m and 630 m bands must not exceed 60 meters in height above ground level. Quote
0 back4more70 Posted June 23, 2023 Report Posted June 23, 2023 14 minutes ago, WRXR374 said: I'm pretty sure my HOA isn't going to sign off on an antenna. Looking for my options if that's the case. I don't believe that an HOA can legally prohibit you from installing an antenna. Maybe start here: https://www.fcc.gov/consumers/guides/installing-consumer-owned-antennas-and-satellite-dishes Quote
0 back4more70 Posted June 23, 2023 Report Posted June 23, 2023 8 minutes ago, kidphc said: That only applies to tv antennas. Ah, so it does. Quote
0 WRXR374 Posted June 23, 2023 Author Report Posted June 23, 2023 36 minutes ago, kidphc said: Similar problem with my hoa. For my gmrs and uhf/vhf antennas. I have resorted to in the attic. Which presents other problems. Plus, they don't work fantastic. But any antenna is better then non. Though about putting up a vertical mobile antenna, with a base ground plane made for mobile antennas on the eveaes of the house. There are ways around the rules. Most are not optimal. I wish I had trees on my lot, because, you can hide verticals reasonably well in a tree with green paint. Problem I see with the eaves is that sounds very unidirectional. I'm interested in any omnidirectional antenna that could go in the attic even if it's sub-optimal. The tree idea is good, but I'd have quite a bit of trenching to do. I'll have to think about that! Quote
0 kidphc Posted June 23, 2023 Report Posted June 23, 2023 Problem I see with the eaves is that sounds very unidirectional. I'm interested in any omnidirectional antenna that could go in the attic even if it's sub-optimal. The tree idea is good, but I'd have quite a bit of trenching to do. I'll have to think about that!The peak of the eaves. I have a giant triangle on the side of the house. Some 40 feet off the ground.Mobile verticals are going to be omni. Very few people use mobile yagis.Sent from my SM-S901U using Tapatalk SteveShannon 1 Quote
0 Blaise Posted June 23, 2023 Report Posted June 23, 2023 1 hour ago, kidphc said: That only applies to tv antennas. They do and can restrict you from putting radio antennas and towers. So if you put your GMRS antenna on your TV antenna... WRYF638 1 Quote
0 kidphc Posted June 23, 2023 Report Posted June 23, 2023 So if you put your GMRS antenna on your TV antenna...For me no. My Hoa will not allow yagi style antennas in the covenant.Sent from my SM-S901U using Tapatalk Quote
0 Lscott Posted June 23, 2023 Report Posted June 23, 2023 I’ve read where people mounted a small tower/mast on a trailer then ran the coax into the house. Technically the antenna is used on a vehicle so it isn’t covered under an HOA. Others put one on their car/SUV/truck and ran the cable inside. Same idea. WRYF638 1 Quote
0 marcspaz Posted June 23, 2023 Report Posted June 23, 2023 2 hours ago, kidphc said: That only applies to tv antennas. They do and can restrict you from putting radio antennas and towers. Sent from my SM-S901U using Tapatalk For what it's worth, there are some federal statutes (I'm out and don't remember at the moment) that state HOAs 'must' make reasonable accommodations for 2-way radio equipment. My friend actually went to court over and the HOA lost. He replaced his small antennas that could only be seen off property through about 2 degrees of opening in the trees, with a giant mast that is 20 feet higher than the house and has several monster antennas for HF, VHF and UHF. WRUU653, kidphc, wayoverthere and 4 others 5 2 Quote
0 kidphc Posted June 23, 2023 Report Posted June 23, 2023 For what it's worth, there are some federal statutes (I'm out and don't remember at the moment) that state HOAs 'must' make reasonable accommodations for 2-way radio equipment. My friend actually went to court over and the HOA lost. He replaced his small antennas that could only be seen off property through about 2 degrees of opening in the trees, with a giant mast that is 20 feet higher than the house and has several monster antennas for HF, VHF and UHF.Funny enough neighborhood is full of "karens". Complaining about leaf blowers and lawn mowers during business hours. That can be heard in their house. Same people where if they were less financially secure with live under a glide path to an airport. Then demand they move the airport that was there 40 years prior to the houses. Lol.I will have to recheck the covenant. But it's pretty restrictive. Not sure about the op.Sent from my SM-S901U using Tapatalk wayoverthere, marcspaz and WRUU653 1 2 Quote
0 back4more70 Posted June 23, 2023 Report Posted June 23, 2023 26 minutes ago, marcspaz said: HOAs 'must' make reasonable accommodations for 2-way radio equipment. I recall this from my general test last week WRUU653, marcspaz and wayoverthere 3 Quote
0 Blaise Posted June 23, 2023 Report Posted June 23, 2023 1 hour ago, kidphc said: For me no. My Hoa will not allow yagi style antennas in the covenant. I feel like intentionally cutting residents off from emergency transmissions and news *has* to be illegal! marcspaz 1 Quote
0 marcspaz Posted June 23, 2023 Report Posted June 23, 2023 21 minutes ago, kidphc said: Then demand they move the airport that was there 40 years prior to the houses. Lol. This is why so many auto race tracks go away. WRUU653 1 Quote
0 Blaise Posted June 23, 2023 Report Posted June 23, 2023 Just now, marcspaz said: This is why so many auto race tracks go away. Hipsters are doing this in NYC right now. Swarm to live in the "cheap" meatpacking district, then sue the hundred-year-old slaughterhouses because of the smell... WRYF638 1 Quote
0 WRQC299 Posted June 23, 2023 Report Posted June 23, 2023 What about converting a directtv dish into a VHF/UHF antenna? Decent project:Sent from my iPhone using Tapatalk Quote
0 WRXR374 Posted June 23, 2023 Author Report Posted June 23, 2023 1 hour ago, marcspaz said: For what it's worth, there are some federal statutes (I'm out and don't remember at the moment) that state HOAs 'must' make reasonable accommodations for 2-way radio equipment. My friend actually went to court over and the HOA lost. He replaced his small antennas that could only be seen off property through about 2 degrees of opening in the trees, with a giant mast that is 20 feet higher than the house and has several monster antennas for HF, VHF and UHF. I'd love to see a statute or case cited. I've always heard that was only for digital TV antennas. Quote
0 axorlov Posted June 23, 2023 Report Posted June 23, 2023 31 minutes ago, WRQC299 said: What about converting a directtv dish into a VHF/UHF antenna? Decent project: Indeed. Here the link to the original article: http://www.w6nbc.com/articles/2016-03QSTdishslot.pdf And it will continue to work with your DirecTV! WRQC299 1 Quote
0 marcspaz Posted June 23, 2023 Report Posted June 23, 2023 56 minutes ago, WRXR374 said: I'd love to see a statute or case cited. I've always heard that was only for digital TV antennas. I know that 47 C.F.R. §97.15 applies to Amateur Radio, and section 207 of the Telecommunications Act of 1996 covers almost everything else. If the HOA bust chops about a CB or GMRS antenna, I would just get my Amateur license and then the antennas would be protected. WRUU653 1 Quote
0 kidphc Posted June 23, 2023 Report Posted June 23, 2023 I know that 47 C.F.R. §97.15 applies to Amateur Radio, and section 207 of the Telecommunications Act of 1996 covers almost everything else. If the HOA bust chops about a CB or GMRS antenna, I would just get my Amateur license and then the antennas would be protected. I thought the amateur antenna is protected if you are a mars operator. Then it is protected by the DOD. Then everyone can go pound sand.Sent from my SM-S901U using Tapatalk marcspaz 1 Quote
0 WRDE563 Posted September 2, 2023 Report Posted September 2, 2023 On 6/23/2023 at 12:58 PM, kidphc said: Similar problem with my hoa. For hf I resorted to a bird feeder with a "perching line". The other hf antenna, I will be putting up a 1/4 hf antenna with a flag on top. They allow flag poles up to 25 feet. For my gmrs and uhf/vhf antennas. I have resorted to in the attic. Which presents other problems. Plus, they don't work fantastic. But any antenna is better then non. Though about putting up a vertical mobile antenna, with a base ground plane made for mobile antennas on the eveaes of the house. My hoa doest allow tv antennas. Although that is in violation of the FCC OTA rules. They also only allow small satellite dishes under 16". There are ways around the rules. Most are not optimal. I wish I had trees on my lot, because, you can hide verticals reasonably well in a tree with green paint. Sent from my SM-S901U using Tapatalk For my hf antenna in HOA I use a gutter. Works great with a 9-1 unun. Here is a facebook group that has a lot of good suggestions. https://www.facebook.com/groups/292984397532571 Quote
0 kidphc Posted September 2, 2023 Report Posted September 2, 2023 For my hf antenna in HOA I use a gutter. Works great with a 9-1 unun. Here is a facebook group that has a lot of good suggestions. https://www.facebook.com/groups/292984397532571 It was in my plans to be a tertiary/fourth antenna... but it is on hold till I can buy multiple coax switches Sent from my SM-S901U using Tapatalk Quote
0 WRYV757 Posted September 28, 2023 Report Posted September 28, 2023 You could do a stealth antenna placed on your roof vent of your home. They make one that does not require a ground and that would be a simple option and have some elevation. https://www.ruggedradios.com/products/uhf-stealth-antenna?variant=39745864433760 Quote
0 SteveShannon Posted September 28, 2023 Report Posted September 28, 2023 On 9/2/2023 at 9:35 AM, kidphc said: It was in my plans to be a tertiary/fourth antenna... but it is on hold till I can buy multiple coax switches Sent from my SM-S901U using Tapatalk A patch panel is cheaper and more flexible than two coax switches connected common to common, if that’s what you’re thinking about doing. Quote
WRXR374
34 answers to this question
