JamesBrox Posted August 21, 2023 Report Posted August 21, 2023 Repeater : RX is Output and TX is Input. Quote
WRUU653 Posted August 21, 2023 Report Posted August 21, 2023 Your radios TX is transmit. Your radios RX is receive. The repeater is going to RX (recieve) your TX and TX (transmit to your receive) RX. Yes it can be complicating. What you need to remember is the TX and RX listed is where you need to program those numbers for your radio. Hope that helps. WRHS218, SteveShannon, wayoverthere and 3 others 6 Quote
Guest Posted August 22, 2023 Report Posted August 22, 2023 2 hours ago, WRUU653 said: Your radios TX is transmit. Your radios RX is receive. The repeater is going to RX (recieve) your TX and TX (transmit to your receive) RX. [...] Simple enough: T is R and R is T ... and sometimes there is no R or was it T or ... really easy Honestly, it is simple once you allow for the shift in perspective - your "right side" is "left" for someone looking at you - same thing Quote
WRUU653 Posted August 22, 2023 Report Posted August 22, 2023 7 minutes ago, WRXD372 said: Simple enough: T is R and R is T ... and sometimes there is no R or was it T or ... really easy Honestly, it is simple once you allow for the shift in perspective - your "right side" is "left" for someone looking at you - same thing It helps if you are ambidextrous. Wasn't that the lyrics to a Beatles song? R is T and T is R and we are all together... Quote
WRQC527 Posted August 22, 2023 Report Posted August 22, 2023 3 hours ago, JamesBrox said: Repeater : RX is Output and TX is Input. Honestly, I think more information is needed. Unless this is a thought experiment, like Schrödinger's Cat. Sab02r and marcspaz 2 Quote
WRQC527 Posted August 22, 2023 Report Posted August 22, 2023 54 minutes ago, WRXE944 said: Is that like a: Dead Cat Bounce? More like a dogma. Quote
WRXW945 Posted August 22, 2023 Report Posted August 22, 2023 9 hours ago, WRQC527 said: Honestly, I think more information is needed. Unless this is a thought experiment, like Schrödinger's Cat. Schrödinger's frequencies. Quote
SteveShannon Posted August 22, 2023 Report Posted August 22, 2023 Quote Is this statement true? Repeater : RX is Output and TX is Input. Maybe, but you weren’t specific enough. The repeater’s Output is its TX but is heard on your radio’s RX. Similarly, your radio’s TX frequency or TX tone, must match the repeater’s Input frequency and tone. Your radio transmits at 467.xxx MHz to the repeater. The repeater transmits at 462.xxx to anyone listening. There are only eight 467/462 repeater frequency pairs. Those frequencies are established by the FCC rules. Nearly all repeaters require a tone, otherwise they would be re-transmitting everything they receive. Your radio transmits a specific tone (CTCSS or PL, they’re two names for the same thing) or digital pattern (DTCSS or DCS or DPL) to open the repeater. That’s called the input or uplink or even receive tone for the repeater. The repeater usually sends a tone or digital pattern along with its transmissions. That’s the output or downlink or transmit tone of the repeater. Those terms are standardized so we can share information. The repeater output tone is for your convenience to lessen interruptions, but it doesn’t provide any kind of security. There are only eight frequencies that repeaters can receive on and only eight that they can transmit on. The frequencies that repeaters transmit on are the same as people use for simplex communications as well. If you are within range of a couple of repeaters that receive and transmit on the same frequencies, using different tones can ensure that your transmissions are being repeated by the correct one and that you’re hearing the correct one. So, for example, repeater Sandhawk and repeater Black Brant both receive on 467.550 MHz and transmit on 462.550 MHz. They’re far enough apart that they don’t usually bother each other, but you happen to live where you receive them both. Sandhawk uses an uplink or input tone of 67.5 Hz. That means that you MUST set your transmit or TX tone to 67.5 Hz or Sandhawk will just disregard your transmissions. Sandhawk uses a different tone, 100 Hz, for its output tone. Using two different tones for TX and RX is referred to as having a “split tone”. It’s usually done by repeater operators who want to protect against unauthorized access to their repeaters. Why? Because it’s easy to scan for the repeater output tone. It’s not as easy to scan for the input tone. The Black Brant repeater uses 103.5 Hz for both input and output. What a lot of people don’t initially understand is that these tones work like filters. If I set my handheld radio to a receive tone of 103.5 Hz my radio will only break squelch when it receives a transmission that incorporates that tone, which would be the Black Brant repeater. If I set my radio receive tone to 100 Hz it will only reproduce transmissions it receives which include a 100 Hz tone. But, if I don’t set a receive tone in my radio, it does no filtering. It literally reproduces everything that has a signal strength sufficient to break squelch. That’s useful, especially when trying to troubleshoot. Don’t fall into the trap of referring to a tone by a number or some other shorthand because not all radios number the codes the same. Always refer to the frequency of the tone, such as 103.5 Hz, or the DCS code. Not all radios include all the tones. Motorola and Midland include the standard tones, but fail to include some of the tones included in the overseas brands. Thus they might not be able to access some repeaters. WRYJ580, WRUU653, WRXB215 and 3 others 6 Quote
WRXB215 Posted August 22, 2023 Report Posted August 22, 2023 @Sshannon Very well said. You should expand that slightly and put it into a PDF. Is there an FAQ area on this forum? WRUU653 1 Quote
SteveShannon Posted August 22, 2023 Report Posted August 22, 2023 12 minutes ago, WRXB215 said: @Sshannon Very well said. You should expand that slightly and put it into a PDF. Is there an FAQ area on this forum? Thank you! I’ll try to expand on it. I haven’t seen an FAQ. Quote
WRUU653 Posted August 22, 2023 Report Posted August 22, 2023 @Sshannon very informative and well said sir. The most detailed answer to the least detailed question. Above and beyond. WRXB215 1 Quote
JamesBrox Posted August 22, 2023 Author Report Posted August 22, 2023 I see. I'm programming via software. So, if I put 141.3(the repeater's output PL) in my radio's input and 423 DPL (the repeater's input PL) in my radio's output...I'm good? Quote
WRHS218 Posted August 22, 2023 Report Posted August 22, 2023 28 minutes ago, JamesBrox said: So, if I put 141.3(the repeater's output PL) in my radio's input and 423 DPL (the repeater's input PL) in my radio's output...I'm good? Correct. JamesBrox and WRUU653 2 Quote
JamesBrox Posted August 22, 2023 Author Report Posted August 22, 2023 17 minutes ago, WRXE944 said: CHIRP? Or proprietary CPS software? I recommend leave out the Receive Tone on your radio to get started. Mistakes can leave you with no reception on a busy repeater Proprietary, I guess. The programming screen has KG-1000G+ on the upper left and a picture of the 1000G+ on the desktop icon. Leave out the RX tone? Then I won't be able to comm on the programmed RPT stations....why would I want to do that? Quote
SteveShannon Posted August 22, 2023 Report Posted August 22, 2023 29 minutes ago, JamesBrox said: Proprietary, I guess. The programming screen has KG-1000G+ on the upper left and a picture of the 1000G+ on the desktop icon. Leave out the RX tone? Then I won't be able to comm on the programmed RPT stations....why would I want to do that? No, if you leave out the receive tone you receive everything. Add the receive tone after making sure you have the transmit tone correct. WRUU653 1 Quote
Guest Posted August 23, 2023 Report Posted August 23, 2023 12 hours ago, WRXB215 said: @Sshannon Very well said. You should expand that slightly and put it into a PDF. Is there an FAQ area on this forum? 12 hours ago, Sshannon said: Thank you! I’ll try to expand on it. I haven’t seen an FAQ. An FAQ section or WIKI would help to answer some basic questions. - You know, those that are "frequently asked" Quote
SteveShannon Posted August 23, 2023 Report Posted August 23, 2023 43 minutes ago, WRXD372 said: An FAQ section or WIKI would help to answer some basic questions. - You know, those that are "frequently asked" I understand what an FAQ is. I said I haven’t seen one, meaning on this site. WRUU653 1 Quote
BoxCar Posted August 23, 2023 Report Posted August 23, 2023 4 minutes ago, Sshannon said: I understand what an FAQ is. I said I haven’t seen one, meaning on this site. Its been suggested several times Quote
SteveShannon Posted August 23, 2023 Report Posted August 23, 2023 3 minutes ago, BoxCar said: Its been suggested several times I think it’s a great idea. We answer the same questions over and over. But it does no good to give them lip service in the forums. People who are willing to compile the questions and answers that already exist on this site should put something together and write to Rich, offering to maintain them. Or even start a new thread called FAQs. kirk5056, WRUU653 and WRXB215 3 Quote
Guest Posted August 23, 2023 Report Posted August 23, 2023 1 hour ago, Sshannon said: I understand what an FAQ is. I said I haven’t seen one, meaning on this site. I did not doubt that you know that - my argument just got circular on accident and there was no way to recover Quote
SteveShannon Posted August 23, 2023 Report Posted August 23, 2023 2 minutes ago, WRXD372 said: I did not doubt that you know that - my argument just got circular on accident and there was no way to recover If anything I have ever posted would help, I have no problem if someone uses it in part or completely. WRUU653 1 Quote
Guest Posted August 23, 2023 Report Posted August 23, 2023 56 minutes ago, Sshannon said: I think it’s a great idea. We answer the same questions over and over. But it does no good to give them lip service in the forums. People who are willing to compile the questions and answers that already exist on this site should put something together and write to Rich, offering to maintain them. Or even start a new thread called FAQs. If you are looking at the members who most often answer on that level - basic knowledge and helpful tips - I would guess that putting together a WIKI or FAQ is no problem. This might take a few weeks or even month, but it would make this forum a high value asset !!! Quote
Guest Posted August 23, 2023 Report Posted August 23, 2023 1 minute ago, Sshannon said: If anything I have ever posted would help, I have no problem if someone uses it in part or completely. I "bet" the answers / articles are all over the forum ... if we could just collate and curate them ... ?!? Quote
SteveShannon Posted August 23, 2023 Report Posted August 23, 2023 2 minutes ago, WRXD372 said: I "bet" the answers / articles are all over the forum ... if we could just collate and curate them ... ?!? They are. Unfortunately, I’m working on two different manuals and NFPA submissions right now so I don’t have the time. Quote
Guest Posted August 23, 2023 Report Posted August 23, 2023 Maybe it's time to get started at the drawing board... What would we need from admin to get this started ?!? - We might need a new category - FAQ or Knowledgebase or WIKI - that board should not be a discussion board buy rather an 'announcement board'/ - Writing and editing privileges for selected / level headed volunteers. - Editing privileges should include going back and editing / collaboration on the posts. - Some collaboration of the contributors to decide on an initial set of topics - ... ... time to weigh in !!! Quote
