CyborgAlienWRYG738 Posted November 9, 2023 Report Posted November 9, 2023 What is a "Stun and Kill Function"?!? Quote
0 SteveShannon Posted November 17, 2023 Report Posted November 17, 2023 It’s not at all unusual for the RF output to deviate from the advertised value. Some may be more and some may be less and it really makes almost no difference in communications whether a radio puts out 4 watts or 5. It’s a classic case of diminishing returns. Plus there’s absolutely nothing that says your wattmeter is correct. As an exercise, jot down the power output for every channel. You’ll see that they differ, possibly greatly. WRXB215 1 Quote
0 WRWE456 Posted November 17, 2023 Report Posted November 17, 2023 Just send it back and ask for a replacement if you think it is defective. SteveShannon 1 Quote
0 CyborgAlienWRYG738 Posted November 17, 2023 Author Report Posted November 17, 2023 3 hours ago, Sshannon said: It’s not at all unusual for the RF output to deviate from the advertised value. Some may be more and some may be less and it really makes almost no difference in communications whether a radio puts out 4 watts or 5. It’s a classic case of diminishing returns. Plus there’s absolutely nothing that says your wattmeter is correct. As an exercise, jot down the power output for every channel. You’ll see that they differ, possibly greatly. The barely, if at all vary. My radio is putting out between 3 and 4.3W not even close to the 5.5 advertised and I've barely had it a month or so. I shouldn't be seeing that much of a diminished return yet. Quote
0 CyborgAlienWRYG738 Posted November 17, 2023 Author Report Posted November 17, 2023 3 hours ago, WRWE456 said: Just send it back and ask for a replacement if you think it is defective. I need to find someone to hook up with locally and see if it's my meter or what first. If I can find someone... Being relatively new to my area and GMRS it's difficult. Quote
0 sjl777 Posted November 18, 2023 Report Posted November 18, 2023 From my limited experience along with web and YouTube searches, the DTMF codes allow a user to access devices using the radio. This can include repeaters, garage doors, and anything else where your radio might be used as a remote with a particular configured device. I have not use for this function and dont want to make my radios open to receiving unwanted codes. The Kill/Stun function is an anti-theft function. Government agencies have this built into their public safety equipment. Depending on how much one spends for a mobile or HT, I can understand how you may want to brick the device if it was stolen. Getting it back would be another issue. I think if you change the default code in CHIRP or CPS software it should limit someone from using a factory code to mess with your radio. SteveShannon and CyborgAlienWRYG738 1 1 Quote
0 CyborgAlienWRYG738 Posted November 18, 2023 Author Report Posted November 18, 2023 1 hour ago, sjl777 said: From my limited experience along with web and YouTube searches, the DTMF codes allow a user to access devices using the radio. This can include repeaters, garage doors, and anything else where your radio might be used as a remote with a particular configured device. I have not use for this function and dont want to make my radios open to receiving unwanted codes. The Kill/Stun function is an anti-theft function. Government agencies have this built into their public safety equipment. Depending on how much one spends for a mobile or HT, I can understand how you may want to brick the device if it was stolen. Getting it back would be another issue. I think if you change the default code in CHIRP or CPS software it should limit someone from using a factory code to mess with your radio. Thanks, I was having a problem locating any information on it, not sure if it's my search engines or a setting on my devices I need to change. They're pretty secure. Quote
0 WRXB215 Posted November 28, 2023 Report Posted November 28, 2023 1 hour ago, Sshannon said: unless you have a reason, disable the ability of your radio to be stunned or killed That's a great suggestion. I can't remember if it was on this forum or somewhere else but there was a guy that just started using his new radio and someone in the neighborhood stunned his radio. Took him a while to get it straightened out if I recall. CyborgAlienWRYG738 1 Quote
0 CyborgAlienWRYG738 Posted November 29, 2023 Author Report Posted November 29, 2023 10 hours ago, WRXB215 said: That's a great suggestion. I can't remember if it was on this forum or somewhere else but there was a guy that just started using his new radio and someone in the neighborhood stunned his radio. Took him a while to get it straightened out if I recall. Now if I can just figure out how... Quote
0 CyborgAlienWRYG738 Posted November 29, 2023 Author Report Posted November 29, 2023 12 hours ago, Sshannon said: It’s always a good idea to go through your passwords from time to time, but that’s not what is needed to prevent someone from stunning or killing your radio. Your radio has an ANI. By default, all radios of that model are programmed with a factory default ANI. In order to stun or kill your radio two things must be true: 1. The stun or kill function must be enabled in your radio. 2. The person sending the stun or kill command must send it along with the ANI that is programmed into your radio. That’s especially easy if you never changed the ANI from the factory default. All someone would have to do is send out the stun or kill command with the factory default ANI. So, you should use Chirp or the factory CPS to change the ANI to be different from the factory default. Also, unless you have a reason, disable the ability of your radio to be stunned or killed. ANI?!? Where would I do this magical disabling?!? I don't know what I'm looking for. Quote
0 PACNWComms Posted November 29, 2023 Report Posted November 29, 2023 Interesting thread I clicked on, only because today I received a call for a lost APX4000 Model 2 on a trunked radio network. I had to explain why I was only going to"Transmit Inhibit" the radio, as then they usually end up at one of our repair shops, when someone notices they receive, change channels, and otherwise appear to function until you try to transmit. Many organizations in commercial radio shy away from stun and kill, and the use of system keys helps keep your radios/programming within your organization. It would be interesting to know if CCR's now have this as well? Some do most everything else as found on commercial radios. SteveShannon and CyborgAlienWRYG738 2 Quote
0 SteveShannon Posted November 29, 2023 Report Posted November 29, 2023 2 hours ago, CyborgAlienWRYG738 said: ANI?!? Where would I do this magical disabling?!? I don't know what I'm looking for. Menus 23 and 24 (in the Parent manual I referenced a few days ago) set the Caller ID and control when your Caller ID is sent, which I suspect is the same as your ANI. The pages (49-51) on remote control that I screenshot and posted back then describe the process of Stunning and Killing, but they refer to a value that I don’t find elsewhere in the manual. They refer to “Controlled Code”. Maybe it’s the ID of the unit that is sending the Stun, Kill, Monitor, or Inspection code. I really don’t know. And on this unit it doesn’t appear there’s a disable function so you’ll definitely want to change the ID. CyborgAlienWRYG738 1 Quote
0 CyborgAlienWRYG738 Posted November 29, 2023 Author Report Posted November 29, 2023 3 hours ago, Sshannon said: Menus 23 and 24 (in the Parent manual I referenced a few days ago) set the Caller ID and control when your Caller ID is sent, which I suspect is the same as your ANI. The pages (49-51) on remote control that I screenshot and posted back then describe the process of Stunning and Killing, but they refer to a value that I don’t find elsewhere in the manual. They refer to “Controlled Code”. Maybe it’s the ID of the unit that is sending the Stun, Kill, Monitor, or Inspection code. I really don’t know. And on this unit it doesn’t appear there’s a disable function so you’ll definitely want to change the ID. I had turned the PTT-ID off and I had changed my ID as well, I'm not sure what the "control code" is, I tried the security codes which were the default security codes/passwords and then changed my security codes/passwords. I did notice a slight increase of output power after a subsequent complete wipe as well, though I don't have the full power I once had. It's noticable when I try to talk to locations from inside my house that I now have to go outside to reach. Quote
0 CyborgAlienWRYG738 Posted November 29, 2023 Author Report Posted November 29, 2023 14 minutes ago, Sshannon said: Once again, Stun and Kill have absolutely nothing to do with reducing your transmission power. Stun disables transmission entirely. Kill disables transmission and reception. Thanks again Steve, I think I've got it now. SteveShannon 1 Quote
-1 CyborgAlienWRYG738 Posted November 28, 2023 Author Report Posted November 28, 2023 On 11/18/2023 at 10:42 AM, sjl777 said: I think if you change the default code in CHIRP or CPS software it should limit someone from using a factory code to mess with your radio. As a n update on this, I have since changed ALL my passwords, I hope this is what you were referring to. Quote
-2 WRUI365 Posted November 28, 2023 Report Posted November 28, 2023 I wonder if you people know that stun and kill function is by digital means, not analog. As in if you are using a DMR, NXDN or P25 unit and someone wants you not on that talk group. There is no analog means of doing that for the reason that in the digital modes your radio is transmitting a unit id number. In analog it doesn't. CyborgAlienWRYG738 1 Quote
CyborgAlienWRYG738
Top Posters For This Question
31
13
7
5
Popular Days
Nov 9
36
Nov 17
10
Nov 29
7
Nov 28
6
CyborgAlienWRYG738 31 posts
SteveShannon 13 posts
WRWE456 7 posts
WRQC527 5 posts
Popular Days
Nov 9 2023
Nov 17 2023
Nov 29 2023
Nov 28 2023
Popular Posts
SteveShannon
Here’s what a Reddit user said: Stun is a setting which will allow the radio to receive but not be controlled or used to transmit. It will listen for the revive command. It's a commercial ra
OffRoaderX
Are you transmitting on the same channel as you were when you were getting 4W? The output varies on most of these radios depending on the frequency.
WRWE456
According to the KG-1000Gplus manual "To reactivate a killed radio send the kill sequence again".
Posted Images
65 answers to this question
