KiloFoxtrot Posted December 11, 2023 Posted December 11, 2023 Looking to upgrade my handheld GMRS antenna. I see Nagoya, Smiley and Signal Stick mentioned a lot. Anyone have recommendations on which of these performs better? I wouldn’t want the Nagoya 771g, too long and impractical for my use. Quote
WRXB215 Posted December 11, 2023 Posted December 11, 2023 Nagoya also makes a NA-701g. Same antenna, just shorter. 5.5". WRUU653 1 Quote
KiloFoxtrot Posted December 11, 2023 Author Posted December 11, 2023 50 minutes ago, WRXB215 said: Nagoya also makes a NA-701g. Same antenna, just shorter. 5.5". Oh. How does this one compare to typical stock antennas, better distance or audio? Quote
WRXB215 Posted December 11, 2023 Posted December 11, 2023 Just about any other antenna is better than the stock antenna. The Nagoya has a good reputation. Abbree are also good and much cheaper but they don't make a 701g yet. The do have a 701 however. Quote
WRWE456 Posted December 11, 2023 Posted December 11, 2023 Which radio are you using would be the first question? Then are you having problems with the stock one? Not all stock antennas suck. Most aftermarket antennas get better range because they are longer but that only matters if the stock one is not reaching where you need it to. Quite often the stock one will work just fine. WRXB215, WRUU653 and WRYZ926 3 Quote
WRZD706 Posted December 11, 2023 Posted December 11, 2023 I have a BTECH 5 watt handheld and the stock antenna, the 701G, and the 771G. For me in my non-scientific testing (my friend staying put on high ground and me moving further and further away and testing each antenna), the stock and 701G are very similar but the 771G is better by abut ~30%. Of course, that will vary from user to user, but I use my stock or 701G when within 1.5 miles or so, and my 771G for greater simplex or repeaters. WRUU653, WRXB215 and SteveShannon 3 Quote
WRXB215 Posted December 11, 2023 Posted December 11, 2023 3 hours ago, WRWE456 said: Not all stock antennas suck. That's true. I tend to not think about those since I can only afford cheep radios with stock antennas that suck. SteveShannon and WRUU653 2 Quote
WRYZ926 Posted December 11, 2023 Posted December 11, 2023 4 hours ago, WRWE456 said: Which radio are you using would be the first question? Then are you having problems with the stock one? Not all stock antennas suck. Most aftermarket antennas get better range because they are longer but that only matters if the stock one is not reaching where you need it to. Quite often the stock one will work just fine. I agree. And knowing what radio he has will help. I find the Nagoya 771G works better than stock on my Baofeng radios but I didn't notice much difference when trying the 771G on my Wouxun 935G. The stock 935G antenna is a good one. WRUU653 and StogieVol 2 Quote
WRWE456 Posted December 11, 2023 Posted December 11, 2023 40 minutes ago, WRYZ926 said: I agree. And knowing what radio he has will help. I find the Nagoya 771G works better than stock on my Baofeng radios but I didn't notice much difference when trying the 771G on my Wouxun 935G. The stock 935G antenna is a good one. Perfect example. Quote
StogieVol Posted December 12, 2023 Posted December 12, 2023 @WRWE456 @WRYZ926 I was about to ask that question. If any antenna would make the 935g plus get out any better. Thanks WRYZ926 1 Quote
WRYZ926 Posted December 12, 2023 Posted December 12, 2023 47 minutes ago, StogieVol said: @WRWE456 @WRYZ926 I was about to ask that question. If any antenna would make the 935g plus get out any better. Thanks I have not found any other antennas that work better than the stock 935G antenna. StogieVol 1 Quote
