I am having an issue with my TD-H3 radios. I read the manual, search the web with 3 different search engines, and no luck finding anything useful. All 3 of them behave the same way, so I think I am doing something wrong. Since they are getting popular for GMRS, I figured I would see if anyone else here had the same problem and resolved it.
So, short version, everything works if programmed in Chirp. However, I can't change any offset or tone values if I attempt to set them through the FPP.
In VFO mode I cannot configure the CTCSS, DCS, Offset Direction nor Offset values; menu items 10, 11, 12, 13, 23 and 24. When I attempt to set a value, and press the BT/menu button to confirm, the values set back to off/none/0.000/etc.
So, here is the odd part... If I use Chirp-Next to program the radio, it programs perfectly and everything works fine. In existing memory channels that have been programmed with Chirp, I can successfully change any of those values. BUT... if I manually save a new memory channel via FPP, I still can't manipulate any of the aforementioned menu items in the new saved item.
I have reset the radio several times. This problem exists regardless of if the radio is in Ham, GMRS or Normal mode. I tried enabling and disabling a bunch of other features to see if there is an impact, but nothing seems to matter. When I am planning ahead, this isn't really an issue, but if I am out and about or have an emergency and need to program a repeater into the radio, it's just not possible with the FPP.
marcspaz
So, any ideas about what I am doing wrong?
Thanks,
Spaz
18 answers to this question
