Guest graeme soens Posted May 15, 2024 Report Posted May 15, 2024 I've just got a boafeng p15uv and put a password into it but I've forgotten it is there a way I can bypass the password or reset the radio Quote
nokones Posted May 15, 2024 Report Posted May 15, 2024 Why would anyone would want to password a cheap Chinese $18 POS for? Raybestos and dosw 2 Quote
OffRoaderX Posted May 15, 2024 Report Posted May 15, 2024 My guess is that you will be making a call to Baofeng support.. But maybe someone has a better idea. PRO TIP: When setting a password..for anything.. write it down, or save it in your Password Manager. dosw 1 Quote
Guest Posted May 15, 2024 Report Posted May 15, 2024 7 minutes ago, nokones said: Why would anyone would want to password a cheap Chinese $18 POS for? Whoa whoa whoa I saw it on Amazon for $27! It’s probably because he has a frequency stored in it to talk to aliens and he didn’t want any one else to get a hold of it and talk to them also. Either using the exact same password every time or writing it down would have helped. It can’t be that big of a deal to have to lock down your radio. Can it? Quote
dosw Posted May 15, 2024 Report Posted May 15, 2024 But the question we're all really wanting answered is what the subject line "Mr" means. PRadio, OffRoaderX, WRXB215 and 1 other 3 1 Quote
SteveShannon Posted May 15, 2024 Report Posted May 15, 2024 2 hours ago, Guest graeme soens said: I've just got a boafeng p15uv and put a password into it but I've forgotten it is there a way I can bypass the password or reset the radio The manual doesn’t mention a password. Are you sure you entered a password? Resetting the radio is menu 40. https://fccid.io/2AJGM-P15UV/User-Manual/User-Manual-5201622 Quote
WRXR255 Posted May 15, 2024 Report Posted May 15, 2024 1 hour ago, Sshannon said: The manual doesn’t mention a password. Are you sure you entered a password? Resetting the radio is menu 40. Would you not have to get past the password before you could choose menu 40? Quote
SteveShannon Posted May 15, 2024 Report Posted May 15, 2024 6 minutes ago, WRXR255 said: Would you not have to get past the password before you could choose menu 40? If there’s truly a password. As I said, the manual doesn’t mention one. Perhaps he simply locked the keyboard. Or maybe the manual is poor. WRXB215 1 Quote
WRXR255 Posted May 15, 2024 Report Posted May 15, 2024 (edited) 13 minutes ago, Sshannon said: If there’s truly a password. As I said, the manual doesn’t mention one. Perhaps he simply locked the keyboard. Or maybe the manual is poor. My Assault Radio - Beofeng AR-5RM - has that feature but like was said, why? And the manual only tells you how to turn it on or off... Im afraid to test it, as if there happens to be a default password, the manual says nothing about, oops! EDIT I really want to test it though, have it locked and I am curious if you can still pull a download/upload from CHIRP. Edited May 15, 2024 by WRXR255 Addl. comment SteveShannon 1 Quote
nokones Posted May 15, 2024 Report Posted May 15, 2024 2 hours ago, WRXP381 said: Whoa whoa whoa I saw it on Amazon for $27! It’s probably because he has a frequency stored in it to talk to aliens and he didn’t want any one else to get a hold of it and talk to them also. Either using the exact same password every time or writing it down would have helped. It can’t be that big of a deal to have to lock down your radio. Can it? $27? Wow! That price gotta be just for Californians to help with the State's budget deficit. SteveShannon 1 Quote
SteveShannon Posted May 15, 2024 Report Posted May 15, 2024 $18 or $27 is still too much to pay for a paperweight. Let’s try to help the guy figure out the problem. WRWE456 and WRXB215 2 Quote
WRWE456 Posted May 15, 2024 Report Posted May 15, 2024 We need more info. I don't have any radios that use passwords. Could it be the programing software that uses a password not the radio? SteveShannon 1 Quote
nokones Posted May 16, 2024 Report Posted May 16, 2024 I would check and see if the seller or manufacturer has some type of customer support and call them and see if they have the ability of remote control of his computer and maybe they can do a factory reset back to default to the radio over the internet. SteveShannon 1 Quote
Hoppyjr Posted May 16, 2024 Report Posted May 16, 2024 Here is a link to a Reddit post about that radio. https://www.reddit.com/r/Baofeng/s/SxrCkiGYV1I’d first Google and try the factory reset settings for other Baofeng radios, to see if any of that works. Another option is to try programming software like RT Systems, to see if you can get in that way. It seems to be one of the less common radios, so likely not as much info out there. SteveShannon 1 Quote
SteveShannon Posted May 16, 2024 Report Posted May 16, 2024 I found this on Reddit. A person accidentally enabled the password without actually setting it. It turned out that the default was 000000: WRXB215 and Raybestos 2 Quote
back4more70 Posted May 16, 2024 Report Posted May 16, 2024 3 hours ago, WRXR255 said: My Assault Radio - Beofeng AR-5RM Quote
