back4more70 Posted June 29, 2024 Report Posted June 29, 2024 Here is my RA25 into a dummy load. I didn't chart the SWR but it was very acceptable across all bands. Quote
AdmiralCochrane Posted June 29, 2024 Report Posted June 29, 2024 8 hours ago, back4more70 said: Here is my RA25 into a dummy load. I didn't chart the SWR but it was very acceptable across all bands. I would hope so. dosw and SteveShannon 2 Quote
WRYS709 Posted June 30, 2024 Report Posted June 30, 2024 On 6/27/2024 at 9:24 PM, WRYC373 said: The AT-779UV is the same as the DB20G but with a part97 cert instead of the Part 95. Both come certified for GMRS. On 6/28/2024 at 7:52 AM, amaff said: I keep seeing people report this but I keep checking mine and it doesn't do that. Are you always using it on High output? Most of the time I run at low or at most medium (because 99% of the time it's for simplex, car-to-car type stuff) unless I'm struggling to talk to someone, and even during extended conversations it only ever just gets warm to the touch. If it got *hot* it'd probably be a problem for where I have it mounted, but I keep checking it waiting for it to happen and it just hasn't. Yes, if you primarily use Medium and Low Power, yours will be OK as mounted. High power will a high transmit duty cycle and you are in trouble. Quote
Skunkworks Posted July 3, 2024 Report Posted July 3, 2024 I have 4 of the Radioddity DB-25G's. I really like them a lot and they have cig-lighter plugs. This, the ability to monitor 4 channels, and listen to HAM vhf/uhf are the reasons they are packed in a Apache box in each of the family cars along with a Nagoya UT-72G mag-mount. They are great radios and I have used one as a base at times as well. Plus, they are only 89.99 on Amazon right now with coupons. https://www.amazon.com/gp/product/B09C7JBBVY/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Quote
ClassicCarGuy Posted August 4, 2024 Report Posted August 4, 2024 On 6/28/2024 at 7:30 AM, WRXB215 said: I use the AT-778UV daily. It gets hot but apparently not too hot for the radio. If I ever get time, I'm going to pull the fan out of an old laptop and mount it on the heatsink just for good measure. Thread resurrection.. Does anyone know or have a bulletin in adding a cooling fan in this radio? Anytone AT-778UV Thanks, Quote
WRYS709 Posted August 6, 2024 Report Posted August 6, 2024 While I have the AT-779UV, which is a completely different radio than their AT-778UV, my understanding is that neither radio has an official fan "add-on" available through Anytone. My experience with the 779UV for many years of high duty cycle "yakking" is that, yes, it is very hot to the touch, but their has been no denigration in its service and capabilities. Quote
SteveShannon Posted August 6, 2024 Report Posted August 6, 2024 Leave the power on Medium instead of High. I led a Net last night with me talking at least 50-60% of the time and it was just warm. AdmiralCochrane, WRUU653 and amaff 3 Quote
amaff Posted August 6, 2024 Report Posted August 6, 2024 2 minutes ago, SteveShannon said: Leave the power on Medium instead of High. I led a Net last night with me talking at least 50-60% of the time and it was just warm. 100% this. Unless you're having trouble getting through (and even then, the few extra watts maybe will / maybe won't make the difference), there's no need to have it on maximum chooch. WRUU653, SteveShannon and AdmiralCochrane 3 Quote
AmanGMRS Posted August 31, 2024 Report Posted August 31, 2024 Doesn't ship with cigarette lighter, will have to connect your own (seems more complicated than it is, once you do it you'll realize it wasn't that bad), but this is a good performing radio and great antenna. Lacks programming features if you run a lot of different repeaters, and their privacy tone code set up is odd (they use their own numbering system, you need the chart to figure out what is what). But if you're only running one local repeater per channel and don't change often, the quality and performance are tough to beat. You can also get their ghost antenna which is only about 6 inches tall or so and still does well, letting you in and out of garage if you have one. Just look for discount codes, it's a little pricey. **edit to add, this radio is easily hidden out of sight when in sketchy area. Also look into Lido brand mic mount that clips onto your vent. Nothing permanent needed for this radio, antenna, mic hanger set up. Everything can be added and removed in a minute or two. https://midlandusa.com/collections/micromobile/products/mxt275whip-extended-range-bundle Quote
TNFrank Posted September 29, 2024 Report Posted September 29, 2024 On 6/26/2024 at 7:15 AM, jwilkers said: The BTECH GMRS 20-V2 is a 20 watt radio with a cig lighter plug. I second this choice mainly because that's what I have in the truck. All the controls are on the hand-set so you can mount the base where ever you want it. Only draw back is that it doesn't go below 5 Watts so channels 8-14 can't be used to TX but all the other GMRS channels are good. I also have 4 of our local DPS channels programed to scan while I'm driving to keep track of what's going on on the roads. Tests show 15-16 watt output so it's not a true 20 watt but close enough and the price isn't too bad. You also get the BTech quality and customer service which is a plus. Quote
WRYS709 Posted September 29, 2024 Report Posted September 29, 2024 14 minutes ago, WSAA635 said: Only draw back is that it doesn't go below 5 Watts so channels 8-14 can't be used to TX but all the other GMRS channels are good. I also have 4 of our local DPS channels programed to scan while I'm driving to keep track of what's going on on the roads. No mobile is allowed to transmit on Channels 8-14; HTs @ 0.5 watts only! WRUU653 and dosw 1 1 Quote
WRYZ926 Posted September 29, 2024 Report Posted September 29, 2024 8 hours ago, WRYS709 said: No mobile is allowed to legally transmit on Channels 8-14; HTs @ 0.5 watts only! I fixed it for you. Yes according to the FCC, channels 8-14 are restricted to hand held radios only. Most mobile radios will only go down to 5 watts. This can cause interference on the repeater channels if one uses 5 watts or more on channels 8-14. That being said. Some 20 watt mobile radios can definitely transmit on those channels if set to low power and narrow band. It is not suggested to do so for the reason stated above. TNFrank 1 Quote
