Guest John, Posted June 29, 2024 Report Posted June 29, 2024 I have this Repeater, it has perfect SWR, pushing Full 50 watts. But I can not receive anyone over a mile away. What is the best way to configure the repeater so that I can receive? Quote
OffRoaderX Posted June 29, 2024 Report Posted June 29, 2024 There is nothing really to "configure".. Assuming you have a well placed and well-tuned antenna with no obstructions between you and the other radio a mile away, my guess is that the duplexer is not well-tuned for whatever channel you are using. I would try testing on all 8 repeater channels to see if one works better. If you still can't get any better than one-mile, and assuming it is not an antenna or terrain issue (ie; if your handheld or mobile radio can reach 5 miles from that same location) then I would contact BTech support and tell them to send you one that works. SteveShannon, WRYZ926 and Raybestos 3 Quote
SteveShannon Posted June 30, 2024 Report Posted June 30, 2024 37 minutes ago, Guest John, said: I have this Repeater, it has perfect SWR, pushing Full 50 watts. But I can not receive anyone over a mile away. What is the best way to configure the repeater so that I can receive? I agree with @OffRoaderX, This sounds like an issue with your antenna, feed line or duplexer. (I suspect feed line). Try taking the duplexer out of the feedline temporarily (disable transmit first) to see if your receiving range is more reasonable. If it isn’t, look at the feed line and antenna for problems. It might be as simple as a very lossy coax cable or even a damaged one. A lossy feed line will also make SWR look really good. WRYZ926, WRUU653, WSDM599 and 1 other 3 1 Quote
Guest John, Posted July 1, 2024 Report Posted July 1, 2024 I am using a Btech RPT 50 Repeater, sorry I did not mention that in my first post. Quote
SteveShannon Posted July 1, 2024 Report Posted July 1, 2024 12 hours ago, Guest John, said: I am using a Btech RPT 50 Repeater, sorry I did not mention that in my first post. What type of coax? What length? What antenna? What duplexer? WRYZ926 1 Quote
WRYZ926 Posted July 1, 2024 Report Posted July 1, 2024 24 minutes ago, SteveShannon said: What type of coax? What length? What antenna? What duplexer? Knowing that information would definitely help. Using the best antennas and best coax cable that you can afford is very important and makes a big difference in performance. Quote
WSBT338 Posted July 2, 2024 Report Posted July 2, 2024 Same repeater here, but haven’t tested it yet. Gonna drive away with my 50W Midland MXT500 but waiting for the MXTA26 6dB Gain Whip Antenna to arrive first. See photo for what will be plugged into the RPT50. It’s from DPD Productions and I’m using RG8X. It’s about 30’ up from 14’ elevation. I found a place on the map that gets to 40’ so I’ll probably head in that direction while my wife hangs out at the house. Will report back if you want, but it’ll be next week. Heading out of town tomorrow. Good luck to you! Quote
WRYZ926 Posted July 2, 2024 Report Posted July 2, 2024 @WSBT338 I would definitely go with a different type of coax cable. RG8X has a lot of loss when used for GMRS frequencies. You are looking at a loss of 8.4 dB for a 100 foot run of RG8X, that equates to an 86% power loss. Let's say you are using 100 foot of RG8X, you would only be putting out 7 watts at the antenna with a 50 watt radio. Now let's say you are using 50 foot of RG8X with a 50 watt radio. You will have a loss of 4.2 dB which is a 62% loss with only getting an output power of 18.9 watts. SteveShannon, WRXB215 and RayDiddio 2 1 Quote
WSBT338 Posted July 2, 2024 Report Posted July 2, 2024 8 minutes ago, WRYZ926 said: @WSBT338 I would definitely go with a different type of coax cable. RG8X has a lot of loss when used for GMRS frequencies. You are looking at a loss of 8.4 dB for a 100 foot run of RG8X, that equates to an 86% power loss. Let's say you are using 100 foot of RG8X, you would only be putting out 7 watts at the antenna with a 50 watt radio. Now let's say you are using 50 foot of RG8X with a 50 watt radio. You will have a loss of 4.2 dB which is a 62% loss with only getting an output power of 18.9 watts. Dave Duncan at DPD Productions makes a living on antenna's and disagrees with your assessment. He doesn't even sell LMR400. Quote
WRYZ926 Posted July 3, 2024 Report Posted July 3, 2024 43 minutes ago, WSBT338 said: Dave Duncan at DPD Productions makes a living on antenna's and disagrees with your assessment. He doesn't even sell LMR400. I'm not going to argue with you. It is a well known fact that RG8 and RG8X has high loss on UHF frequencies. Here is one of the better loss calculators I have found. https://kv5r.com/ham-radio/coax-loss-calculator/ I suggest doing your own investigation. You will find that RG8 and RG8X are not good for UHF frequencies. WSBT338, warthog74, SteveShannon and 1 other 2 1 1 Quote
Guest Posted July 3, 2024 Report Posted July 3, 2024 I’d totally agree to dump the rg8 for lmr400. But I’d also get a better antenna for the base as well. Kinda neutered your 50watt radio with all that cable and antenna. Quote
WSBT338 Posted July 3, 2024 Report Posted July 3, 2024 23 minutes ago, WRXP381 said: I’d totally agree to dump the rg8 for lmr400. But I’d also get a better antenna for the base as well. Kinda neutered your 50watt radio with all that cable and antenna. Sorry to hijack this thread If I were to look at another antenna to go with 50' of LMR400 what would you suggest? GreggInFL 1 Quote
WRWE456 Posted July 3, 2024 Report Posted July 3, 2024 2 hours ago, WSBT338 said: Dave Duncan at DPD Productions makes a living on antenna's and disagrees with your assessment. He doesn't even sell LMR400. This is right from the specs on DPD's ad for 50 ft of RG8x. Performance: This cable is fine for short runs from your device to an antenna, but not recommended for critical loss applications above 400 MHz at this length. Using this cable at this length on something like ADS-B, is probably going to create some loss. All he sells is RG8x. WRYZ926 1 Quote
WSBT338 Posted July 3, 2024 Report Posted July 3, 2024 1 hour ago, WRWE456 said: This is right from the specs on DPD's ad for 50 ft of RG8x. Performance: This cable is fine for short runs from your device to an antenna, but not recommended for critical loss applications above 400 MHz at this length. Using this cable at this length on something like ADS-B, is probably going to create some loss. All he sells is RG8x. Never saw that I'll see how my existing setup works, and if it doesn't perform, I'll look into changing it up. Thanks. And hope the OP can figure his situation out too. I'd be experimenting with other channels right away per suggestion above. WRWE456 1 Quote
warthog74 Posted July 3, 2024 Report Posted July 3, 2024 On 7/2/2024 at 5:54 PM, WSBT338 said: I’m using RG8X. It’s about 30’ up from 14’ elevation Agree with the others. RG8/X is fine for 10/11 meter, but your repeater will suffer massive line loss on GMRS. Also only 30 feet high with RG8/X coax will result in horrible repeater performance. You'll be lucky to cover 2 miles. I use LMR400 on a 50 foot run. I had my neighborhood repeater antenna at 30 feet for a while, but coverage wasn't that great. I recently popped it up another 20 feet to 50 feet and i more than doubled my range that's now averaging 10 miles on a 2 watt repeater. Notice that i now am higher than most the trees around vs at 30 feet i was being blocked by trees. The higher you can get that antenna the better your results will be. You also asked about antenna recommendations. I personally use a copper j-pole tuned to gmrs frequencies. Durable, light, cheap, effective. There are better and more expensive antennas, but for home / non commercial use, these work very well. WSBT338 1 Quote
Borage257 Posted July 4, 2024 Report Posted July 4, 2024 Ed fong gmrs collinear, any of the tram/comet etc collinear ground plane antenna. Quote
WRYZ926 Posted July 4, 2024 Report Posted July 4, 2024 On 7/1/2024 at 4:15 PM, Guest WRXT295 said: Lmr 400 coax,comet gp9 I have to agree with others that you might want to contact B-Tech about the issue. Sounds like there might be a problem with the duplexer. You are using good coax and a good antenna. How high is the antenna above ground and is there any obstructions such as trees or building near by? Quote
WSBT338 Posted July 5, 2024 Report Posted July 5, 2024 On 7/3/2024 at 7:42 PM, warthog74 said: Agree with the others. RG8/X is fine for 10/11 meter, but your repeater will suffer massive line loss on GMRS. Also only 30 feet high with RG8/X coax will result in horrible repeater performance. You'll be lucky to cover 2 miles. I appreciate the expert opinions, and I did order LMR400 to replace my RG-8X. That being said, with my existing coax I clearly spoke with someone on a repeater 40 miles away. Quote
AdmiralCochrane Posted July 5, 2024 Report Posted July 5, 2024 1 hour ago, WSBT338 said: I appreciate the expert opinions, and I did order LMR400 to replace my RG-8X. That being said, with my existing coax I clearly spoke with someone on a repeater 40 miles away. Line of sight is more important than power delivered to the antenna; it's possible to hit 40 miles line of sight with less than 5 watts. warthog74, WRYZ926, WRWE456 and 4 others 6 1 Quote
SteveShannon Posted July 5, 2024 Report Posted July 5, 2024 2 hours ago, AdmiralCochrane said: Line of sight is more important than power delivered to the antenna; it's possible to hit 40 miles line of sight with less than 5 watts. This cannot be stressed enough. People routinely talk to the space station using 5 watt radios and it’s more than 200 miles away, but there’s nothing in the way. warthog74, CoffeeTime, AdmiralCochrane and 2 others 5 Quote
warthog74 Posted July 5, 2024 Report Posted July 5, 2024 5 hours ago, WSBT338 said: That being said, with my existing coax I clearly spoke with someone on a repeater 40 miles away. There is a big difference between just transmitting to another station vs running your own repeater. Transmitting to a station 40 miles away doesn't necessarily mean your repeater will cover the same 40 miles using the same antenna and coax. There are a lot more variables involved. Great to see you ordered some better coax though. Let us know how it works out once in operation. WRXB215 1 Quote
WRXB215 Posted July 5, 2024 Report Posted July 5, 2024 3 hours ago, SteveShannon said: 5 hours ago, AdmiralCochrane said: Line of sight is more important than power delivered to the antenna; it's possible to hit 40 miles line of sight with less than 5 watts. This cannot be stressed enough. People routinely talk to the space station using 5 watt radios and it’s more than 200 miles away, but there’s nothing in the way. I agree. It would be nice if I could get that kind of line-of-sight. But I can't. Some of us just can't get an antenna up above the 100'+ trees around us. WRUU653, AdmiralCochrane, warthog74 and 2 others 5 Quote
WSBT338 Posted July 8, 2024 Report Posted July 8, 2024 On 7/5/2024 at 3:30 PM, WRXB215 said: I agree. It would be nice if I could get that kind of line-of-sight. But I can't. Some of us just can't get an antenna up above the 100'+ trees around us. Agreed. As mentioned, I’m at about 44’ above street level which is as high as I’ll be able to go. We’ll see if I can get through the treetops. BTW, LMR400 is bad ass. I had no idea. Replaced my 50’ run yesterday. Will be testing longer distance than the driveway to my wife in the house very soon WRXB215 and WRWE456 2 Quote
SteveShannon Posted July 8, 2024 Report Posted July 8, 2024 47 minutes ago, WSBT338 said: Agreed. As mentioned, I’m at about 44’ above street level which is as high as I’ll be able to go. We’ll see if I can get through the treetops. BTW, LMR400 is bad ass. I had no idea. Replaced my 50’ run yesterday. Will be testing longer distance than the driveway to my wife in the house very soon People sometimes get hung up on height. We have 60 miles and several mountain passes between Butte and Helena Montana. It’s extremely difficult to get higher than the mountains to get line of sight. Yet we have a guy who checks into our 2 meter Net from Helena. We asked how. He does it by bouncing his signal off a mountain that’s in his sight line. I don’t know if something like that could be done in your instance, but look for high topographical features and see what happens. WRUU653, WSBT338 and WRXB215 3 Quote
