WSBS425 Posted November 5 Report Posted November 5 Hi everyone, I’m relatively new to GMRS and currently have a few Wouxun KG-935G Plus handhelds and a couple of KG-1000G Plus base units. I’m using CHIRP and Wouxun’s software for programming. I’d love to connect with someone more experienced who might have an improved code plug that I could apply to my radios. I’m located in the Cornelius/Lake Norman area. Thanks so much for your help! Quote
WRXB215 Posted November 5 Report Posted November 5 @WSBS425 Do you just need an example or are you looking for one that has the repeaters in your area? AdmiralCochrane 1 Quote
AdmiralCochrane Posted November 5 Report Posted November 5 I agree, it's not like DMR If someone doesn't live in the same town as you, a code plug is not likely to be particularly useful. WRXB215 and RayDiddio 2 Quote
SteveShannon Posted November 5 Report Posted November 5 2 hours ago, WSBS425 said: Hi everyone, I’m relatively new to GMRS and currently have a few Wouxun KG-935G Plus handhelds and a couple of KG-1000G Plus base units. I’m using CHIRP and Wouxun’s software for programming. I’d love to connect with someone more experienced who might have an improved code plug that I could apply to my radios. I’m located in the Cornelius/Lake Norman area. Thanks so much for your help! Read the one that’s already on the radio. You should always do that first anyway. Then look at what you want to change, which will be unique to your location. Change or add channels as needed and then write it back to the radio. Hoppyjr, StogieVol and WRUU653 3 Quote
RayDiddio Posted November 5 Report Posted November 5 48 minutes ago, SteveShannon said: Read the one that’s already on the radio. You should always do that first anyway. Then look at what you want to change, which will be unique to your location. Change or add channels as needed and then write it back to the radio. Exactly this. SteveShannon 1 Quote
WRUU653 Posted November 6 Report Posted November 6 I would add, read the one that's on the radio, leave it unchanged and save it, then download another to make changes to and upload that. I find if you have a back up to go back to you probably wont need it but if you don't have one you absolutely will wish you did. SteveShannon 1 Quote
StogieVol Posted November 6 Report Posted November 6 6 hours ago, WSBS425 said: Hi everyone, I’m relatively new to GMRS and currently have a few Wouxun KG-935G Plus handhelds and a couple of KG-1000G Plus base units. I’m using CHIRP and Wouxun’s software for programming. I’d love to connect with someone more experienced who might have an improved code plug that I could apply to my radios. I’m located in the Cornelius/Lake Norman area. Thanks so much for your help! I learned to work my way around the Map on this site and find the repeaters close enough to me that I could hit and programmed those tones. I have learned and grown slowly and by asking questions. Glad to help if I can. I use the KG 935t myself and enjoy that radio. Quote
