WRPL862 Posted February 1 Report Posted February 1 https://www.buytwowayradios.com/wouxun-kg-1000g-plus.html?___SID=U or https://baofengtech.com/product/uv-50x3/ Hoping to use one of these for a SHTF and monitoring communications. I kinda like the Wouxun KG-1000G Plus because it is a heterodyne and a little more sensitive and clearer, but there’s a difference between the broadcast frequencies of the Btech which is homodyne off a chip. I know no one ever has an opinion on these forms but I thought I would ask. LOL Quote
OffRoaderX Posted February 1 Report Posted February 1 I have not used the 50x3, but I have had three 50x2's (basically the same thing).. all three failed within a year or so... Over the last 5 or 6 years I have had 5 (one for each jeep, one for the house, 2 to make into a repeater) KG-1000G's and they all still work today. Raybestos, GrouserPad and WRPL862 2 1 Quote
WRPL862 Posted February 1 Author Report Posted February 1 I had a feeling at 50w the chip would not last. Thanks for the feedback back. Raybestos 1 Quote
WRPL862 Posted February 1 Author Report Posted February 1 I also have to figure out the mobile antenna. Since I live in the Blue Ridge mountains high gain will only benefit when I have few obstructions. I am guessing a 4-5.5 gain if I can find one to hit the G spot for the area. My BF8 hits the repeater sometimes but it gets patchy. Hoping the mobile radio and a good antenna reduces that. I have been on a hunt for a good one. Quote
WRPL862 Posted February 1 Author Report Posted February 1 The down side is not having TX on HAM if SHTF Quote
OffRoaderX Posted February 1 Report Posted February 1 Forgot to add: on all three of the 50X2 units, none of them would output more than 28Watts or so. when i contacted BTech i was told it was because I was not using a dummy-load to measure... Later, when using a dummy load to test, the output was the same. Every KG-1000G i've used (plus friends units that I have tested) all output ~46-51 Watts... WSDM599, WSEZ, WRUU653 and 2 others 4 1 Quote
nokones Posted February 1 Report Posted February 1 15 hours ago, OffRoaderX said: Every KG-1000G i've used (plus friends units that I have tested) all output ~46-51 Watts... No BTech stuff for me. But I do have a three-year-old KG1000G Plus and it puts out 51 watts and my three-year-old Midland MXT500 puts out 49 watts. I guess that is not too shabby for just sitting around all this time. SteveShannon 1 Quote
WRYZ926 Posted February 1 Report Posted February 1 My KG-1000G radios put out between 46 and 50 watts. The Midland MXT500 I had was from a bad batch and would only put out 38 watts on high. One of the guys in our local club has a BTech UV-50x2 and he is wanting to install it inside of his center console. We have all told him not to do that along with saving up for a better radio. I haven't heard very many say good things about the BTech UV50x2 or UV50x3 radios. The TYT-7800 is a pretty good dual band 2m/70cm radio for those on a budget. And it is hard to beat the Wouxun KG-1000G when it comes to GMRS mobile radios. And if you want only a single mobile radio and do not care about it being Part 95 certified, then the TYT TH-7800 is a good one for that without breaking the bank. It is easily unlocked through the official TYT programming software. I actually run a TYT 7800 and a Wouxun KG-1000G Plus in my vehicle. SteveShannon, WRUU653 and GrouserPad 3 Quote
GrouserPad Posted February 2 Report Posted February 2 I’ve got two kg1000g plus’s. Each on a dummy load tx 46 to 54 watts depending on the frequency when measured on a surecom102. Pretty awesome radios. But I do need a scanner to cover the analog frequencies I can’t scan with the kg1000. Although I was able to put most of the Air and Rail frequencies into the kg1000 which is rad af. SteveShannon 1 Quote
WSBR383 Posted March 20 Report Posted March 20 I have and use two Btech UV-50x3's. One is my base radio and one in a SxS. I haven't had any issues with them at all, they are the exact same radio as FTM-350, different firmware. My base radio puts out 50W+- measured on UHF including GMRS. But it also puts out 70W on VHF. I will say my other UV-50x3 has lower outputs, same test environment, but still puts out low 40's in both VHF and UHF. I love the radio and it works and programs so easy with RT Systems software. Never tried the KG1000G, so can't compare to it, but for me, no need to. Quote
WSGU500 Posted May 7 Report Posted May 7 I don't have a BTECH UV-50X3 Tri Band but was using one BTECH GMRS-50V2 as a base and one in my vehicle. I ended up swapping the base unit out for a KG-1000G Plus and have been extremely happy with its performance. I'm located on the outskirts of town (~25 miles away from center) so the additional receive capabilities is noticeable. In fact, I had to start using the receive tones on a couple of the repeaters that I use due to picking up so much distant simplex traffic. Didn't have that with the BTECH. Anyway, glad I had an extra radio because the BTECH in my vehicle quit transmitting. It has been sent in for replacement. The second one (that had been my base unit) is now in my vehicle and so far, doing well. All 3 of these radios showed good power output (until the one BTECH failed) but, if I had to do it again, I would have 2 of the KG-1000G Plus radios. I may still get another KG-1000G Plus although I work from home and don't go mobile all that often anymore. Quote
WRUE951 Posted May 9 Report Posted May 9 i would give the AnyTone AT-D578UVIIIPRO a look at.. I gave my grandson one of these as a gift, its a great radio.. And they are unlock able WRXB215 and AdmiralCochrane 2 Quote
AdmiralCochrane Posted May 12 Report Posted May 12 On 5/9/2025 at 10:15 AM, WRUE951 said: i would give the AnyTone AT-D578UVIIIPRO a look at.. I gave my grandson one of these as a gift, its a great radio.. And they are unlock able That's one of my everyday radios. SteveShannon 1 Quote
