sferguso11 Posted March 17 Report Posted March 17 When it comes to immediate family using the Callsign of a family member, how do the immediate family use the callsign? What I mean is do they use just the callsign or is it the callsign and something after the callsign like callsign unit 1 or callsign dad or something else? Quote
SteveShannon Posted March 17 Report Posted March 17 16 minutes ago, sferguso11 said: When it comes to immediate family using the Callsign of a family member, how do the immediate family use the callsign? What I mean is do they use just the callsign or is it the callsign and something after the callsign like callsign unit 1 or callsign dad or something else? They’re only required to use the call sign, but if it helps you to identify each other you’re allowed to use something like a unit number as well. Personally, I like to use first names or familial relationships, “John, this is grandpa.” Understand that you only need to identify using your call sign once every 15 minutes and when you end a conversation, so if you talk for 2 minutes or 15 minutes you’ll only need to ID once. If you talk for 16 minutes to 30 minutes you are required to ID at least twice. Each time you ID it resets the 15 minute clock. So, if you’re concerned about compliance, just throw in your ID when it’s convenient and at the very end and don’t worry about it. WRUU653, AdmiralCochrane, GreggInFL and 5 others 8 Quote
sferguso11 Posted March 17 Author Report Posted March 17 7 minutes ago, SteveShannon said: They’re only required to use the call sign, but if it helps you to identify each other you’re allowed to use something like a unit number as well. Personally, I like to use first names or familial relationships, “John, this is grandpa.” I'm asking more to see if there's either a FCC required way of doing it, if there's a preferred way to do it in the GMRS or just a personal preference. Quote
SteveShannon Posted March 17 Report Posted March 17 8 minutes ago, sferguso11 said: I'm asking more to see if there's either a FCC required way of doing it, if there's a preferred way to do it in the GMRS or just a personal preference. The only thing the fcc says is that you must ID every 15 minutes and at the end of the conversation and that unit numbers are allowed. § 95.1751 GMRS station identification. Each GMRS station must be identified by transmission of its FCC-assigned call sign at the end of transmissions and at periodic intervals during transmissions except as provided in paragraph (c) of this section. A unit number may be included after the call sign in the identification. (a) The GMRS station call sign must be transmitted: (1) Following a single transmission or a series of transmissions; and, (2) After 15 minutes and at least once every 15 minutes thereafter during a series of transmissions lasting more than 15 minutes. (b) The call sign must be transmitted using voice in the English language or international Morse code telegraphy using an audible tone. (c) Any GMRS repeater station is not required to transmit station identification if: (1) It retransmits only communications from GMRS stations operating under authority of the individual license under which it operates; and, (2) The GMRS stations whose communications are retransmitted are properly identified in accordance with this section. WRYZ926 and AdmiralCochrane 2 Quote
amaff Posted March 17 Report Posted March 17 There's no rule against using names on GMRS. So long as someone IDs every 15 minutes, use your names, use a nickname. Hell, give each other trucker or Top Gun call signs lol The ONLY thing the FCC requires is that someone talking under that callsign IDs every 15 minutes AdmiralCochrane 1 Quote
TDM827 Posted March 17 Report Posted March 17 This is pretty wide open and immediate family members can ID themselves to each other as they like. As long as you follow the call sign identification requirements as mentioned by SteveShannon, or any other FCC regulations. As a practical matter, we find it smoother to make sure the family understands our contact procedure and we stick to it as best we can so it's second nature. We incorporate the last 3 digits of our call sign when calling each other to avoid multiple "Jim's or "John's" who may be monitoring mistakenly answering up. Quote
WSEZ864 Posted March 17 Report Posted March 17 1 hour ago, TDM827 said: This is pretty wide open and immediate family members can ID themselves to each other as they like. As long as you follow everyone follows the call sign identification requirements as mentioned by SteveShannon, or any other FCC regulations. As a practical matter, we find it smoother to make sure the family understands our contact procedure and we stick to it as best we can so it's second nature. We incorporate the last 3 digits of our call sign when calling each other to avoid multiple "Jim's or "John's" who may be monitoring mistakenly answering up. Fixed. TrikeRadio 1 Quote
H8SPVMT Posted March 18 Report Posted March 18 21 hours ago, SteveShannon said: The only thing the fcc says is that you must ID every 15 minutes and at the end of the conversation and that unit numbers are allowed. § 95.1751 GMRS station identification. Each GMRS station must be identified by transmission of its FCC-assigned call sign at the end of transmissions and at periodic intervals during transmissions except as provided in paragraph (c) of this section. A unit number may be included after the call sign in the identification. (a) The GMRS station call sign must be transmitted: (1) Following a single transmission or a series of transmissions; and, (2) After 15 minutes and at least once every 15 minutes thereafter during a series of transmissions lasting more than 15 minutes. (b) The call sign must be transmitted using voice in the English language or international Morse code telegraphy using an audible tone. (c) Any GMRS repeater station is not required to transmit station identification if: (1) It retransmits only communications from GMRS stations operating under authority of the individual license under which it operates; and, (2) The GMRS stations whose communications are retransmitted are properly identified in accordance with this section. I take the to mean identification isn't necessary at the beginning of the transmission, just the end, correct? WRUU653 1 Quote
WSEZ864 Posted March 18 Report Posted March 18 4 minutes ago, H8SPVMT said: I take the to mean identification isn't necessary at the beginning of the transmission, just the end, correct? Every 15 minutes and, as you say, at the end. WRUU653 1 Quote
WRUU653 Posted March 18 Report Posted March 18 1 hour ago, H8SPVMT said: I take the to mean identification isn't necessary at the beginning of the transmission, just the end, correct? Correct. SteveShannon 1 Quote
WRUU653 Posted March 18 Report Posted March 18 23 hours ago, SteveShannon said: just throw in your ID when it’s convenient and at the very end and don’t worry about it. This ^^^ keep it simple I think is the essence of GMRS. SteveShannon 1 Quote
SteveShannon Posted March 18 Report Posted March 18 1 hour ago, H8SPVMT said: I take the to mean identification isn't necessary at the beginning of the transmission, just the end, correct? As Gil said, that’s correct. When GMRS is used to communicate with people you already know an introduction isn’t necessary and nothing in the regulations require using a call sign at the beginning of a call for either GMRS or ham radio. Ham radio operators usually will use their call signs at the very beginning of a contact as a matter of courtesy to introduce themselves but they are simply required to ID at the end of every communication and every 10 minutes. Now, something I don’t honestly know is whether every communication means every time we push the PTT. A lot of times I’ll give a short answer without using my call sign, as do all the other hams I know. WRUU653 and Jaay 2 Quote
Davichko5650 Posted March 18 Report Posted March 18 2 hours ago, SteveShannon said: Now, something I don’t honestly know is whether every communication means every time we push the PTT. I listen to a group on a local 2m repeater I can hear, but normally can't talk on more often than not (dead spots and terrain issues) that are on most every weekday AM and the number of times they repeat their callsigns borders on the ridiculous. I've not ever gotten on to bug them about this, but have mentioned it to a couple of them during "eyeball QSO's" at hamfests or other occasions when I've met them. Never hurts to ID more than required, but when it's before and after every transmission, it gets a bit much. Quote
H8SPVMT Posted March 19 Report Posted March 19 Thanks for the replies! Thinking over the years I have picked up a bad habit. SO it is, just at the end of the conversation. I like that better! WRUU653 1 Quote
WRUU653 Posted March 19 Report Posted March 19 6 minutes ago, H8SPVMT said: Thanks for the replies! Thinking over the years I have picked up a bad habit. SO it is, just at the end of the conversation. I like that better! If by bad habit you mean announcing your call sign at the beginning, I think that is fairly common and I wouldn’t consider it a bad habit. Rather when conversing with family or friends I would say you shouldn’t feel obligated. I like to think GMRS is a little less uptight. I wouldn’t give you a hard time either way. SteveShannon, marcspaz and WRYZ926 2 1 Quote
WRTC928 Posted March 25 Report Posted March 25 On 3/18/2025 at 10:44 AM, Davichko5650 said: I listen to a group on a local 2m repeater I can hear, but normally can't talk on more often than not (dead spots and terrain issues) that are on most every weekday AM and the number of times they repeat their callsigns borders on the ridiculous. I've not ever gotten on to bug them about this, but have mentioned it to a couple of them during "eyeball QSO's" at hamfests or other occasions when I've met them. Never hurts to ID more than required, but when it's before and after every transmission, it gets a bit much. On the repeaters I use, it's not the norm to give a callsign at the end of every transmission. People typically use their callsign at the beginning and periodically (usually when the repeater IDs), then when they're finished with the conversation. I suppose it varies from one location to another. Things often become customary not because there's any requirement for it or even inherent logic in it, but just because it's what someone did and everyone else followed suit. amaff 1 Quote
wrci350 Posted March 25 Report Posted March 25 3 hours ago, WRTC928 said: On the repeaters I use, it's not the norm to give a callsign at the end of every transmission. People typically use their callsign at the beginning and periodically (usually when the repeater IDs), then when they're finished with the conversation. I suppose it varies from one location to another. Things often become customary not because there's any requirement for it or even inherent logic in it, but just because it's what someone did and everyone else followed suit. There is no need to ID after each transmission on either GMRS or amateur radio. Periodically (15 minutes on GMRS, 10 on amateur radio) and at the end of a conversation. The point of IDing at the beginning of a conversation is just that ... identification. "Joe this is Bill do you hear me" is not as specific as "This is <callsign1>. Callsign2 do you hear me? Sure, if it's a private repeater and only you and other members of your family are using it then just names works fine. But in the general case, not so much. WRYZ926 and WRTC928 2 Quote
WRYZ926 Posted March 26 Report Posted March 26 14 hours ago, wrci350 said: The point of IDing at the beginning of a conversation is just that ... identification. "Joe this is Bill do you hear me" is not as specific as "This is <callsign1>. Callsign2 do you hear me? Sure, if it's a private repeater and only you and other members of your family are using it then just names works fine. But in the general case, not so much. This is especially true when you have several people using the repeater that have the same first name. We have several Johns, Ricks and Rons that use our amateur and GMRS repeaters. Plus we have quite a few people traveling through the area that use our repeaters. Most of us will ID at the beginning of our conversation, every 10/15 minutes and then at the end of our conversations. I have not heard anyone ID after every transmission on any of the 2m, 70cm, and GMRS repeaters. The last time I used call signs after each transmission was in the military, but the was SOP. SteveShannon 1 Quote
nokones Posted March 26 Report Posted March 26 On 3/17/2025 at 9:05 AM, TDM827 said: This is pretty wide open and immediate family members can ID themselves to each other as they like. As long as you follow the call sign identification requirements as mentioned by SteveShannon, or any other FCC regulations. As a practical matter, we find it smoother to make sure the family understands our contact procedure and we stick to it as best we can so it's second nature. We incorporate the last 3 digits of our call sign when calling each other to avoid multiple "Jim's or "John's" who may be monitoring mistakenly answering up. Ultimately, the person listed on the license is responsible for all authorized family members and has to answer to the FCC when requested to do so and will have to identify those family members when a rule infraction/violation occurs. SteveShannon 1 Quote
LeoG Posted March 29 Report Posted March 29 On 3/26/2025 at 8:46 AM, WRYZ926 said: This is especially true when you have several people using the repeater that have the same first name. We have several Johns, Ricks and Rons that use our amateur and GMRS repeaters. Plus we have quite a few people traveling through the area that use our repeaters. Most of us will ID at the beginning of our conversation, every 10/15 minutes and then at the end of our conversations. I have not heard anyone ID after every transmission on any of the 2m, 70cm, and GMRS repeaters. The last time I used call signs after each transmission was in the military, but the was SOP. That why both the repeaters I use have a numerical ID system. It comes with getting permission to use the repeater, they issue you an ID number. Then you can call out 105 calling 325 and you don't have to worry about getting the other Tom or Jerry that is on the repeater. After a short while you memorize the people's ID you converse with and it's easy to call out. Quote
WRYZ926 Posted March 29 Report Posted March 29 39 minutes ago, LeoG said: That why both the repeaters I use have a numerical ID system. It comes with getting permission to use the repeater, they issue you an ID number. Then you can call out 105 calling 325 and you don't have to worry about getting the other Tom or Jerry that is on the repeater. After a short while you memorize the people's ID you converse with and it's easy to call out. That is one way of doing things just as using call signs is another. Quote
WRTC928 Posted March 31 Report Posted March 31 On 3/28/2025 at 9:56 PM, WRYZ926 said: That is one way of doing things just as using call signs is another. Call signs work very well in amateur radio where each user has an individual call sign, but I can imagine that with 3-4 families with 3-4 members each using a GMRS repeater, it could get a bit confusing. Quote
WRYZ926 Posted March 31 Report Posted March 31 5 minutes ago, WRTC928 said: Call signs work very well in amateur radio where each user has an individual call sign, but I can imagine that with 3-4 families with 3-4 members each using a GMRS repeater, it could get a bit confusing. We do occasionally have more than two family members talking on the repeater along with others and it hasn't been an issue. SteveShannon 1 Quote
wrci350 Posted March 31 Report Posted March 31 On 3/28/2025 at 10:56 PM, WRYZ926 said: That is one way of doing things just as using call signs is another. Yes, except the FCC regs require use of call signs, not "numerical IDs". Apparently the owners of those repeaters don't care, unless you are saying these IDs are used along with the call signs, not instead of. For whatever reason, the "cool thing" around here seems to be using just the numeric part of the call sign. "123 this is 456". Not sure I would find memorizing a three-digit number any easier than memorizing an alphanumeric call sign. Quote
WRYZ926 Posted March 31 Report Posted March 31 Well every one that uses our GMRS repeater does use their actual GMRS call sign. They will use designators such as WRYZXXX Base, or WRYZXXX Unit 2, etc. And that has worked just fine for us. I would not want to try and remember a bunch of numbers either. And you still have to use your call signs when using open repeaters anyway. Now if the repeater is closed and ONLY used by immediate family then that's a different story. Correction. Call signs are still required even on private/closed repeaters. Though the repeater itself does not. SteveShannon and WRUU653 2 Quote
