  2. It's no different than using a chimney mount or a satellite dish mount on your roof. You run the proper sized ground wire from the antenna/mount to ground. Look at a properly installed satellite dish antenna. There will be a ground wire running with the coax. And that ground wire should be bonded to your service ground before the coax enters the structure. The same goes for cable TV, there will be a ground wire coming off the feed to your home and it to will be grounded to the service ground when installed correctly.
  3. Yesterday
  4. How does it change the calculations if the antenna is mounted on something non-conductive like a fiberglass mast?
  5. Use one of the many coax loss calculators to see if the loss for that length is acceptable to you.
  6. Dogs like us struggle with keyboards. I'm trying to get into CW. Strait key obviously. Paddles are out of the question.
  7. Unless I misread the NEC and other sources, the tower should have its own ground and be bonded to the service ground. This is correct. Steve did a good job of expelling things
  8. Let’s disregard lightning protection for a few minutes and just talk about bonding to your house service ground. Your tower is sort of grounded. We all agree with that I think. It’s embedded in an imperfect conductor, concrete, at the bottom. To improve the grounding a ground wire runs from each leg of the tower to a ground rod. But any two separate ground rods are almost always at different potentials. Whenever you have different potentials between two points in a circuit you will have electric currents flowing from one point to the other. So, the three or four legs of the tower are bonded together using a material that is more conductive than the tower itself. Otherwise you have current flowing between the legs of your tower. If current flows between the legs of your tower over time the metal of the tower will corrode. Bonding between the three or four legs provides an easier path for the current to flow which keeps the legs all at the same potential. In addition your antenna mount is certainly connected electrically to your tower and your coax shield is connected to your antenna mount. Your coax shield then runs to your radio. If you have a watt meter, amplifier, or any other device between your radio and your antenna, they are all connected serially via the coax shield. Their metal cases are all connected to the coax shield. So all of the devices in your shack are connected together via the coax shield. If a power surge comes through the shield (static, lightning, unicorn farts, whatever) it is going to cause current to flow through your equipment because that’s the most direct path. By bonding the chassis of all those devices to a single point, we provide a much better path that doesn’t flow through those devices. So that’s why we use a single point ground. But remember, that single point ground is connected to ground at the tower. You power your radio with a power supply that’s plugged into your house power. Its case is connected to the ground wire in the outlet which runs back to the service panel where it’s bonded to the service ground for the utility power coming into your house. It has to be because NEC says so. So let’s say you don’t have your single point ground bonded to your service ground. You reach out to touch your radio and at the same time your brush your other hand on the power supply. The potential of your tower ground, which is what your one hand is touching, is probably different than the potential of the service ground, which is what your other hand is feeling. And it’s DC. Your heart can be stopped by as little as 1/10 of an ampere. So you die. So we bond the tower ground to the utility ground to ensure they are at the same potential and save your life. Also with fewer ground currents in the shack we hear less noise.
  9. What happened to the Winslow repeater in NW Arkansas? It doesn't come up on the gmrs map and it does not seem to work for me anymore.
  10. I’m thinking I’m going to build a repeater. I’m making a shopping list. I want to use two Kenwood tk-8180 radios and a mobile Celwave 633-6a-2 duplexer. I keep seeing images of people using what looks like rg400 coax from the radios to the duplexer. I used lmr400uf ultra flex from DX Engineering to connect my base station and I have some left over. But the lmr400uf is still stiff for such a small distance from radio to duplexer. If I use a smaller coax like the rg400 vs the lmr400uf will it make that much of a difference? thank you!
  11. So, a home antenna tower shouldn't have it's own ground? Just bond to house ground?
  12. I'm not following you. What does that have to do with lightning protection? What kinds of problems will it cause? To be clear, I'm not being confrontational. I'm really trying to understand this.
  13. To prevent electrical noise being transferred from one system into the other system. You are drawing power from one electrical system thus you should be using only one grounding system. If you have two earth grounding points then you have two grounding systems and that will cause problems.
  14. Today, after much research, I programmed my new AR-152 radio using Chirp. I used the UV5-XP profile because it was recommended in another forum, is similar to what the manufacturer recommends, and features three power-level settings. After downloading and saving the factory settings, I uploaded my list of frequencies to the AR-152 using the UV5XP profile. I did not mess with frequency range or any advanced settings. So far I have only modified a few basic settings like muting the beep and voice. As measured by the Farsometer, the transmit power levels remained the same before and after programming with Chirp. I am still testing, but so far the radio appears to function as designed. Pre-Chirp: Freq. 155.500 H: 8.2 watts, M: 6.3 watts, L: 2.08 watts Freq. 438.500 H: 9.2 watts, M: 5.8 watts, L: 2.4 watts After Chirp: Freq. 155.500 H: 8.2 watts, M: 6.3 watts, L: 2.15 watts Freq. 438.500 H: 9.3 watts, M: 5.9 watts, L: 2.5 watts
  15. Correct - Because Commercial Sites Don't Have A House - They Have A Structure Or A Cabinet For Equipment. The Structure Or Cabinet Requires Proper Bonding - For Single Point Grounding - To Avoid A Ground Potential Difference.
  16. Hello Group! Here is a quick repeater system update! 6/28/25 SGA-575 is on the air! New updated repeater is in and being readied to be installed in the near future. Also antenna crew is being scheduled to replace the existing antenna with one that has higher gain. SGA-600 is on the air! Intermittent noise issues....Replacement duplexers have been received and tuned. Scheduling date to install them. SGA-650 is NOT on the air! Down due to hurricane Helene tower being destroyed. New site has been located and equipment is being ordered. Tower crew to be scheduled for work. No ETA at this time. SGA-700 is on the air! No issues noted at this time. Thanks, Scott Haner - SYSOP WRFS362
  17. That was my logic, hence my confusion at the recommendation to do that.
  18. Yes, but commercial tower sites don't then bond the ground to a house ground. What I'm trying to figure out is why almost every article or video I find recommends doing that.
  19. The actual ground (i.e., dirt) can be a conductor of lightning that hits nearby, especially wet ground in a thunderstorm. By installing grounding wires, you may be increasing potential of that getting to your electronic devices inside. For ordinary folks, disconnecting the devices from the AC and antenna lines is the best option.
  20. It's Called Single Point Grounding. Reason - To Eliminate A Potential Difference Between Having (2) Separate Grounding Systems. Single Point Grounding Is Done On All Commercial Tower Sites.
  21. You answered your own question by keeping PROPER grounding outside so there's no need to do any grounding inside the house.
  22. I'm sorry, but I don't understand how that relates to my question. Please elaborate.
  23. All radio related grounding should be done with 500MCM cable. End of story.
  24. What is the logic behind bonding your lightning ground to the house ground? Lightning always wants to go to the earth, so grounding your antenna and coax makes sense. You give the lightning an easy path to the earth, and hopefully it will take it. I also understand why it's recommended that you bond the common ground for your equipment to the house ground. The powered equipment is part of the same circuit as all the other electrical equipment in the house and you want to keep it at the same potential. However, I don't follow the reasoning of bonding the two together. It seems to me that the most logical solution for protecting against lightning is to give the electrical buildup a way to get to the earth without directing it into your house; i.e., a lightning ground separate from the equipment ground. Yet everything I read recommends bonding the lightning ground to the house ground, so there must be some reason that I don't understand.
  25. Awesome, thanks for that information. I will definitely be taking that into consideration. I'm just trying to get something up and going for the meantime as I build the setup I want when I have the time to do it.
  26. I want to set up the antenna temporarily in the joists until I can get the long term setup built and in place. I don't get a lot of free time due to work, kids etc. so I was going to do the joist mount as a down and dirty temporary solution as I built the antenna setup I really want. If I do mount the temporary setup outside, I want to make sure it is properly grounded and bonded. I work as an industrial controls electrician and I've seen how lightning strikes, even indirect ones, can completely destroy communications systems.
  27. I don't know why the quote box attributed that line to you. Probably my bad though.
