Can I use an RJ45 splitter to run dual Hand Mics?
MDYoungblood replied to WSJL659's question in Technical Discussion
I'm going to say "Yes" but the splitter needs to be the type where all the oins go to the same place, as is pin 1 is the same on all 3 locations etc. Like I read in the comments there might be an impredence issue affecting the radio's modulation when keyed. You might want to think of some kind of bluetooth devise like the Uniden microphone, only problem there is they lack distance. 3's Greg -
WRUU653 reacted to a post in a topic: Ham Radio 2.0 Coverage of Low-band Channels for GMRS
WRUE951 replied to WSJL659's question in Technical Discussion
I knew that would cofuse you Boxcar.. - Today
SteveShannon reacted to a post in a topic: Ham Radio 2.0 Coverage of Low-band Channels for GMRS
WRTC928 replied to marcspaz's topic in General Discussion
Yeah, I'd like to get back to lifting weights, but I don't want anything like that to happen. I'm going to be careful with it for quite some time. -
BoxCar reacted to an answer to a question: Can I use an RJ45 splitter to run dual Hand Mics?
Jesus.. whats a real cheerleader -
WRUE951 reacted to an answer to a question: Can I use an RJ45 splitter to run dual Hand Mics?
wrci350 reacted to a post in a topic: Ham Radio 2.0 Coverage of Low-band Channels for GMRS
SteveShannon reacted to a post in a topic: Volts
I know the Wouxun KG-1000G and Radioddity DB20-G calls for 11.7 - 15.8 volts. I couldn't find the specs for the Midland MXT500 but it's probably the same. Pretty much all transceivers call for 11.7-15.8 volts. Yes you will see a small drop in output power at the lowest allowed voltage compared to 13.8 volts or the max allowed voltage. But it is not enough to make a difference on signal strength or FARS. I haven't noticed any differences with my QRP HF radios that have internal batteries. They usually will put out 5 watts with the internal battery and 8-10 watts on an external power source, depending on the radio.
SteveShannon reacted to an answer to a question: Can I use an RJ45 splitter to run dual Hand Mics?
amaff replied to WSJL659's question in Technical Discussion
To answer the original question: I don't see a reason that wouldn't work. There's a couple of BTech radios that do this from the factory. They have RJ-45 connectors at the radio, and come with a splitter that has RJ-45 on 1 end, and a K1 connector on the other. In my case, I have one in my race car, with the K1 connector going to the wiring harness for my helmet mounted mic & ear buds, and steering wheel mounted PTT. -
nokones replied to WSJL659's question in Technical Discussion
Yes you can have multiple microphones connected to one radio device and it is done all the time in the Aviation industry. It is not rocket science, it is basic electronics in matching levels with each microphone circuit with the radio device. Don't forget, if you're going to have separate microphones in separate locations, you will need to have separate speakers and you will need to factor in if you are going to have side tone without causing feedback (audio loop) or if you're going to automatically mute the receive audio circuit. It will be a little more involved than just coupling (doubling) two microphones to one radio. Also, fire apparatus have multi-comm systems similar to aircraft systems. And, Rugged Radios has on-board radio/Intercom systems for multiple users in one vehicle for off-road applications. You might want to checkout Racing Radios or Radio Electronics. -
amaff started following Can I use an RJ45 splitter to run dual Hand Mics?
It's basically* ethernet in the same way that the 120v wiring in your house is basically ethernet. Ethernet is a network technology. There's no 'networking' going on between the mic and your radio. No addressing being shared. It's just using a common connector to pass the same type of signal (your audio, your PTT trigger, button pushes) that would come through any other kind of mic connector to the radio. It's an RJ-45 connector. It's nothing at all like an ethernet connection other than it shares a common connector type. -
MarkInTampa replied to WSJL659's question in Technical Discussion
Two problems I see... 1st) If you are using a Y-cable/splitter I'd assume you are going to run into mic impedance issues. The radio is designed for a certain microphone impedance, adding another mic in parallel or trying to extend the cable by 30ft is probably gonna jack it up. 2nd) If you did run a 2nd hand mic somewhere - what about audio? -
i said basicity. The MIC connection and cable is using the same physicial RJ45 connector and twisted pair wire found in ethernet systems but with different wiring pinout and for different purposes. Yes, it is a non ethernet connection, we all know ethernet needs to be a managed connections, hence the reason you use switches or routers in a eithernet environment which is more than likley lacking with his set up. I will say, if i wanted to, i could extend the mic on my repeater via Ethernet and a lot of other things. -
SteveShannon replied to WSJL659's question in Technical Discussion
No, although the same connector is used, none of the radio microphones for which I’ve seen schematics are Ethernet. The different wires carry analog audio, push to talk, and other analog connections which allow push buttons or LED lights on the microphone. -
Some people do use an RJ45 manual switch to switch between two microphones, but in that case only one microphone is connected at a time. I don’t know how what you refer to as an RJ45 splitter is actually wired, but if the two microphones are connected in parallel I would not expect good results. Also, there’s the problem of having a long run for the microphone cable. You might find that it’s just too long and your audio signals are too weak. -
it doesn't make sense. why would you want to split the mic? You can extend a mic using RJ45 extensions.. There are aslo some Bluetooth mic gizmos that you can add. The Mic connection is basicly an eithernet connection to the radio, generally, no you can not split an ethernet signal without feeding it through a switch or router.. -
I am working on setting up a base station and ideally would like the unit to live in the basement. Can I simply use an RJ,45 splitter and run a remote handmic elsewhere in the house? I haven't found any examples of this anywhere, but don't see why it wouldn't work. Thank you! -Adam
WSDI414 joined the community
LeoG started following Duplexer insert keeps burning out.
When you changed out the tuning rods and made them thinner by removing the threads instead of leaving a space in there maybe you could make the teflon (or plaster) insulator thicker so it is more snug on the smoothed out threaded screw. A thicker insulation would give you better protection. Good idea taking the receive insulators and use them on the transmit side. I think the 1st one burns out because it's 1st in line of the three, taking the brunt of the power.
WSIU894 joined the community
mperciful joined the community
Lscott replied to marcspaz's topic in General Discussion
Been there about 12 to 15 years back. Had a minor rotor cuff tear in the tendon. Got surgery to stitch up the tear, doc put in an anchor to reattach the torn section to the bone and clean off some bone spurs. I wrecked the shoulder at the gym while using the upright seated bench press machine. Yeah, it hurt like an SOB when it happened too. Then the shoulder “popped” just a fraction of a second after I felt the stretching sensation. When home offer that. Basically couldn’t lift my right arm. It took about 6 months of PT just to get back normal range of motion. Then another 6 months to a year building the strength back up. -
WSDY936 joined the community
Kudos to @dosw and @tweiss3 for understanding the question and providing good answers.
Actually, your local repeater coordination body (typically won't answer anything and are useless), have recommended tones (2-5 of them) for each region of the area which they coordinate. These are Ohio's recommendations, not requirements, but it keeps adjacent pairs from using the same tones.
WSFA263 joined the community
WSGV743 joined the community
While the choice of CTCSS tones is not entirely random, it may as well be. There are common conventions, like avoiding adjacent tones in a given overlapping area, avoiding tones that are harmonics of power lines, that sort of thing. I think in some cases it's more about "legacy conventional wisdom" than about "real world issues in 2025." But as far as repeaters following a pattern, what you might be seeing is either a freak coincidence, or regional conventions that may have some historical rationale. Not any broadly adopted pattern.
Your title says "offsets" but then, in the body of your message, you talk about CTCSS. Which one is it and what pattern do you think you are seeing?
WRZG610 joined the community
Jbfaust joined the community
Repeater Off-Sets are different with HAM.
SteveShannon replied to TNFrank's topic in Amateur Radio (Ham)
No, I haven’t noticed. -
I've also noticed kind of a pattern for CTCSS tones for each band. Not every repeater follows the pattern but I'd say a good 80-90% of them do. Has anyone else noticed this?
WSJM822 joined the community
WSJS901 joined the community
The mystery of the MXT-400 that can ....Talk Around Feature
tweiss3 replied to H8SPVMT's question in Technical Discussion
Talk around is a great function commonly used in commercial radios. It switches your TX frequency to the output of the repeater to operate in simplex. I personally think it should be used more, but it's only as good as those trained how/when to use it. -
two different MDC acronyms. I'm referring to Motorola Digital Communicator.. So yes i 'get it' Motorola Data Communications is acceptable. I'll still stick with MAGA though
