OffRoaderX
    270
  1. I have one mounted on a cookie-sheet in the window. You only need a few inches of metal around the base, and it doesn't even need to be solid-metal, it can be strips. There is also an inexpensive ground-plane mount you can by that will do the job, but i dont think the hand-railing alone will do the job unless it's at least 6-10 inches wide. My 72G on the cookie-sheet works fine - it has an SWR below 2 and I can hit repeaters 70 miles away and talk on simplex with HT's ~20 miles away.. YMMV based on terrain.
  2. Sir, the term "CCR" is racist and moolahphobic.
  3. The best and most important functions to have on a radio are the ones that are most important to you and allow you to do whatever you want to do with your radio. In other words, only you can answer that question. That said, by far, THE single most important feature to have on a radio is the Roger Beep - because without it you will never be able to draw-out all the Sad-H.A.M.s and laugh at them when they start crying about hearing your Roger Beep.
  4. Is the duplexer correctly tuned for whatever frequency you are using? and are your two RA87s properly shielded to prevent de-sensing each other?
  5. EDIT: Upon reflection, never mind.
  6. Based on all of the detailed information you have provided, I would say "probably a lot of things"
  7. Yah, there is a reason for that.
  8. Ok.. Mine did not do that.. It's not in the user-manual because this radio does not have a Roger Beep.. So yours must be defective. What did BTech Support have to say?
  9. Aluminum will work, but your mag-mount wont stick to it as well as a cookie-sheet.. However the wife will probably complain less about using the foil vs the cookie-sheet. I'm sure that "some people" will leave a more detailed, 10-paragraph explanation complete with the molecular differences between steel and aluminum and the RF calculations, all just to say "it will work" ....
  10. The offset is 462.700 +5Mhz = 467.700 - thats what you are seeing on the screen when you transmit. Because it's a GMRS radio, you dont have to worry about entering the offset because it's all automatic. The radio is working 100% as it should. If people aren't hearing you it is because you are either not in range of the repeater (just because you can hear it does not mean you cant hit/use it from your radio), you put in the wrong tone, or did something else wrong.
  11. You wont find it in the manual because the 50V2 (at least, the one that I had) does not have a Roger Beep.
  12. What kind of report are you trying to download, and as already asked, WHERE/HOW are you trying to download it from?
  13. I want to see him tell us.
  14. Oh my, that sounds serious! So what will happen if he uses an illegal radio on GMRS?
  15. The fact that the OP, and a thousand others have to ask this question, prove that this is incorrect. It might be written down somewhere, but the fact that nobody knows and even less people abide by it shows that, in the real-world, this is incorrect. as @Sshannon said, there is no [widely-recognized] call channel IN USE - to refer to some outdated and UNUSED reference is disingenuous at best.
  16. I dont think you actually understand what the term "major issue" means. Now please write a page-long explanation of why i'm wrong so more people can laugh at you.
  17. yah, i'm outraged... because its such a major issue...
  18. I stand corrected.. ONE other guy ...
  19. I have, or have had every GMRS radio that Wouxun makes. In some cases, multiple ones, and I have never, once, seen this issue. I also have many friends, and about 200K fans, and none, never, once, have mentioned this issue.
  20. I concur.. Putting together a repeater with two KG1000's is fun, but you will get better performance and can probably save some money with a "real" repeater. You can find a good, used UHF repeater for a few hundred $$, and some can double as a base-station.
  21. 93 miles from Palm Springs, CA to our old "Delta" repeater, using the XTL5000 in my jeep with the Midland MXTA26 antenna mounted on the rear tail-light, where all of the "experts" still proclaim that the antenna will not work because it is below the roofline and due to the poor ground plane at that mounting location. Initially started using the repeater with my radio transmitting at 40W, and when I switched to 110W nobody could hear any difference. I have heard people in their mobile radios hitting that same repeater from 40 miles further away at Chiriaco Summit for a total of 133 miles, but I cant do it - probably because my antenna wont work where it's mounted.
  22. @WRXP381 is the kind of sad-H.A.M. that some Youtubers make fun of all the time. If he does not yet actually have a H.A.M. license, then he is a latent Sad H.A.M... Hopefully you get the radio back together - keep us updated.
  23. I just checked, and all of my standard SMA connecters fit perfectly into my Q10G - but when I look at the picture of your antenna, it looks like you broke your radio and the SMA connector is still attached to the antenna, leaving what is probably nothing more than a useless ragged-hole (much like my ex-wife) in the radio . Compare the bottom of your antenna to the bottom of my antenna in my pic.
  24. IF you can get the antenna off without destroying the radio, you will discover an SMA 'male' type connector.
  25. If they never used them why would they take all the time to mention them in the SX700, T5100, and several other user-manuals?
