270
Many repeaters use DPL codes.. Many other repeaters use CTCSS codes, and that is exactly what the "interference Eliminator Codes" are. So the answer to your question is: NO
I would just like to point out that one need not be "a programmer" to setup a UV-5R radio. Investing a few minutes reading some online articles or watching Youtube videos is all you need to learn how to 'program' your radio. You can even do it all by hand, right on the keypad, no computer necessary. Virtually everyone here learned to do it ourselves, and we all have faith that you can too - We believe in you!
50W is good, especially when you have a long-run of that leaky coax, to get more juice squirting from the antenna. 50W is also good to step on the other guy that is irritating everyone but only has 20W.. all else being equal.
You thought wrong.
I volunteer @WRXY699
It does not really require much research - just follow this formula: IF radio is manufactured after 2017 AND IF radio says "GMRS" on the box THEN = FCC Type Accepted* *99.9998% of the time
1: YES - you also have to add the correct "TX" or Transmit tone .. The RX/Receive tone is optional 2: GMRS is not primarily intended to "get into conversations with others" - but if you insist, just call out and ask if anybody wants to talk to you. There is no protocol other than talking normally and using your GMRS callsign at least once every 15 minutes.
Be careful!!1 I have read that the rubicon guy is just a shill for cheap chinese radios and will say anything the manufactures tell him to say!!!1 I know it must be true because the people that say that have been licensed ham radio operators for 20+ years, it says so right in their forum signature!!1
Hypothetical Scenario: What would happen?
OffRoaderX replied to Webslinger's question in Technical Discussion
Yes, there will be interference. -
Tidradio TD-H8 Won't Hold Channels in Memory.
OffRoaderX replied to WSAA635's question in Technical Discussion
Should have got the BoofWHang! -
The only other option is to give a fake address, but that violates the rules so either Ham Registry or a PO box are the only FCC-acceptable ways to keep your address private.
Antenna question on roof of 4Runner
OffRoaderX replied to WRZP383's question in Technical Discussion
Are you talking with your friends on the trail, or trying to bounce signals off the moon and talk to strangers across the planet? If you are using your radio for talking to your friends on the trail then SWR of 1.4 is fine and SWR of 2.4 is good enough. Stop overthinking it and just enjoy the radio. -
Maybe they can hear you, but just don't want to talk to you.
No. The Output Tone is always optional and is only used to limit what you hear to only that repeater.
Although overload is a real thing, after testing LITERALLY every GMRS handheld manufactured in the last 5 years, I have never, EVER, NOT ONCE seen any overload/desense issues unless the radios were closer than about 75 feet, an 90% of the time they had to be closer than 25 feet or so. To claim that overload is an issue at up to a 1/2-mile, on its surface, seems like a preposterous over-exagguration, based on my very extensive testing. But that's just my experience..
Fixed that for you. For someone that is already at least vaguely familiar with what repeaters are and how they work, its a "little" more difficult.. For someone that knows absolutely zero about nuthin, it is going to be a LOT more difficult.
All of your radios are H.A.M. radios, so they probably won't be able to transmit on the GMRS repeater.. But, if they are unlocked, you can ignore the 'output' tone until you know what you're doing, and just use the input tone by entering that in your repeater-channel setup which will be specific to each radio. You have a lot to learn - there are no simple, quick answers.. Unless you had real GMRS radios, then it is actually pretty simple and quick to use a repeater.. but you have H.A.M. radios.. sooo...
Situation: Mobile Repeater Operation During Disaster
OffRoaderX replied to WRZM243's question in Technical Discussion
No way you're going to get MY toilet paper... Nice try.. -
What repeater and antenna would you choose?
OffRoaderX replied to bshort's question in Technical Discussion
I chose a Vertex VXR7000 and a Tram1486. I chose the 1486 due partially to its very low wind-profile. -
Edit: Nevermind
Moisture bearing vegetation is even worse than houses full of .. .fat people!
You can't (yet) use CHIRP to program your UV-5G+.. Your best hope is IF you can copy and paste the info from CHIRP into the UV-5G Plus software. Or export from CHIRP and import into the UV-5G+ software, and I'm not sure the 5G+ software can do either.
I never thought of this. I will check the other harmonics (above and below) for 462.6000 and see what I hear.
Then why does it occur on all my radios (forgot to mention in my list above it also happens KG-1000G+) and why did it just start happening a few months ago?
