OffRoaderX
    281
  1. All of your radios are H.A.M. radios, so they probably won't be able to transmit on the GMRS repeater.. But, if they are unlocked, you can ignore the 'output' tone until you know what you're doing, and just use the input tone by entering that in your repeater-channel setup which will be specific to each radio. You have a lot to learn - there are no simple, quick answers.. Unless you had real GMRS radios, then it is actually pretty simple and quick to use a repeater.. but you have H.A.M. radios.. sooo...
  2. No way you're going to get MY toilet paper... Nice try..
  3. I chose a Vertex VXR7000 and a Tram1486. I chose the 1486 due partially to its very low wind-profile.
  4. Edit: Nevermind
  5. Moisture bearing vegetation is even worse than houses full of .. .fat people!
  6. You can't (yet) use CHIRP to program your UV-5G+.. Your best hope is IF you can copy and paste the info from CHIRP into the UV-5G Plus software. Or export from CHIRP and import into the UV-5G+ software, and I'm not sure the 5G+ software can do either.
  7. I never thought of this. I will check the other harmonics (above and below) for 462.6000 and see what I hear.
  8. Then why does it occur on all my radios (forgot to mention in my list above it also happens KG-1000G+) and why did it just start happening a few months ago?
  9. If you are using a real GMRS radio you dont need to hassle with the offset, just switch to the correct repeater channel - IF the repeater truly does not require a tone, then thats all you need. My guess is that it does need a tone, but it's just not there for whatever reason.
  10. I am hearing it with my Baofeng UV-5R, My Motorola XTS5000, and my XTL5000.
  11. are your two radios at least 50 feet apart from each other when testing?
  12. Where are you located? I've noticed this on Channel 17 for the last month or two, almost everywhere I go when I'm off-roading and at my house. This means I am hearing it over an area that is thousands of square miles of southern California - even when i'm deep in canyons where there is no line of site to anything. I am starting to think it is sunspots or aliens.
  13. Because they all have a better signal/are closer to the repeater than you, and you have an HT with a small antenna/are further away/have more stuff between you and the repeater. The best thing you can do is connect to a bigger/better/external antenna or get closer to the repeater. A mag mount stuck to a cookie-sheet placed up high/near a window can work great.
  14. You're my best friend now.
  15. You could be doing any one of a-bazillion things wrong. But i'll start with these questions: What kind of antenna is the repeater connected to and is it tuned to the frequency you are using? What kind, and how long is the coax? are you using the specific frequencies on the repeater that the internal duplexer is tuned for?
  16. I think i like you, can we be friends?
  17. Your feelings do not matter. I have setup in the neighborhood of 30 repeaters from the listing here, and 100% of them had all the information I needed to use them. If you are not able to figure out how to use a repeater listed here, then you are doing it wrong. and no, those details will not benefit the community at all because they are irrelevant, or in the case of tones, all the info is already there.
  18. If you abide by #2 and #3 on my list, you dont need to worry about any of that.
  19. Its very easy: Read manual Identify what Repeater channel your local repeater is on Change radio to the correct repeater channel Enter the correct TX (transmit) CTC or DTC tone for the repeater and save (for questions, refer to item #1) do not concern yourself with the RX/Receive tone until you level-up to "I know what I'm doing now" Hold radio near your noise output hole, & push the talk trigger and talk, then take your finger off the trigger Hold radio near your noise input hole and wait for everyone to congratulate you on a job well-done
  20. The hole is only for electricities, not bits or bytes.
  21. I have never done any such thing against just any/all H.A.M. operators - and if you are not capable of understanding who I actually do that to (basically as @Sshannon specified), then you are exactly who I, and everyone else, makes fun of, and rightfully so.
  22. This... The antenna that comes with the 9R is tuned for GMRS because it is a GMRS radio, and IIRC, it does not receive VHF (NOAA) frequencies very well.
  23. Does not sound common at all to me, based on actually having and using several of these repeaters. Is the duplexer tuned for the frequencies you are using? Is your antenna tuned for those frequencies and have you checked the SWR of the antenna with the cable attached? Are all the radios IN the heavily wooded valley or are you trying to test with no line of sight?
  24. Then you probably should have said that, especially since the OP is a self-confessed n00b and prone to confuckulation and at a very impressionable stage in his radio career.
  25. If the repeater cant hear you then how can you kerchunk it?
