281
So far the vote is roughly 790 NAY to 30 YAY. StinkFinger OUT, over <beep>
Software (other than CHIRP) to reprogram a Wouxun KG-905G
OffRoaderX replied to Reclusiarch's question in Technical Discussion
That Youtube guy is just a shill for Chinese radio manufacturers and has been copying me since day-1.. I assume you are actually running the software in the correct computability mode? If not, you should do that. -
Assuming you are using the same cable that worked with CHIRP and your Baofengs, then either you have the wrong software or you have a Windows/port/driver issue. I would try to reboot everything, then go directly into the Wouxun software, ensure you have the right port selected and try again. If no joy, try each different port.. If still no joy exit out and do a RUN AS Administrator for the program and try again. If still no joy, Uninstall the Wouxun software, then RE-Install, but RUN AS Administrator when you run the installation .. If STILL no joy, do anything else suggested in this thread between now and Tuesday.. If still no joy, contact BuyTwoWayRadio support on Tuesday and they can walk you through everything possible. -
it would seem that HF maybe with one or two relay-people or repeaters would be a better, more reliable solution because you will generally get much greater range with HF than with GMRS. and good luck getting any GMRS signals over the rockies and all other mountain ranges between New York and California.
What would have to happen for GMRS to include APRS?
OffRoaderX replied to fremont's question in Technical Discussion
Watch out for those GMRS influencers.. I have heard that they are all bought & paid-for, and are nothing more than puppets for all of the CCR, commie, cheap-Chinese radio manufactures and they only say what their commie slave-masters tell them to say. I know this must be true because 100% of "some people" that claim this all memorized a 35-question multiple-choice test. -
Trouble programing 654DPL CTS/DCS into my Radioddity DB20-G
OffRoaderX replied to knowinowen's question in Technical Discussion
Yes.. "N" means "Normal", "i" means inverted. 99.8% of GMRS repeaters use a "Normal" DCS/DPL/DTC tone. -
Programing a Repeater into Baofeng GM-15 Pro
OffRoaderX replied to WRXR606's question in Technical Discussion
On GMRS there is always a +5Mhz split from the RX frequency, or if you are left-handed a -5Mhz split from the TX frequency.. so RX is always 462, TX is always 467. -
This.. 1.9:1 is fine and more than plenty good enough for normal people using their radio for normal things. Stop overthinking it and just use/enjoy your radio.
It is my understanding (which is open to correction by others) that your SWR affects your transmission far greater than reception. But I am unclear if the correct word is affects or effects..
How to attract more young people into the Amateur Radio Hobby
OffRoaderX replied to WRUE951's topic in General Discussion
Winner!! I would also throw-in listening to/talking to the ISS. -
I dont think that 1db is going to make the difference, but it could be one of multiple weak links like cable length/quality, connectors, radio sensitivity, and any of 2-gazillion other variables.
PS: it does not HAVE TO BE the internet. You could also use your own private leased-line type connection, but that is much costly.
The only way to do this and not break any of the GMRS rules would be to link them over the internet. Not sure of the overall cost, but not a trivial task. I'm sure others can chime in with more details.
Cheap, low quality cable - too many of the RF electricities fall out and dont make it to the antenna.
How can I make my repeater allow APPROVED unit IDs only?
OffRoaderX replied to WRYF747's question in Technical Discussion
I am not aware of any repeaters that do this, but the functionality may exist (others can chime in) but even if using a Unit-ID (ANI/DTMF), anyone could very easy spoof it and use the repeater.. There is no way that I am aware of on GMRS, without breaking the GMRS rules, to fully prevent people from using a GMRS repeater. -
Hopefully @rdunajewski can fix it.
Not a mobile, its an HT, but the Wouxun's KG-Q10G is a GMRS radio that also receives CB.. So far, as of today the only one on the market.
Simplex on private repeater output w/ tone
OffRoaderX replied to UncleYoda's topic in General Discussion
Violate any protocol? NO Upset the repeater owners? Maybe, but that does not matter.. Just don't intentionally be a dickhead. -
Official/Unofficial GMRS Road/Travel Channel
OffRoaderX replied to DanW's topic in General Discussion
are they/you guys in a noisy area? Where we go there is usually zero radio traffic other than the few other off-roaders nearby.- 91 replies
- highway
- interstate
(and 2 more)
Tagged with:
I do a bit of off-roading and I dont know of any other off-readers that run any tones, unless/except when in some kind of large event. Many that I know, myself included not only do not run any tones, but also scan all frequencies in case someone is calling for help.- 91 replies
- highway
- interstate
(and 2 more)
Tagged with:
Dont mess with it - 2.02:1 is plenty good enough.
It sounds like its tuned just fine, and I wouldn't mess with it .. But how you actually tune it depends on what kind of antenna it is.
New GMRS user, looking for others in my area.
OffRoaderX replied to Puzzles's topic in General Discussion
Stating the fact that there are not droves of GMRS users across the country staring at their radios every-night waiting to chit-chat with strangers is not dissuading anyone from doing anything. Its simply stating a fact. If this makes you sad, I have just the cure to ease your pain and itching. -
Yes, but I am using Windows 11 on ARM, so it might not be the same.
Oh, this should be fun...
