281
75Feet of LMR400 from my VXR7000 gets me ~50 miles of farz, so I'd say LMR400 works just fine - Not "The best", but good enough for most normal people with low-power, non commercial installations.
What happens when you connect another radio up to the same coax and antenna and transmit?
I've hit repeaters 70 miles away and talked with HTs 25 miles away using a 25W radio and one of those small 3db antennas. But if you still cant hit any of the repeaters then be a pillar of the community and put one up!
There are many "771" antennas out there and I assume they all come from the same chinese child-slave-labor hut and just get different stickers. I have tested several (maybe all) of them, and have never noticed any difference in reception that my ear could pick up, and only small differences in improved transmission farz compared to stock GMRS antennas. The only time I've ever noticed 'real' difference was when comparing it to a UV-5R antenna which is not well-tuned for GMRS, and even then, the differences were not huge.
In case you werent aware - anyone that runs into me while off-roading (IN the dirt, not on the streets!) gets a free GMRS radio! (while supplies last). Just find me most saturdays anywhere between Anza Borrego and Randsburg, and unless I've already given away that days radio(s), you'll get one (IF you need one)
That is the GMRS version so your life is going to be a lot easier getting repeaters set up. To set up the Inland Empire "Ranchino" repeater, start on Repeater 17/Channel 25 and enter the DTC TX tone 023. For a pro, this should take about 15 seconds to set up right on the keypad, no computer or cables needed.. For your first time, set aside at least an hour.
I WISH my callsign was that pretty! He should be thanking Xenu for what the FCCs hath blessed upon him.
On the GMRS-9R, like every other GMRS radio, the offsets are programmed - so all you need to do is pick the correct repeater channel and set your tones.
Offsite repeater location considerations
OffRoaderX replied to fremont's question in Technical Discussion
I dunno - i bought mine gently-used for about $500. -
You might also consider a repeater that has a high-temperate rating. My VXR-7000 is rated to operate at up to something like 160F (if i am recalling correctly). The thing is nearly bullet-proof..
