64
Everything posted by gortex2
Line A is an imaginary line the FCC defined that you cannot operate GMRS above. Its stated on your license that certain channels cannot be used above it. https://wireless.fcc.gov/uls/index.htm?job=line_a_c The Line A and Line C Program determines whether an entered coordinate is SOUTH of Line A or WEST of Line C. Line A is an imaginary line within the US, approximately paralleling the US-Canadian border. To the north of Line A, FCC coordination with Canadian authorities is generally required in the assignment of frequencies.
Got a cheap surplus APX radio, is it okay to use for GMRS?
gortex2 replied to Moui's topic in General Discussion
Correct per the flash UHF/VHF. Both Analog and Digital P25 is supported. Appears to be a great starter radio. Get the MSI battery and antenna and you wont be disappointed. Biggest issue will be the software. You need to open an account with Motorola and then purchase. Cables can be had in aftermarket although the MSI cable isn't expensive. 806: ASTRO IMBE Digital Operation QA00571: Primary Band: UHF Range 1 QA00574: Secondary Band: VHF QA00579: Enable Dual Band Operation QA00583: Enable Bluetooth Operation QA01749: Legacy SW System Key Enable Q947: APCO Packet Data Interface -
gortex2 replied to w4thm's topic in General Discussion
So we are focusing on something that rarely happens and there is no real rule out there to tell us which way to go. Sadly we spend more time talking about non compliant CCR radios and every other topic on this forum than true GMRS chat. There used to be a few good guys on here that were not only knowledgeable but involved heavily in GMRS as well as other services. On a similar topic our threads appear to drift off topic alot.... Done ranting. I'll go play on P25 LMR now... -
I guess just don't get it. 99% of the GMRS use for me is my friends and family. If someone calls me and I don't know them I most likely wont answer them. Its not that Im rude but that's what I have GMRS for. If i'm on 2M and some calls on 520 its my option to answer or not. A road channel implies a channel folks will listen to and monitor. When im on the highway my radio is in scan. With that said I have PL on all my channels because i don't want to listen to others. CB was the same for years. The only defined channel was 9 for emergencies back in the 70's. 19 was kinda the trucker channel and 4 was the jeep channel. What is the intended goal ? If I'm on a jeep ride they give us a channel to monitor. If I'm home I monitor my repeaters. To me some just feel GMRS needs more than it was intended for. While some are avid GMRS users with multiple repeaters, many are using it for a 1/4 mile to talk to a car behind them and most likely have no license anyway.
I'll jump on this topic against better judgement. If someone gets on my repeater without permission and is stupid its on them. If i gave them permission i take responsibility. There is no keeping idiots off a repeater if they want to no matter what we do. Just take it with a grain of salt. Back to reqular programming. -
This comes up often. there is not one and no need for one. This isn't ham radio.
The APX is the top of the line radio from Motorola and many use it on GMRS and Amateur as well as public safety. It can be flashed many ways. -
No wideband key needed for APX line. -
OK. Many opinions on this but here is the info on the APX line. You first need to know the model number of the APX7000. That radio came in multiple flavors of dual band and single band. UHF/VHF and 700/800. The flashcode can give you some info. I use my APX on GMRS and it works great. (APX7000, 8000, 7500, 8500). CPS is going to be expensive as it needs purchased from MSI directly. There is no wideband entitlement as some claim as the software allows wideband on the frequencies and bands approved for wideband. Yes the radio can do P25 if so flashed for that option. Our first APX7000 for SAR wave VHF Analog only. The best option is to get the flash code looked at. Start with whats listed on the radio. IF you have no battery you are not 100% knowing whats in the radio but the label can help. If its 800/VHF it wont do much on GMRS. Feel free to PM me if you have more questions on the APX. -
gortex2 replied to Lscott's topic in Multi-Use Radio Service (MURS)
My 1 watt HT1000 talks further than a FRS radio time and tome again. Love to have 5 watts to use but for what I use it for 1 watt is perfect. -
I agree. Had a license for many years, before I even got ham. I use GMRS more than ham also. I remember my father having a CB license and when I got my first CB there was no license at that point. Now its a mess. Sadly GMRS is a mess in some areas already. Another topic for anther day. Just happy JJ finally put it in writing for folks.
Radio shielding when close to an antenna?
gortex2 replied to Riktar's question in Technical Discussion
I would not install the radio that close. If your using 30' of cable you are not loosing that muck unless its twin lead wire. Any RG/LMR will be fine on that short of a distance. I dont see where you would gain much if not anything by moving it in the attic with the antenna. -
Saw this in a registration package today. Was happy they are talking about it this year. Last year they just said get a radio. This year it does say a license is required. See if it affects anything. Last year at one of the events I asked a guide who said he had no license. I tried to explain the rules to him but that not something we can fix anytime soon. Sadly the more popular GMRS becomes I see license' going away just like CB.
Being neither has a true ground plane it may be worth adding a ground plane vs moving them. Maybe its just the picture but i see no ground planes on either antenna. Those are both mobile antenna's so without a ground plane are both not going to do much.
Fun topic - SHTF communications plans and equipment?
gortex2 replied to Lscott's topic in Miscellaneous Topics
I guess it really depends on the area. Most of the areas I work in the RACES/ARES groups get limited funds from the county. Instead of using it to get good equipment they prefer cheap with quantity. When the hardline connector cost more than the antenna on the end of the 1 5/8" hardline you should question your goal. JMHO. -
I just had this conversation with a EOC director about the amount of CCR junk in boxes. He stated thats what the ham guys wanted. The county spent alot of money on hardline and installs for the ham club to order and request a $60 antenna on the top of the tower. Its sad that hams are that cheap and they wonder why more and more they are shoved out of any large incident. Sorry your CCR isn't going to work better than my APX8000 in an emergency.... -
Radios is only a 15 watt radio. really no need to go to the battery, but if you do just cut off the plug, ground near radio inside and run a larger wire to a fused battery. 3 watts wont change alot to be honest. Id focus on a real antenna first.
Never used one. Never plan to. No rule to have an ID'r on the repeater but if mine has a factory ID I use it.
Everything listed can be done from the front of the radio. To me its all Ham garbage. But to each there own. I'll stick to my APX and XTL base radios.
No reason for a desk mic to have any button other than PTT and Monitor. As stated if you can find the pinout you can use about any desk mic as long as the mic element matches.
Midland MXT575 & MXT500 on Midland website now!
gortex2 replied to mrweller's topic in General Discussion
Does no one read any of the rules ? Those frequencies are only allowed in a portable radio and not mobile. Why would midland add them as receive only ? It would jsut confuse 99% of the market. Why would you think they are "censoring" the radio ? they are following the rules. Love them or hate them Midland has a huge market in GMRS. They sell an out of the box simple devise. I would bet 95% of the Midland users never uses repeaters and if the do use one repeater. The issue is more licensing in my opinion. over 3/4 of the Jeep guys I talked to at the last Jeep Jamboree had no license but had the Midland radio (Many 275). While its required many people just buy what they perceive as needed. Midland will continue to sell GMRS radios. While many don't like them they are ideal for simple GMRS users. -
What Jeep do you have ? On my JK I run the rugged ridge mount on the front left cowl. On my JT I used the Mopar Pillar light mount.
No. Just leave the cable.
Building a 300' VS 500' free standing radio tower. Advise needed?
gortex2 replied to JB007Rules's topic in General Discussion
Valmont Structures As far as towers, the civil work is just as crucial as the actual tower. Most towers will want environmental studies done ahead of time also to determine the condition of the soil which in turn will tell what the foundations need. Both a 300 & 500 is going to require caissons. Grounding, electrical and local permits is another thing you need to verify.
