I have run a 890 (actually 690, 790 and 890) in my old truck when I was in NY for SAR work. They were great radios. All of mine were remote head. Rock solid. I probably would still use them but we switched to MDC identifiers for SAR and didn't want to cobble encoders in them. At one point my 690/890 was dual deck single head.
See the thread above. While you can put up a cheap repeater if you want one that will get used and works well you need to spend some coin. Lots of info in the link above.
This was mentioned in the pst by other members. You pay for quality. Thats the biggest thing that leave members leaving GMRS. If you want quality service dont spend $20 on radios
Its really about antenna and line as has already mentioned. Power isn't necessarily the factor. If your only talking to the repeater on a 4 watt HT having a 50 watt repeater wont make it work better. In the LMR world we would "balance" repeaters all the time to get them close.
Also as said above. Take a portable and hook it to your antenna system. If it doesn't work a repeater wont help.
Rich when i try to login i get the same question again telling me it needs a username and wont let me use my current one. Only way past was to add a 2 again. If you merged the accounts I dont care at this point.
This is for Rich I guess. When i logged in it made me change my profile name. I just added a "2" to my current name. Would not allow me to re-use my name. Thoughts ?
Agree. Id be worried how far from center I'd go. I normally tune my flatpack style ones dead center of GMRS band so it can go up or down a channel or 2. Much more it does show issues the further away from center.
Also remember there is loss thru a duplexer. Cheaper the duplexer the more loss. Depending on how it was tuned I have had them come in the shop with almost 3 db of loss. That's half your power. The only true way to know is to have your duplexer swept and see what the loss is on it. If its got high loss or off frequency that can cause the PA to heat up and drop power. Quick way to test is to drop the radio to low power and see if it does same thing,. As other said you dont want to run any 1225 on high power if you want it to last. I've replaced hundreds of PA's over the years. All my GR1225 run at 25 watts max. My low power units go into TPL amps.
As said I'd try to find the HHCH for the radio. If not there is a company that makes a console face plate for your center console. I just did one in a 2019 Denali for my buddy. Holds 2 radios.
You would have better luck with a 1/4 wave on the mount than that antenna. Inside is litterly a circuit board with a brass strip. Its about as good as a rubber duck.
When in the Jeeps simplex. When around one of my repeaters we use the repeater for range. Its mostly to talk to family or friends, not a chat line. If I wanted to listen to that I'd turn a ham radio on.
They used to sell a Mini-UHF to SO239 jumper cable. I suggest finding one of them vs an adapter. Used hundreds of them in my shop days for control station installs.
Depending on what the height of the camper is you may be better off with a small fiberglass antenna on the ladder. Thats what I run at camp (on my repeater) and it works really well. For the most part there is no metal in the camper roof. Even where the AM FM antenna is its just plywood with a ground wire on the cable. I run the Laird FG4500 and it works great. I have LMR400 run up the ladder and under the RV to the compartment with the repeater. When installed its actually a bit lower than my vent covers but i still remove depending on where I plan to drive.
