Landshark
    Bob
    SoCal
  • Interests
    many
680 profile views
Landshark's Achievements
  1. Thanks, good to know it was not just me
  2. I am curious what would cause a GRMS channel to push out signal that just sounds like the squelch control is turned off, for the last week or so here in LA, Ca channel 22 sounds that way, I first thought maybe I had done something with my KG1000 but I checked with one of my handhelds it was doing the same thing. In the past there had been some obnoxious users on 22 so I wondered could this be the local repeater owner causing this to discourage the use of the channel or is some weird going on here
  3. KG1000G in Jeep
    KG-XS20G in RV
    KG 805, KG905, GGUV9G HTs
  4. It is to tell the difference between the pro and lite, besides the roger beep,the lite will only transmit at med power on the lower channels 1-7
  5. Just got mine yesterday, checked out at 21.5 watts transmiting, installed in the Rv replacing the handheld I was using there, so far so good, looking forward to using it as mobile base station out in the wilds, talking to the KG1000g in the Jeep or one of the handhelds being used on a hike by people in the family when camping, Since first posting this I have cleaned up the wiring with split wire loom tubing
  6. Thanks, The mic speaker is loud enough that I can turn it down and be fine, I got a ball mount form I am not ure where at the moment that replaces one of the screws for the passenger grab rail, then a 67 Design CF arm, then the face plate is mount to a 67 Design SwitchPro SP9100 Switch Panel that I modified with some new holes and bolts
  7. I installed the base radio under the driver's seat and face plate on a 67 design cf arm attached to a ball mount that installed in the passenger grab rail, running the cable to the face plate would have been cleaner with the base unit under the passenger seat but i could do that because my ARB compressor is already in that space. I hung the mike from another 67 Design arm that is using JeepUniq mic mount and also put a lido mic mount on the drivers side freedom panel so it could be closer to my head when it was really loud in the jeep. In order to mount the face plate i modified a 67 Design SwitchPro-SP9100 Switch Panel Holder. Overall very happy with how it all turned out, The mic speaker volume is loud enough but I like have both speakers on
  8. I am using the Nagoya NL-770G High Gain Mobile GMRS Antenna on a magnetic mount that i attached to a Rhno Rack rotopax mount on the Rhino Pioneer roof rack on my Jeep, works very well
  9. I had one of their BK burritos last week, curious if the problems your are having are just that radio or is it a problem all around. I want to get one for the rv instead of using the HT. I have a KG-1000G in the Jeep, which i like but did not want to go with that much radio for the less used rv
  10. In my Jeep I mounted the radio under the driver seat and the front control panel is mounted on an arm attached to the passenger grab handle
  11. I enjoy Randy's reviews on his channel
  12. Jeepuniq has a number of 3d printed HT mounts, mostly for jeep but they do have a ball attachment that will work with 67 Design stuff or others https://jeepuniq.com/?gclid=Cj0KCQjw_dWGBhDAARIsAMcYuJzstGnZEu1p9cqsurBct7gxbuXvRHBcYogvOlMMSwLKdzVETxuAxOkaAh7cEALw_wcB
  13. Channel 22 has sadly become pretty obnoxious
  14. if it is the pro version it will not let you turn on the roger beep only the lite version will
  15. Just got one today for the wife, great little radio, smaller and lighter than the 905G, but the funny thing is out of the three different Wouxun radios i have the 805G, 905G and KG-UV9G it has the largest charger, all three share the same ac adapter but the tray on the 805G is the largest
