PastorGary
180
Everything posted by PastorGary
The Staff here at the Forum has no access to the software running the main site. Please hit the Contact button at the main site to advise Rich of the situation. Thanks...
Do you have a 60 to 80 foot windmill tower on your property? Those work well - especially if the actual windmill blades and water pump rod is deactivated. Just use extreme caution while doing ANY tower work.
199.9 feet unless you are within an FAA flight pattern for a local airport. See 47 CFR 95.317 for details and current restrictions. https://www.ecfr.gov/cgi-bin/text-idx?SID=72b61b708f0ce25ea78b21b0aed4e95b&node=47:5.0.1.1.5&rgn=div5
General Etiquette when using a repeater
PastorGary replied to orionarms82's topic in General Discussion
§95.1751 GMRS station identification. Each GMRS station must be identified by transmission of its FCC-assigned call sign at the end of transmissions and at periodic intervals during transmissions except as provided in paragraph © of this section. A unit number may be included after the call sign in the identification. (a ) The GMRS station call sign must be transmitted: (1 ) Following a single transmission or a series of transmissions; and, (2 ) After 15 minutes and at least once every 15 minutes thereafter during a series of transmissions lasting more than 15 minutes. (b ) The call sign must be transmitted using voice in the English language or international Morse code telegraphy using an audible tone. (c ) Any GMRS repeater station is not required to transmit station identification if: (1 ) It retransmits only communications from GMRS stations operating under authority of the individual license under which it operates; and, (2 ) The GMRS stations whose communications are retransmitted are properly identified in accordance with this section. ================================================================================ *** Repeaters do not need automatic owner license ID - IF users of the repeater identify themselves as stated in section (a ) above. *** -
Do repeaters have to be part 95 accepted
PastorGary replied to Elkhunter521's question in Technical Discussion
If anyone has verifiable official documentation that ANY GMRS licensee has ever been given an FCC citation for using a Part 90 Type Certified "transmitter" in Part 95 service, please add that documentation to this thread. -
Has anyone here tried either the MFJ-874 OR the Diamond SX600 HF, VHF, UHF meters?
Staff moved the post to the MISC. area where other sales related items are located.
Very nice decision and I'm sure that it will be greatly appreciated... (until the new owner tries to program it...LOL... )
Just a reminder for some of our new members - Forum participation on or near US holidays is always less than at most other times. Please be patient for member replies at holiday time at the MyGMRS Forum. Thanks and have a safe and enjoyable holiday weekend.. MyGMRS Staff -
Refer to 95.1705 of the Rules, Section C -2 : "Any individual who holds an individual license may allow his or her immediate family members to operate his or her GMRS station or stations. Immediate family members are the licensee's spouse, children, grandchildren, stepchildren, parents, grandparents, stepparents, brothers, sisters, aunts, uncles, nieces, nephews, and in-laws." They do NOT have to reside in the same household.
John has a good offer there - In case anyone ever needs one and John is out of stock, there are several varieties available from EBay, Tessco and others... https://www.ebay.com/sch/i.html?_nkw=nmo+cover https://www.tessco.com/products/displayProductInfo.do?sku=85487
Let's add another possibility to the discussion... Stainless steel "L" brackets for NMO mounts - I have used these for 40 + years and never had an issue.
Using a properly mounted NMO places the antenna over a ground plane surface at a proper resonant distance and has a DC ground. If a mag mount is used, the bottom of the antenna itself is above the ground plane surface by at least an inch and the resonant length of the antenna may be off. It also has no DC ground connected to the vehicle body at that point because of paint layers, etc. From personal experience - If an NMO body mounted antenna is cut to a resonant length for lowest possible SWR, and that same cut antenna is then placed on a mag mount, the SWR will be a bit higher. If the antenna on a mag mount is then re-cut to compensate for the additional height of the mag mount above the vehicle body, the antenna will then be non resonant if placed back on a body mount NMO. I have also found that most (but not all) NMO mag mounts have factory supplied coaxial cable and PL259 that are somewhat inferior to what might be used with an NMO body mount from a frequency sensitive and loss per foot aspect.
While the Kenwood TKR820 is not antique, it is getting on in years. Had one in the 90's on 462.575/467.575 at 185 feet using a 10 db omni. Solid 42 miles with an 18 watt output. Still wish that I had it and the programmer to change the chipset. Anyone still using one of these? Image supplied by Ebay... http://img0031.psstatic.com/111563782_kenwood-tkr-820-uhf-repeater-ebay.jpg
While it is not specifically covered in Part 95 Subpart E, you may wish to refer to the blanket specifications for all Part 95 Personal Radio Services found in Subpart A: §95.339 Operation of transmitter with external device causing rule violation prohibited.No person shall operate any Personal Radio Service transmitter to which an external device or accessory has been added such that operation of the combination results in a violation of the rules. [if a Part 90 amp is used with a Part 95 transmitter, that may be an implied Rule violation because the amp is not Type Certified specifically for Part 95 use and would not show up on the approved equipment listings.] As always, it is the responsibility of all licensed operators to follow the letter and spirit of the law. If a question arises about Rules interpretation, call 1-888-225-5322 and ask to speak with a ULS Help Desk Agent.
Dan - Please log in to the main MyGMRS repeater listing site and direct an inquiry to Rich by using the "Contact" button. The forum staff has no access to the software that runs the main site. Main Site: https://www.mygmrs.com/
April 19, 2018: Worker killed in Missouri TV Tower Collapse
PastorGary replied to PastorGary's topic in Miscellaneous Topics
A colleague at a broadcast station in Mississippi mentioned to me that their upgrade was completed a couple weeks ago on their 2000 foot tower, by a crew that had three persons killed during an upgrade in Florida in September of 2017. https://www.broadcastingcable.com/news/three-tall-tower-workers-killed-florida-168970 -
Thanks for the news. It may be awhile for all the services to be restored - in some manner. -
If anyone has additional news of any communications that may have been affected by this incident, please log your observations here. (Amateur, business, public safety, GMRS, cell systems, microwave interlink, etc.) The PBS tower was just under 2000 feet high, so it may not be the same '1000 foot commercial broadcast tower' as listed in the data supplied above. Confirmation from local sources would be appreciated regarding interruption of any communication services. -
Thanks for verifying the analysis details.
That can mean that the system that you are inquiring about is no longer in service, changed owners OR the email address of the owner has changed. The DATA UPDATING in our main listing website is the responsibility of the owner to keep current. Old or out dated information may exist, but MyGMRS takes no responsibility for the lack of accuracy in any listing at the main website.
Using a Laird 460-470 5.0 db omni base antenna and 1/2 inch Andrew Hardline for nearly a decade. No issues ever. https://www.theantennafarm.com/catalog/laird-technologies-fg4605-8029
Since no one on the MyGMRS staff is an attorney, this reply is solely based upon FCC wording and common interpretation in Part 95 Section 1705. ___________________________________________________________________________________________________________________ Subpart ( a)( 2): " Any person that holds a valid individual license is eligible to obtain a renewed license, or a modified license to reflect a change of name or address. If the original license holder is deceased, he or she is no longer eligible to renew or modify. Subpart (b ): "Individual licensee responsibility. The holder of an individual license to operate GMRS stations is responsible at all times for the proper operation of the stations in compliance with all applicable rules in this part. If the individual license holder is deceased, he or she can no longer be "responsible at all times for the proper operation or compliance." Therefore, under the wording in Section 1705 as listed above, and other applicable licensee responsibilities that can not be fulfilled if the original licensee is deceased, the license most likely becomes void upon the licensee's passing and another family member would have to apply for an FRN as well as a NEW license and allow family members to operate under that NEW license. The FCC ULS Office can be reached initially by calling 1-888-CALL-FCC and then asking for the ULS Information Desk. Discuss the situation with the agent and they will be able to give information about proper FCC procedures in this case.
