43
Everything posted by WRUU653
Reception on GMRS is line of sight. Check out this tool, it may help you with expectations. Trees, buildings, even moisture can impact your signal.
I started answering unknown calls with "this call may be recorded for quality assurance". They always hang up after that.
@GeauxGreddy greatest presentation of a question ever For what it's worth I like em wide...
Does the Raspberry Pi 4 work well with the ASL image?
WRUU653 replied to wrjf803's question in Technical Discussion
John did you notice @SteveShannon mentioned that Bakersfield recently had an outage?
As previously mentioned there is no official national channel/frequency for GMRS emergencies. Some areas have repeaters set up on GMRS for locals in case of flooding, fires and other things that may be common concerns in their particular areas. I have seen some like the one at Oroville that have time restrictions and split tones so residents can monitor through the night in case of a dam flood. Check with your local ARES group to see if they have adopted anything where you are. Our Emergency Communications Council has adopted 462.675 as “Emergency communications and traveler assistance in the General Mobile Radio Service (GMRS).”
I’m near the coast where it seems to be constant so I had not considered this. Thanks @back4more70and @SteveShannon.
If you are using software always save a copy before you start making changes so you can go back if needed. I’m tapping out for the night. It’s been a long one. Let us know if you succeed and think about joining the forum. Good luck
I don’t know. The fact that you picked it up once indicates you should be able to get there again. Assuming you are at the same location probably not the antenna. Any chance you changed the frequencies that were programmed by accident or put a tone on them? Probably not the station itself being down as you can get it on your HT. Assuming you’re receiving other signals I would verify frequencies for NOAA are correct as @WRXP381 suggested.
No you’re correct. Have you tried just tuning to the stations rather than using scanning. If the station isn’t strong I wonder if your squelch setting isn’t running right by it.
How’s the ground plane? Is it possible the vehicle is blocking reception from how it’s sitting. I’m just throwing darts here
I think I have seen radios come programmed with the NOAA stations in a different order. So potentially not having the same numbers from one radio to another. Just a thought but have you tried all the NOAA channels?
Yeah I hear you but I gotta figure something is making the Ht work better and the location of a NOAA station and you receiving it definitely can be affected by the antenna. I can pick up two stations where I am with a good dual antenna but only one that isn’t. Also if he can program an HT he probably can program his mobile.
I believe that antenna is uhf only. Your Ht likely has a dual band antenna.
Ahh yes, I had one of those kits as a kid… Great story! I have a clear picture of what that would have looked like with my dad.
I fellow who coined "FARS" has put down his Kenword radio.
WRUU653 replied to StillA0's topic in General Discussion
You may have missed the real joke here… but it’s okay. It wasn’t meant maliciously. -
You are not fat. -
If I remember correctly the default used to be “my repeaters” equaled owned repeaters and this is a change Rich made to try and make it more clear from how it used to be. Seems pretty clear now so who knows why people do what they do.
FRS radio recomendations for my non GMRS friends
WRUU653 replied to TrikeRadio's question in Technical Discussion
Interesting, who knew they made a superheterodyne FRS?! I don’t have any of those… must resist @TrikeRadio I have used Motorola talkabouts myself for cycling. I saw these Retevis RA55 and the ability to clip to a camelback and noise reduction feature might be nice in the wind, usb-c charging too. I have no personal experience with them though. Cheap enough to try out. -
I have also found sending Rich a message from the contact page has worked as well for me. I did this once for a friend’s repeater that had a bogus listing. He took care of it no problem. More often than not it’s done mistakenly. One person came here after they tried to save it as a favorite but noticed this happened and then didn’t know how to fix it. I try not to think the worst of people when it comes to this because it’s so prevalent. I feel one extra layer of safeguard would be beneficial, like a pop up that says “are you sure you want to upload this repeater as one you own” or something like that before it post. I don’t know something.
is there any set channel for hiway use?
WRUU653 replied to Deerstalker's topic in General Discussion
The difference is in this thread he isn’t referring to Off Road. The question was about a highway channel. Or as stated Hi way. Which I like to think is a pun for the intended communications. -
This has happend so may times it has become ridiculous.
Troubling story, I hope they find this guy soon.
WRUU653 replied to WRQC527's topic in General Discussion
After so many days… that is something! Nice to have a good news story! -
The Future of Linked Repeaters??? Must Watch!
WRUU653 replied to marcspaz's topic in FCC Rules Discussion
Thanks for sharing. That sounds like it was a completely thankless task. -
@numnutz6383, Okay I gave this a shot in Chirp. I changed the frequency limit to 485.000 on UHF RX, uploaded to the radio and I can now set the radio with a RX of 484.4000. Of course this is RX only. Give it a shot and see if you pick up the station.
