WRXB288 Posted May 4 Report Posted May 4 DELETE DELETE DELETE Docket No: 25-133 https://www.fcc.gov/ecfs/document/10425259046292/1 Interesting comments on adding unused channels to the GMRS license Quote To Reallocate Underutilized or Abandoned ) 47 CFR Part 15 46/49 MHz Cordless Telephone, ) 49 MHz Low Power Walkie-Talkie, and ) 47 CFR Part 22 VHF Low Band Public Mobile ) Radio Services (PMRS) Paging Channels to ) the General Mobile Radio Service (GMRS) ) and Family Radio Service (FRS) Below is a revised chart with channel pairs 16 – 25, rearranged and renumbered as 01 – 10, illustrating such a reallocation to the GMRS. Proposed New 47 § 95.1763(e) & (f) – 46.610 - 49.990 MHz 100-Watt GMRS Allocation Channel Mobile Frequency (MHz)* Base or Mobile Frequency (MHz) 01 46.670 49.830 02 46.710 49.845 03 46.730 49.860 04 46.770 49.875 05 46.830 49.890 06 46.610 49.670 07 46.630 49.770 08 46.870 49.930 09 46.930 49.970 10 46.970 49.990 *These frequencies are for use only as repeater input frequencies This proposed 46.670 – 46.970 MHz & 49.830 – 49.990 MHz reallocation of former cordless telephone frequencies would be assigned to the GMRS as licensed, up to 100-watt, duplex repeater channels These channels were licensed pairs for duplex portable phones and could be used for long range repeaters. They are no longer in use. Quote
OffRoaderX Posted May 4 Report Posted May 4 So you'd need two different radios, or one radio with two different antennas to make use of these and the existing GMRS channels? Does not seem very user-friendly... If they are unused, throw 'em to the H.A.M.s.. they'll use it.. they'll use anything. WRXB215, Ian, dosw and 6 others 4 4 1 Quote
FishinGary Posted May 4 Report Posted May 4 22 minutes ago, OffRoaderX said: So you'd need two different radios, or one radio with two different antennas to make use of these and the existing GMRS channels? Does not seem very user-friendly... If they are unused, throw 'em to the H.A.M.s.. they'll use it.. they'll use anything. Yes, we'll take them. That's down near 6m territory. NCJeb, Raybestos, Jaay and 1 other 3 1 Quote
Radioguy7268 Posted May 4 Report Posted May 4 Before you get too excited about the long range possibilities of a low band repeater, talk to anyone who has actually built one, or tried to use one. Beyond the problems of skip, near-far, and antennas that can double as fishing poles, you also find out that you need to have one antenna tuned for the transmit frequency, and another tuned for receive. Typical bandpass cavities are 5 ft. tall, you will need enough space for at least 6, and you better keep them in a climate controlled environment, unless you want to keep a separate set tuned for each season. You also need to know that a typical low-band mobile antenna is only good for about a 500 KHz spread while your proposed pair is 3 MHz apart. Noise is a huge problem, terrible at times. It's only gotten worse in the last 25 years. There's a reason why Commercial (paying customer) Low-band has become a wasteland. Actually, there's many reasons beyond the ones I've mentioned. Most manufacturers have abandoned the band. GrouserPad and tcp2525 1 1 Quote
WSHH887 Posted May 4 Report Posted May 4 1 hour ago, OffRoaderX said: So you'd need two different radios, or one radio with two different antennas to make use of these and the existing GMRS channels? Does not seem very user-friendly... If they are unused, throw 'em to the H.A.M.s.. they'll use it.. they'll use anything. Using existing radios, yes. But if the frequencies were given over to GMRS I'm pretty sure someone would find a way to make one radio do both. Ian 1 Quote
WRUE951 Posted May 4 Report Posted May 4 Actually, that would be very interesting considering the proposal is asking for 100 watts and repeater use in the 6M area. Can you imagine the 'FARS' people would get. This would open a whole new game.. I like the idea Ian 1 Quote
Jaay Posted May 4 Report Posted May 4 19 hours ago, OffRoaderX said: So you'd need two different radios, or one radio with two different antennas to make use of these and the existing GMRS channels? Does not seem very user-friendly... If they are unused, throw 'em to the H.A.M.s.. they'll use it.. they'll use anything. Thank you !! We'll find a way to make it work ! Quote
Jaay Posted May 4 Report Posted May 4 17 hours ago, Radioguy7268 said: Before you get too excited about the long range possibilities of a low band repeater, talk to anyone who has actually built one, or tried to use one. Beyond the problems of skip, near-far, and antennas that can double as fishing poles, you also find out that you need to have one antenna tuned for the transmit frequency, and another tuned for receive. Typical bandpass cavities are 5 ft. tall, you will need enough space for at least 6, and you better keep them in a climate controlled environment, unless you want to keep a separate set tuned for each season. You also need to know that a typical low-band mobile antenna is only good for about a 500 KHz spread while your proposed pair is 3 MHz apart. Noise is a huge problem, terrible at times. It's only gotten worse in the last 25 years. There's a reason why Commercial (paying customer) Low-band has become a wasteland. Actually, there's many reasons beyond the ones I've mentioned. Most manufacturers have abandoned the band. Yep, we know that. Quote
Jaay Posted May 4 Report Posted May 4 19 hours ago, WRXB288 said: DELETE DELETE DELETE Docket No: 25-133 https://www.fcc.gov/ecfs/document/10425259046292/1 Interesting comments on adding unused channels to the GMRS license These channels were licensed pairs for duplex portable phones and could be used for long range repeaters. They are no longer in use. Actually there ARE still 46/49 Cordless phones still in use, so Not true. WRCR724 and Ian 2 Quote
WRYZ926 Posted May 5 Report Posted May 5 Last time I checked the US military is still using 30 MHz to 70 MHz. I know we used that section all of the time when I was in. Low band was 30-50 MHz and high was 51-70 MHz. And the 6m band is not called the magic band for nothing. 6m is either open or it’s not. And it doesn’t matter if you are using FM AM or SSB. 6m FM won’t get much farther than 2m will Jaay and SteveShannon 2 Quote
WRTC928 Posted May 7 Report Posted May 7 Giving it to GMRS doesn't really solve anything except the question of what to do with it, but it doesn't really make sense to create a new class of license for that band. I suspect that if it were given to GMRS, users would divide up into "VHF GMRS" and "UHF GMRS" folks depending upon their needs or whims. And, of course, the occasional oddball would "need" to have two radios just because. Yes, repeaters would be expensive to build and maintain, but 6m AM simplex would be great for some things, especially with 50-100 watts. A lot of folks who now need a repeater to talk to the spouse unit from office to home could probably just go to 6m simplex. Farms and ranches that now use repeaters might be able to get rid of them. The easiest solution for the FCC would be to set some basic rules, toss it into the GMRS category, and say, "You figure it out. Or don't. Whatever." Ian and Jaay 2 Quote
73blazer Posted May 16 Report Posted May 16 On 5/4/2025 at 4:40 PM, Jaay said: Actually there ARE still 46/49 Cordless phones still in use, so Not true. My parents still use a 49MHz cordless phone system in their house. I never looked at what type is was before until just a couple months ago when we switched them from AT&T's rape job $110/mo landline to a $6/mo VOIP service. My dad just got some new batteries for the handsets last year! SteveShannon and AdmiralCochrane 2 Quote
AdmiralCochrane Posted May 17 Report Posted May 17 I believe I have a set here, but haven't used them in a couple of years Quote
WRUE951 Posted May 17 Report Posted May 17 I live near a military base, we used to listen to military aircraft between 220-400 Mhz. Nothing really exciting, mostly air traffic control stuff and an occasional 'target locked' announcement. I think they use LF as well. Quote
Jaay Posted May 17 Report Posted May 17 22 hours ago, 73blazer said: My parents still use a 49MHz cordless phone system in their house. I never looked at what type is was before until just a couple months ago when we switched them from AT&T's rape job $110/mo landline to a $6/mo VOIP service. My dad just got some new batteries for the handsets last year! I have a old Uniden set that needs batteries so I nosed around on the batteriesamerica.com site and found a set ! They have batteries for quite a few different models in the 46/49 mhz. and 902-928 mhz. range. Quote
73blazer Posted May 17 Report Posted May 17 1 hour ago, Jaay said: I have a old Uniden set that needs batteries so I nosed around on the batteriesamerica.com site and found a set ! They have batteries for quite a few different models in the 46/49 mhz. and 902-928 mhz. range. My dad just took one of the paks into a Batteries Plus and they disassembled it, matched the three main cells with new equivalents, and re-soldered up the connectors on the new cells and re-shrinked wrapped them together and made 3 more for all their handsets on that system. I think they charged him like $11/pak. Jaay and Ian 1 1 Quote
ADVBikerRadioGirl Posted May 22 Report Posted May 22 Oh please people, just relax! Let them give it to us and then we worry about what we do. I am sorry, may be I am the only one with the body of an adult (a sexy one, if you must know, ), but the wonder of a child. They haven’t given them to us and I am already thinking about all the possibilities. Like a child about to get a new toy. Even though, I am sure that the FCC in their infinite wisdom will ruin it but coming up with some crazy restrictive regulations. Our government doesn’t like it when we have too much fun and freedom. Oh well, sometime is better than nothing. SteveShannon, Jaay and Ian 3 Quote
GrouserPad Posted May 23 Report Posted May 23 13 hours ago, ADVBikerRadioGirl said: Oh please people, just relax! Let them give it to us and then we worry about what we do. I am sorry, may be I am the only one with the body of an adult (a sexy one, if you must know, ), but the wonder of a child. They haven’t given them to us and I am already thinking about all the possibilities. Like a child about to get a new toy. Even though, I am sure that the FCC in their infinite wisdom will ruin it but coming up with some crazy restrictive regulations. Our government doesn’t like it when we have too much fun and freedom. Oh well, sometime is better than nothing. Fed WRTC928 and Ian 2 Quote
WRQI583 Posted May 25 Report Posted May 25 I had to laugh..................... give these frequencies to the Hams? They will use them? Hams wont even use 6m unless the band opens up and sends their signal halfway across the country. I say, make a long range GMRS band. Regular citizens will put them to better use. I have sat here for quite awhile trying to find digital activity on 6m since voice is always dead. No repeaters, no simplex, nothing. I did manage to make one contact on FT8. The first and only contact since 1996. Since then, I haven't noticed even a fart of activity on 6m. So what makes anyone think Hams will make use of the 46/49 MHz band? Davichko5650 and gortex2 2 Quote
Jaay Posted May 26 Report Posted May 26 8 hours ago, WRQI583 said: I had to laugh..................... give these frequencies to the Hams? They will use them? Hams wont even use 6m unless the band opens up and sends their signal halfway across the country. I say, make a long range GMRS band. Regular citizens will put them to better use. I have sat here for quite awhile trying to find digital activity on 6m since voice is always dead. No repeaters, no simplex, nothing. I did manage to make one contact on FT8. The first and only contact since 1996. Since then, I haven't noticed even a fart of activity on 6m. So what makes anyone think Hams will make use of the 46/49 MHz band? Guess what ?? 6 meters was open yesterday and Today !! I made 11 new contacts on usb , and 4 on fm @ 50 watts ! Seapup, Ian, WRQI583 and 4 others 7 Quote
Jaay Posted May 27 Report Posted May 27 On 5/25/2025 at 11:25 PM, marcspaz said: @Jaay are you working on this with Jack? Jack ?? Huh? Quote
marcspaz Posted May 27 Report Posted May 27 5 hours ago, Jaay said: Jack ?? Huh? I guess not. Jack is the guy who submitted the Petition for Rule Making. Some of your posts lead me to ask the question. Quote
Lscott Posted May 27 Report Posted May 27 The 46/49 MHz issue isn't much different than the Ham 6M band. Having it on an HT is sort of a joke. Unless that antenna is a quarter wave long the radiation efficiency is crap, not considering the size of the ground plane required. Connection to an external antenna is another matter. Even Ham VHF, 2M band, HT radios suffer from reduced efficiency. I see typically quoted rubber duck antenna gains from negative 5 to 6 db. That's because they are far less than a quarter wave, at least 19 inches more or less, and a crummy ground plane. At least the UHF HT antennas are close to the ideal quarter wave and the body of the HT provides much more of an effective ground plane. A really inefficient antenna are those so called "screw driver" types with a huge base loading coil. I told a Ham buddy I'll bet around 80 to 90 percent plus of the transmitter power is wasted in the loading coil on the low bands. Using a 100 watt radio likely around 10 watts might be really radiated. The reason why is the loading coil is located at the feed point, which so happens to be where the antenna current is the highest, and the skin effect of the magnet wire results in enough resistance to waste most of the input power, I^2 x R loss. Yeah, they can match up good when adjusted right, but there is a price to be paid for that. Quote
Blaise Posted May 27 Report Posted May 27 Maybe instead of thinking of this as a "One band can't do both those frequency ranges" *problem*, it should be looked at as a "maybe GMRS should have cross-band repeaters, and maybe they could be used to build networks of repeaters with "not public network" connections..." *opportunity*. Ian and marcspaz 2 Quote
