HOW MANY FARS???
One of the most asked questions about GMRS radios is “How many FARS?”.  How far can it transmit and receive. Unfortunately, the question is someone meaningless as the answer is, “It depends”.  Of the three primary factors, (power, antenna type and height) it is the height of the antenna by far that is the most important. It takes very little power and only the simplest of antennas to reach over 400 miles!
While this topic has been covered before, most OPs make a mistake with the use of the earth's curvature equation. So here goes. Feel free to comment.
The best example I could find on "How many FARS?", is from weather balloons which transmit in the 400 to 406 MHz range with an output power of LESS than 0.5 watts (60 to 250 mW) to a quarter wave ground plane receiving antenna.  With a release point in Santa Cruz CA, the longest reception was ~750 km (466 miles) off the coast of Mexico.
My personal best was 44 miles using a bubble pack Motorola Talkabout T7200 HT putting out 1.5 watts through an integral fixed antenna to a roof mounted J-pole antenna using Radio shack RG58 cable attached to a simplex repeater and a 4 watt HT.
My view is that if you can’t hear with a FRS bubble pack radio in an open air, line of sight condition then there is some form of obstruction between the two radios. I consider that there are three types of obstructions. The first is the curvature of the earth, the second is a solid obstruction such as solid earth from a ridgeline, mountain, etc. to a reinforced concrete wall, and the third is vegetation, wooden structures, glass, human bodies, etc.  The first two types of obstruction are absolute. You are not going to get a radio signal through no matter how much power or antenna type you are using. Only antenna height can solve the solid obstruction problem. It’s the third type of obstruction where antenna type, height and transmit power come into play.
CURVATURE OF EARTH
With an antenna height of 5 ft. above the ground that is flat you can transmit for 2.7 miles before the signal hits the earth from its curvature.  But wait, if the other radio is also 5 ft. about the ground they also can transmit 2.7 miles for a total range of ~ 5 miles.  These are the conditions for the normally stated 5 mile range of GMRS radios. The 7 miles that is sometime stated is a special case of both radios (~ 5 ft. above the surface) being over a body of water which slightly bends the radio signal giving a bit more range. Both cases also require open-air, line of sight conditions with both radios being at the same elevation.
The condition that both radios are at the same elevation, which almost never is true, is why you can’t use these simple calculations for determining radio range from the earth’s curvature.  In one YouTube video on FARS, the second scenario shown was with one radio located in Plankton (Elev. 922 ft) and the second in Melrose (Elev. 856 ft), OH. A distance of 4.6 miles apart. The reason you can’t use the above calculation of 5 miles horizon curvature range is that the town of Melmore is at an elevation that is 66 feet lower than Plankton even though it looks fairly flat.
Not to get too much in to the specifics of the math, I take the difference in elevation (66 ft.) along with the height of the upper antenna (5 ft.) to compute a radio horizon curvature range, or 10.4 miles.  I use this value as an approximation of how close I am to failing the curvature test. Don’t use GPS elevations as their accuracy is only +/- 60 - 100 ft.)
For comparison purposes so one can better understand the importance of antenna height here are the earth curvature ranges for different antenna heights with a flat surface. (No consideration for the second radio antenna height above the ground).  Use these values to help one determine approximate changes in antenna heights to reach the second radio.
5 ft. – 2.7 miles
10 ft. – 3.9 miles
20 ft. – 5.5 miles
30 ft. – 6.7 miles
50 ft. - 8.7 miles
100 ft. – 12 miles
500 ft. - 28 miles
1,000 ft. – 39 miles
5,000 ft. – 87 miles
10,000 ft. – 123 miles
With my personal best I was ~ 4,500 ft. above the second antenna or a curvature range of around 82 miles.
SOLID OBSTRUCTION
Topographic features of the earth (the earth is seldom flat) are more important than the earth’s curvature in determining if you can communicate with another GMRS radio. To determine if you have any geologic solid obstructions you need to be able to construct a topographic/elevation profile using the USGS National Elevation Dataset (NED). You simply draw a line between the two antennas and have the software compute a profile. I use the software TOPO which is no longer available. You can also use Google Earth Pro to perform the same function. This will show you if you have an open-air line of sight or if the ground is going to obstruction the signal.
Here is the profile from my 44 mile test sitting on Bandera Mt. and talking back to my house in Seattle. Easy peasy.
To show you another example I was recently driving around the San Rafael Desert in SW Utah where there is no cell phone coverage.  Computing various profile lines I was able to predetermine that if I set up a simplex repeater on a plateau near an easy access dirt road (the right-side or eastern line) I could communicate back to the hotel in Green River (38 miles away) from pretty much anywhere in the desert and some of the slot canyons in the San Rafael Reef which opened out onto the desert. A worthy undertaking as the soft sand made travelling somewhat sketchy. The profile line to the left (west) showed that the two radios could not communicate.
Here are the results.
This third example shows Google Earth Pro using the towns of Plankton and Melmore, OH. To see if one has any topographic issues simply draw a straight line (or place a straight edge on the computer screen) to see if you will intersect the earth.  In this example the answer is yes, but check the elevation scale (7.5 ft) and by raising the upper antenna (Plankton) up to 15 ft. above the ground will allow you to communicate to the center of Melmore. It’s almost always best to raise the upper antenna for best chance of improved reception. Notice that there are a number of creeks and other low points that one will not be able to communicate into. I tried another profile line to see if one can communicate from the town of Plankton to the nearby #103 Highway.  The answer is there is a low ridgeline (Elev. 935 ft.) that prevents this. By dragging the profile line you can find where the highest point is (the big red arrow). This is the location one would want to put up some form of a repeater if you wanted to extend the range of your radio.
Semi-obstructions
These are the types of obstructions where radio power and antenna type can help extend the range (FARS) of GMRS/UHF radios. Unfortunately, there are no formulas that I know off that will allow you to predetermine how many FARS a radio can transmit/receive under these variable conditions. Just don’t stand between the radio antennas and try to create as clear of a path between them.  I’m sure many people here are much more knowledgeable on this subject than I am. Feel free to add to how many FARS a radio can reach.
20 answers to this question
My repeater antenna sits about 45 AGL from a ground elevation of 2,600 feet.  Mt. Whitney is about 75-80 miles away, line of site.  Last summer i talked with a hiker sitting at Whitney Portals whom was talking off a Baufang UV5R off my repeater.   I've talked to mobiles on Hwy 395 near Lone Pine, about the same distance but not the elevation angle as Mt. Whitney..  I sit in a unique spot where i  sit in a valley and surrounded by long mountain ranges..  Another repeater 12 miles from me sitting at 4,300 feet can talk 200+ miles.  Aside from Antenna height, other factors come into play such as ground elevation and elevation of surrounding areas.   The guy sitting at Whitney Portals said he was at 8,400 feet.
But yet in parts of the country you will be lucky to get 50 miles even when the repeater antenna is at 450 feet above ground. Some areas are lucky to see a 20 mile range with antennas on mountain tops.
Foliage has a big effect on UHF. When one talks about the Appalachians, Smokey Mountains, Ozark mountains, etc, there are no tree lines to get above. There are also no large flat and open areas like out west. And most lakes, outside of the Great Lakes, are smaller and surrounded by forested hills.
Our GMRS repeater antennas are on the same tower as our 2m and 70cm repeaters antennas. The radio tower is on one of the highest points in the immediate area. The GMRS antennas are at 400 ft above ground and the 2m/70cm antennas are at 900 ft above ground.
We only get about a 35 mile radius of coverage from our GMRS and 70cm repeaters with plenty of dead spots due to local terrain and forested areas. The 2m repeater has a 80-95 mile radius of coverage.
And just because radio A can hear radio B doesn't mean that radio B can hear radio A. There are plenty of variables involved.
the only foliage i see is a 3' high tumbleweed  🤣.. In the evenings i can see the glow from the lights coming out of Las Angeles 130 miles south.
We had to use repeaters setup on the top of the Granite Mountains at the National Training Center/Ft Irwin, Ca. Otherwise our hand held radios would not reach the main base. And we still has plenty of dead zones. especially on the northern part of the training are where all of the live fire ranges were. We used commercial radios for the Observer/Controller groups and associated maintenance personnel.
The live fire ranges were on the north side of the Granite Mountains while the rest of the base was south. And there were still plenty of dead spots on the main training area, especially in certain spots in the John Wayne Hills and along the Whale.
My point is that not every spot in the desert is wide open. We definitely did not have to worry about foliage interference. But there was plenty of terrain features that caused issues.
I have made it 460 miles with tropospheric ducting Montgomery, TX to Mobile, AL this was on may15th 2025 on 700. The whole coast line from Texas over to Alabama was white. The majority of the Gulf of America was white hot as well. You can use https://www.dxinfocentre.com/tropo.html to find out if your ever in a good opening and try for some farZ contacts.
Fort Irwin is kinda limited on what they can do radio wise. Lot's of restrictions because of the Goldstone Deep Space Communications Complex being adjacent to the base.
Gold Stone is actually inside of Ft Irwin and has been for a long time. I know that there are certain areas around Goldstone that even military personnel are restricted from. I was stationed at NTC in 95-96. One of my first vehicle recovery missions was to the southwest side of base and I accidentally crossed over into the Goldstone area and was met by armed HMMV's with M2's pointed at me. The guards wore solid tan uniforms and no rank or insignia. I was promptly escorted back to the actual training area.
I know Goldstone very well. My dad was worked there for 35 years and was the head of R&D for the DSN (Deep Space Network). I loved going to work with the old man as a kid!
I left Ft Irwin in 1996 so my memory is not the best. The turn off for Goldstone was right after you went through the gate which was after you passed the painted rocks.
I was just going to bring up Goldstone. I did a bit off work out there until I retired. You think getting into the base was difficult. NASA was a whole other level.
But they do receive radio from many, many, many, many Farz away.
Then there were the terrestrial hazards. Watch where you step!
5 hours ago, Socalgmrs said:
Wow that’s a load of words.  My best is 235 miles I’m at 4500’ and the other station is at 6000’ and we have open desert between.
WE KNEW you were High but .... 😆
Goldstone has us all beat, including MR 250 Miles, on how many FARz they get.
I found out the hard way about the extra security on the Goldstones portion of base. I'm just glad security decided to ask me why I was there first since they did have loaded M2's pointed at me. They escorted me back onto Ft Irwin proper.
All of the live fire ranges are on the opposite side of the base (north side) from Goldstone. The rotational (training) units use to deploy live mines back in the 1990's, but they were the type that were either command detonated or self detonated  after a certain time period.
FT Irwin shares its western part of the northern border with China Lake Navel Weapons Testing. We had a couple of Navy cruise missiles that were misguided and landed on Ft Irwin. Luckily no one was on the live fire ranges at the time.
The northeast corner of Ft Irwin meets up with the Southwest corner of Death Valley National Park. The winds would blow from Death Valley onto Ft Irwin during the summer. The live fire ranges were always at least 10 degrees hotter than main base.
Talk to Brent at Cerro Gordo. If you put a repeater on the ridge up there you should be able to make it down to Saline Valley and parts of DVNP and still have coverage to Mt. Whitney. There are 2 commercial antenna sites on either side of his property, but he actually owns the land all the way up to Cerro Gordo Peak (9163 ft).
Did a tour of the mines last Sept and camped at Alabama Hills..  Lots of simplex activity from Hikers.  I don't frequent that area enough to maintain a repeater gut you are right,  coverage from Cerro Gordo Peak would be a killer.  I'll donate/loan a repeater to the right someone if they are interested in setting up and maintaining at Cerro Gordo
On 5/25/2025 at 4:25 PM, WSHC539 said:
HOW MANY FARS???
CURVATURE OF EARTH
5 ft. – 2.7 miles
10 ft. – 3.9 miles
20 ft. – 5.5 miles
30 ft. – 6.7 miles
50 ft. - 8.7 miles
100 ft. – 12 miles
500 ft. - 28 miles
SOLID OBSTRUCTION
Semi-obstructions
TLDR.
The simple answer to the question is: "It depends".
I'll believe you just as soon as you prove you actually found someone willing to talk to you.
