almiz Posted January 22, 2021 Report Posted January 22, 2021 On the repeater descriptions under the maps tab it often says 'login required'. What does that mean? And how do you do it?Does it refer to the weekend regional and national net? What about general use any day any time? Anything to do with this site log in? Thx.AlmizWRKF434 Quote
2 kmcdonaugh Posted March 27, 2023 Report Posted March 27, 2023 On 1/22/2021 at 5:00 PM, almiz said: On the repeater descriptions under the maps tab it often says 'login required'. What does that mean? And how do you do it? Does it refer to the weekend regional and national net? What about general use any day any time? Anything to do with this site log in? Thx. Almiz WRKF434 Mygmrs.com and forums.mygmrs.com are two separate websites with two different log ins. If you log in to forums.mygmrs.com and then go back to the maps on mygmrs.com, you are still not logged in to mygmrs.com. It gets confusing the way it is set up. In order to see the tones, you will have to have an account and log in to "mygmrs.com" NOT forums.mygmrs.com. WRUU653 and SteveShannon 2 Quote
0 WRAK968 Posted January 22, 2021 Report Posted January 22, 2021 On the repeater descriptions under the maps tab it often says 'login required'. What does that mean? And how do you do it?Does it refer to the weekend regional and national net? What about general use any day any time? Anything to do with this site log in? Thx.AlmizWRKF434MyGMRS requires a username and password to log in to see repeater information. To obtain a username and password you must submit your callsign and fill out the registration page. Your callsign will be confirmed through the FCC database (this may take a few days if you just received your callsign) and your account will become active. This process was done to reduce the number of unlicensed operators as well as malicious operations upon repeaters that were listed. Note that your MyGMRS account is not the same as the MyGMRS forums (To my knowledge) so you will need to register on both sides to use both the forums and the main site. MacJack and kmcdonaugh 2 Quote
0 almiz Posted January 23, 2021 Author Report Posted January 23, 2021 OK thx. I am (I was) with you on everything you said. In fact I did web site login, got repeater permission, etc. It appeared from the maps page that I then had to login somwhere before I turned on my radio and activated the repeater channel. Guess I read too much into it. Thx again. Quote
0 WRAK968 Posted January 23, 2021 Report Posted January 23, 2021 OK thx. I am (I was) with you on everything you said. In fact I did web site login, got repeater permission, etc. It appeared from the maps page that I then had to login somwhere before I turned on my radio and activated the repeater channel. Guess I read too much into it. Thx again.By any chance do you know the name of the repeater so I may see first hand, perhaps I am misunderstanding what you meant by username and password? Quote
0 n4gix Posted January 23, 2021 Report Posted January 23, 2021 By any chance do you know the name of the repeater so I may see first hand, perhaps I am misunderstanding what you meant by username and password? I believe he means this: Quote
0 almiz Posted January 24, 2021 Author Report Posted January 24, 2021 The repeater is Mercer County. Go to the MAP tab/page and click on the specific repeater. It says LOGIN REQUIRED. Quote
0 MacJack Posted January 24, 2021 Report Posted January 24, 2021 Try sending a PM to CFD521. He not active on this site nor do I see a call sign... I would say it not working and may be down.Jack Quote
0 n4gix Posted January 25, 2021 Report Posted January 25, 2021 The repeater is Mercer County. Go to the MAP tab/page and click on the specific repeater. It says LOGIN REQUIRED. Is that located in Lawrenceville, NJ? It's the only "Mercer County" repeater in the entire database. If so, I have no problem seeing the frequency and CTCSS tone codes. But I did have to login mygmrs.com to allow me to see that data. kmcdonaugh 1 Quote
0 WRXI335 Posted December 5, 2023 Report Posted December 5, 2023 Just login or sign up as instructed to access the internal items on the websites. wayoverthere 1 Quote
0 wayoverthere Posted December 5, 2023 Report Posted December 5, 2023 23 minutes ago, WRXI335 said: Just login or sign up as instructed to access the internal items on the websites. This. I'll note that somewhere around the time of the original post (I forget if it was before or after) the logins between the two parts of the site were unified. One may still need to login to the main page again, as it doesn't carry between the two (afaik), but the login should be the same for main site or forum. Quote
0 WRZM562 Posted February 14, 2024 Report Posted February 14, 2024 Just means login to your account, I guess. Quote
almiz
Thx.
Almiz
WRKF434
17 answers to this question
