WRWE744 Posted March 31, 2023 Report Posted March 31, 2023 How can I unlock my Baofeng GM15 Pro for broadcast on all channels? WRTT642 1 Quote
WRUU653 Posted April 1, 2023 Report Posted April 1, 2023 12 hours ago, WRWE744 said: How can I unlock my Baofeng GM15 Pro for broadcast on all channels I don’t believe you can. SteveShannon 1 Quote
WQOK964 Posted April 2, 2023 Report Posted April 2, 2023 You bought it for GMRS, why do you need it to transmit outside of that? AdmiralCochrane, gortex2 and 1 3 Quote
AdmiralCochrane Posted April 2, 2023 Report Posted April 2, 2023 If you need to ask, you should not be doing it. gortex2, GreggInFL, wyland316 and 2 others 5 Quote
WRXV417 Posted November 28, 2023 Report Posted November 28, 2023 I'd like to "somewhat" unlock mine as well. I'm using the Radiodity GM-30 software (the only one that works as of now) and I can program tones and such, but all of the other memories are pretty much locked. The DIY memories can be renamed, but the TX/RX frequencies can't be changed. You can add some RX only frequencies into memory, but no TX that's not already programmed. I'd like to program in some repeaters local to where I travel along with appropriate tones, etc., but I'm pretty much stuck with the first 22 channels and RPT1 - 8, and just 1 set of each. I'd like to duplicate some frequencies for different areas and remove the ones I don't need. It's a bit more frustrating than their older UV-5's that let you bounce all over wherever you wanted and program 10 channels with different tones and the same freq for every city you pass thru on a drive. Raybestos 1 Quote
WRYS709 Posted November 30, 2023 Report Posted November 30, 2023 Get the Baofeng UV13-Pro, the Ham Radio cousin of that radio and it transmits on GMRS as well! Quote
WSAG543 Posted February 1, 2024 Report Posted February 1, 2024 On 11/28/2023 at 4:27 PM, WRXV417 said: I'd like to "somewhat" unlock mine as well. I'm using the Radiodity GM-30 software (the only one that works as of now) and I can program tones and such, but all of the other memories are pretty much locked. The DIY memories can be renamed, but the TX/RX frequencies can't be changed. You can add some RX only frequencies into memory, but no TX that's not already programmed. I'd like to program in some repeaters local to where I travel along with appropriate tones, etc., but I'm pretty much stuck with the first 22 channels and RPT1 - 8, and just 1 set of each. I'd like to duplicate some frequencies for different areas and remove the ones I don't need. It's a bit more frustrating than their older UV-5's that let you bounce all over wherever you wanted and program 10 channels with different tones and the same freq for every city you pass thru on a drive. This is actually why I got a Tidradio H8 GMRS. It's an unlockable radio but that's just a side benefit for SHTF. The main reason I bought it is for the flexibility with the memory channels. I really like my GM-15 Pros but the limited memory options is a let down, then again they only cost $25 a piece so we can't be too upset. Quote
WRZR633 Posted October 18, 2024 Report Posted October 18, 2024 On 11/28/2023 at 5:27 PM, WRXV417 said: I'd like to "somewhat" unlock mine as well. I'm using the Radiodity GM-30 software (the only one that works as of now) and I can program tones and such, but all of the other memories are pretty much locked. The DIY memories can be renamed, but the TX/RX frequencies can't be changed. You can add some RX only frequencies into memory, but no TX that's not already programmed. I'd like to program in some repeaters local to where I travel along with appropriate tones, etc., but I'm pretty much stuck with the first 22 channels and RPT1 - 8, and just 1 set of each. I'd like to duplicate some frequencies for different areas and remove the ones I don't need. It's a bit more frustrating than their older UV-5's that let you bounce all over wherever you wanted and program 10 channels with different tones and the same freq for every city you pass thru on a drive. Same issue... Quote
IronWire Posted January 9 Report Posted January 9 It can be completely unlocked, rather easily. https://youtu.be/G44BtmgYqhw Quote
WRYS709 Posted January 9 Report Posted January 9 I avoided this problem by getting the UV-13 pro which is the Ham radio version of that radio and since it’s already open it transmits on GMRS $20 from AliExpress from AliExpress I retired my TYT-88UV Quote
Flacracker Posted January 10 Report Posted January 10 I just bought the GM 15 Pro and have the radioditty software for the gm 30 version 2.06. Using the Baofeng cable I try to read or write to the radio and get an error to check the com port. No matter which port I use, I get the same error. I am running Windows 10. Is there another version of the software I should be using, etc? thanks Quote
WRUE951 Posted January 10 Report Posted January 10 I'm really not a Baofang fan but do own a couple UV-13 Pro's and pretty impressed with it... My GoTo radio is a Hytera HP682 but when i'm out roughing it and don't want to sacrifice my Hytera, i grab my UV-13.. The UV13 is pretty comparable to xtmt&receive quality to the Hytera. Of course the 682 is cleaner on the Analyzer but not by much.. If it wasn't for all the programing options and ease of programing i get with my HP682 the UV-13 would be my goto. The two UV-13's i picked up on Amazon were open and ready.. Quote
Lscott Posted January 10 Report Posted January 10 3 hours ago, WRUE951 said: If it wasn't for all the programing options and ease of programing i get with my HP682 Looks like a nice radio. What did you pay for it? Hytera HP602-682.pdf Quote
WRUE951 Posted January 10 Report Posted January 10 41 minutes ago, Lscott said: Looks like a nice radio. What did you pay for it? Hytera HP602-682.pdf 2.23 MB · 1 download i have two. My first HP682 bought at Atlantic Radio last Christmas for $525. (christmas sale) Last July I picked one up on Ebay for $375. it was a demo, still had the protective film and looked new when it got it. Both are fantastic radios.. Atlantic gave me the CPS and the Wide Band Lic free with the purchase. Programing is a lot easier than Motorola. I also picked up an HM782 from the same Ebay seller (used) $400. That radio also was a demo and had the protective film.. Both work great in DMR as well.. If you are interested, keep your eyes on Ebay, they come up used as Demo about mid year.. Quote
Lscott Posted January 10 Report Posted January 10 4 minutes ago, WRUE951 said: If you are interested, keep your eyes on Ebay, they come up used as Demo about mid year.. I'll keep an eye out for one, and if it's cheap enough I might go for it. I'm primarily a Kenwood guy. I do have a few Chinese radios, a few Motorola's and Icom's. I just dropped $120 on a used Kenwood NX-320 off eBay. Got it yesterday. This one had the 400-470 band split. I have one already but it's the higher split range and won't run below about 443MHz. I wanted a version of that model that covers the Ham band. https://forums.mygmrs.com/gallery/image/418-nx-320jpeg/?context=new I have a bunch of DMR radios as it is now. In fact I have WAY too many radios. The ones I have cover D-Star, dPMR, DMR, NXDN and P25 Phase 1 so far. Nothing for System Fusion yet. SteveShannon 1 Quote
WRUE951 Posted January 10 Report Posted January 10 25 minutes ago, Lscott said: I'll keep an eye out for one, and if it's cheap enough I might go for it. I'm primarily a Kenwood guy. I do have a few Chinese radios, a few Motorola's and Icom's. I just dropped $120 on a used Kenwood NX-320 off eBay. Got it yesterday. This one had the 400-470 band split. I have one already but it's the higher split range and won't run below about 443MHz. I wanted a version of that model that covers the Ham band. https://forums.mygmrs.com/gallery/image/418-nx-320jpeg/?context=new I have a bunch of DMR radios as it is now. In fact I have WAY too many radios. The ones I have cover D-Star, dPMR, DMR, NXDN and P25 Phase 1 so far. Nothing for System Fusion yet. you wont be dissatisfied with a Hytera. If you end up with one and you need CPS or the Wideband.. Send me a ping.. I can help. Quote
WRYS709 Posted January 10 Report Posted January 10 8 hours ago, Flacracker said: I just bought the GM 15 Pro and have the radioditty software for the gm 30 version 2.06. Using the Baofeng cable I try to read or write to the radio and get an error to check the com port. No matter which port I use, I get the same error. I am running Windows 10. Is there another version of the software I should be using, etc? thanks The Radioddity GM-30 CPS software is the "go-to" software for the Baofeng GM-15. You are having Windows USB Cable/driver issues which is a dark art on Windows! Did your programming cable come with your GM-15, or did you acquire it separately? All facts would be helpful to diagnose! Quote
Flacracker Posted January 11 Report Posted January 11 No cable came with the GM15. I bought it separately from Baofeng. WRYS709 1 Quote
WRTC928 Posted January 11 Report Posted January 11 41 minutes ago, Flacracker said: No cable came with the GM15. I bought it separately from Baofeng. According to the video @IronWire linked above, the Baofeng cable doesn't work. You have to get the Radioddity cable. I don't know personally; I don't own that radio. WRYS709 1 Quote
tcp2525 Posted January 12 Report Posted January 12 On 1/10/2025 at 1:00 PM, Lscott said: I'll keep an eye out for one, and if it's cheap enough I might go for it. I'm primarily a Kenwood guy. I do have a few Chinese radios, a few Motorola's and Icom's. I just dropped $120 on a used Kenwood NX-320 off eBay. Got it yesterday. This one had the 400-470 band split. I have one already but it's the higher split range and won't run below about 443MHz. I wanted a version of that model that covers the Ham band. https://forums.mygmrs.com/gallery/image/418-nx-320jpeg/?context=new I have a bunch of DMR radios as it is now. In fact I have WAY too many radios. The ones I have cover D-Star, dPMR, DMR, NXDN and P25 Phase 1 so far. Nothing for System Fusion yet. I always was a "Kenwood guy" for decades, but sadly they dropped the ball in the amateur sector by discontinuing the famous V71a after 20 years of production. I'm glad I have four of them. I was always tempted to explore their commercial radios but never got around to it. Did you really say you have too many radios? Really? Is that even possible? As for digital, I have D-Star, DMR and C4FM covered. In all honesty, I really dislike the sound of digital and much prefer the natural sound of good old analog. I found that C4FM is the better sounding of all digital formats and D-Star the worst. I hope the FCC never allows digital on GMRS. SteveShannon 1 Quote
Lscott Posted January 12 Report Posted January 12 6 hours ago, tcp2525 said: Did you really say you have too many radios? Really? Is that even possible? What do you think? https://forums.mygmrs.com/gallery/image/249-my-radio-collection/?context=new Quote
tcp2525 Posted January 12 Report Posted January 12 1 hour ago, Lscott said: What do you think? https://forums.mygmrs.com/gallery/image/249-my-radio-collection/?context=new Looks like you are off to a good start. Gotta say, it does look like a nice collection, but there still is some open space on them shelves. Lscott 1 Quote
Lscott Posted January 12 Report Posted January 12 38 minutes ago, tcp2525 said: but there still is some open space on them shelves. I’m working on it. I would like to find another IC-F3162DT with the dPMR firmware and a few reasonably priced NX-1200DV’s with display and limited keypad. Quote
tcp2525 Posted January 12 Report Posted January 12 58 minutes ago, Lscott said: I’m working on it. I would like to find another IC-F3162DT with the dPMR firmware and a few reasonably priced NX-1200DV’s with display and limited keypad. Looks like you have an HT fetish, which is good. I lean more towards mobiles myself. Quote
