WRUI314 Posted August 14, 2023 Report Posted August 14, 2023 Hi All, I am brand new (FNG) to GMRS I have two hand held radios a UV-5R and a UV-9G but I am looking to replace the CB in my Jeep with a Base/Mobile model. Do you all have any advice/suggestions for a NOOB? I am looking for something that will hold up to 4 wheeling but also not drain bank account to much. Quote
OffRoaderX Posted August 15, 2023 Report Posted August 15, 2023 The KG-1000G or XS-20G are both very good mobile radios. I had a KG1000G in both my Jeeps for a couple of years before replacing them with (MUCH more expensive) LMR type radios. WRUI314, marcspaz and WRUU653 2 1 Quote
WRUI314 Posted August 15, 2023 Author Report Posted August 15, 2023 Thanks for the recommendations, I will check them out and also look to see if you’ve made a video on them. Quote
WRXW945 Posted August 15, 2023 Report Posted August 15, 2023 Also take a look at the Midland MXTA26 antenna. We put one on the wife's 23' Wrangler (Not a Rubicon) using a spare tire mount. Works great and sticks up about 2" over the roof top. https://www.amazon.com/Hooke-Road-Antenna-Bracket-Wrangler/dp/B07XDHS1LR?ref_=ast_sto_dp WRUI314 1 Quote
H8SPVMT Posted August 15, 2023 Report Posted August 15, 2023 I have had the Midland MXT400 in my Jeep Wrangler for about three years now. I usually get the most use out of it on trail rides. As I understand it, the MXT500 is pretty much the same but with more output power. Also you can select the wideband feature that will assist in getting better reception of other brand systems. Midland is usually a narrow band and it makes you turn un the volume to hear wideband radios better. My daily driving usage has been very limited and involves GMRS repeaters when/where available. Overall, there are few people using this system of communication except to speak with fellow travelers or local neighbor chats. Businesses around town use it often. For me I set the channel selector on SCAN and that is what I hear the most of. WRUI314 1 Quote
gortex2 Posted August 15, 2023 Report Posted August 15, 2023 I run the Midland 275 in both my jeeps. I use GMRS for trail riding and the Midland is what others have so its the KISS method. I do use it on repeaters around home also. WRUI314 1 Quote
marcspaz Posted August 15, 2023 Report Posted August 15, 2023 I have run a bunch of different radios over the last 3 to 5 years. I feel like any of the Wouxun or Midland radios would be a good choice. Got to say, though, I am currently using a Land Mobile Radio Service radio and there is nothing on the market that has matched it in performance or durability. The only downside is the price tag. WRUI314 1 Quote
WRUI314 Posted August 15, 2023 Author Report Posted August 15, 2023 Thanks guys, I will look into the Midland MTX400 and 275 plus the MXTA26 antenna. Quote
SteveShannon Posted August 15, 2023 Report Posted August 15, 2023 26 minutes ago, WRUI314 said: Thanks guys, I will look into the Midland MTX400 and 275 plus the MXTA26 antenna. Just so you know, the MXTA26 antenna does not include a mount. You’ll still need to get some kind of NMO mount to attach to your jeep and accept the antenna. Many mounts include the coax cable as well. WRUI314, WRUU653, WRXW945 and 1 other 3 1 Quote
WRQG411 Posted August 16, 2023 Report Posted August 16, 2023 One thing I like about the Midland mount/cables is that the PL259 connector unscrews from the cable and is much smaller, allowing a smaller hole for bringing the cable into the cab of the vehicle. The 400 is popular as I understand that there is CPS available to program it, while the 275 and 575 are programmed from the hand mic. WRUU653, WRUI314, WRXW945 and 1 other 2 2 Quote
WRXW945 Posted August 16, 2023 Report Posted August 16, 2023 22 hours ago, Sshannon said: Just so you know, the MXTA26 antenna does not include a mount. You’ll still need to get some kind of NMO mount to attach to your jeep and accept the antenna. Many mounts include the coax cable as well. Ohh yeah, I forgot to mention that. I agree with WRQG411 on the Midland PL259 mount / cable. I was able hide the cable in the gap between the frame and the fender cover fabric. Just loosen the bolts holding the top on and shove the cable behind them. From there you can run the same line down until you reach the rear floor mat. WRXB215, WRUU653, SteveShannon and 1 other 3 1 Quote
WRXX537 Posted September 23, 2023 Report Posted September 23, 2023 On 8/15/2023 at 2:08 PM, WRUI314 said: Thanks guys, I will look into the Midland MTX400 and 275 plus the MXTA26 antenna. I myself have the MXT275 and do not like it because of the method to program frequencies in, (can’t have multiple tone codes per channel) and will be selling once I decide if I want to stick with GMRS or get a Ham for my Jeep. I feel the GMRS is limited as far as talking to others unless you are linked to a repeater. Im new to this myself but do have some experience with my radio to know I’m looking for more. Quote
marcspaz Posted September 24, 2023 Report Posted September 24, 2023 1 hour ago, WRXX537 said: ...will be selling once I decide if I want to stick with GMRS or get a Ham for my Jeep. Anecdotal, I know, but in my own experience there are very few people I wheel with that are amateur radio operators. All of them use FRS or GMRS when they wheel anyway. Moving to amateur service for offroad is seriously going to limit who you talk to on the trails. If you are not worried about that or don't trail ride, I suppose it's a non-issue. 1 hour ago, WRXX537 said: I feel the GMRS is limited as far as talking to others unless you are linked to a repeater. If you are planing on using VHF and UHF, the same limits apply as in GMRS. While you can run 1,500 watts on amateur bands, the extra power doesn't do much if the LOS isn't there. Most of the time, VHF simplex around me, is limited to between 3.5 and 20 miles depending on terrain. However, I few days ago, from a mountain top I talked to someone almost 250 miles away. GMRS works the exact same way. The only thing that gets you more range without repeaters and mountain tops is HF. You can work the world with just a few watts... but you won't talk any further locally there either, as LOS still limits local comms. Usually once you hit the LOS barrier, either you need 40m, 80m or 160m NVIS to talk, say 20 to 350 miles. Otherwise, you aren't talking to many people inside the 350 mile radius there, either. 1 hour ago, WRXX537 said: Im new to this myself but do have some experience with my radio to know I’m looking for more. What specifically are you looking to do. Myself and many others have a ton of experience over many decades in different areas. There is a good chance we can help if we know what you want to do. AdmiralCochrane, WRXB215 and SteveShannon 3 Quote
