WRYR550 Posted September 19, 2023 Report Posted September 19, 2023 First post here so roast me as you will. Looking for a group of know it alls on the KG-1000G plus. Being a newb, I have hacked everthing I've ever owned and I want to unlock this radio. Have any of you done it? Do you have a Chirp profile? What software are you using? Why isn't there more content out there on this radio yet!?! lol. Quote
WRYS709 Posted September 19, 2023 Report Posted September 19, 2023 Wouxun has a reputation for manufacturing GMRS radios that do not unlock! Good luck! Raybestos 1 Quote
OffRoaderX Posted September 19, 2023 Report Posted September 19, 2023 18 minutes ago, WRYR550 said: I have hacked everthing I've ever owned and I want to unlock this radio. You're not going to hack this, so start preparing for defeat.. Raybestos and donmontalvo 1 1 Quote
WRYR550 Posted September 19, 2023 Author Report Posted September 19, 2023 Wow first post and I get the famous Notarubicon guy! Challenge accepted! FreqieRadio and donmontalvo 1 1 Quote
Borage257 Posted September 19, 2023 Report Posted September 19, 2023 I’ve heard rumors of certain firmware plugs for the ham version and fully unlocked radios if you order straight from Wouxon, but cannot confirm any of it. Quote
WRYR550 Posted September 19, 2023 Author Report Posted September 19, 2023 Can neither confirm nor deny . I’ll be digging into this. Quote
Raybestos Posted September 19, 2023 Report Posted September 19, 2023 6 hours ago, WRYS709 said: Wouxun has a reputation for manufacturing GMRS radios that do not unlock! Good luck! Lemme know if you get it to encode on the scrambler feature! Quote
WRYS709 Posted September 19, 2023 Report Posted September 19, 2023 3 hours ago, RayP said: Lemme know if you get it to encode on the scrambler feature! Sorry, the only Wouxun product that I have purchased, a tri-band Ham Radio HT, I sold on eBay after I could not find a MARS/CAPS modification. I have never attempted to use any scrambler feature on any of my radios, as I view that as a violation of the FCC rules that will be taken very seriously by their staff. Quote
Raybestos Posted September 19, 2023 Report Posted September 19, 2023 5 hours ago, WRYS709 said: Sorry, the only Wouxun product that I have purchased, a tri-band Ham Radio HT, I sold on eBay after I could not find a MARS/CAPS modification. I have never attempted to use any scrambler feature on any of my radios, as I view that as a violation of the FCC rules that will be taken very seriously by their staff. I realize the FCC does not condone scramblers on ham or GMRS. That said, I wish there were a hack to activate scrambler encoding, along with the decode feature some Wouxuns have, in case things deteriorate to a WROL situation. No, the voice inversion scrambling would not give you total privacy, but it would eliminate around 70% of a potential listening audience from hearing your group's transmissions. Quote
SteveShannon Posted September 19, 2023 Report Posted September 19, 2023 10 minutes ago, RayP said: I realize the FCC does not condone scramblers on ham or GMRS. That said, I wish there were a hack to activate scrambler encoding, along with the decode feature some Wouxuns have, in case things deteriorate to a WROL situation. No, the voice inversion scrambling would not give you total privacy, but it would eliminate around 70% of a potential listening audience from hearing your group's transmissions. Your group should invest in radios on a service that allows encryption. AdmiralCochrane, kirk5056, dosw and 3 others 5 1 Quote
CentralFloridaGMRS Posted September 19, 2023 Report Posted September 19, 2023 I have two and they're great radios and no way you hack it. Quote
Borage257 Posted September 19, 2023 Report Posted September 19, 2023 1 hour ago, Sshannon said: Your group should invest in radios on a service that allows encryption. This is the way. Apparently encryption and digital are allowed on Murs. The Gotenna uses encrypted digital modes on those frequencies. But all that is very low power and limited range. Quote
WRUU653 Posted September 19, 2023 Report Posted September 19, 2023 2 hours ago, Borage257 said: This is the way. Apparently encryption and digital are allowed on Murs. The Gotenna uses encrypted digital modes on those frequencies. But all that is very low power and limited range. Located here... SteveShannon and WRHS218 1 1 Quote
Borage257 Posted September 20, 2023 Report Posted September 20, 2023 It was approved by the FCC for data transmissions. The data mode isn’t voice so that scrambling doesn’t apply. https://www.radioworld.com/news-and-business/examining-the-gotenna-communications-device WRUU653 1 Quote
WRUU653 Posted September 20, 2023 Report Posted September 20, 2023 16 minutes ago, Borage257 said: It was approved by the FCC for data transmissions. The data mode isn’t voice so that scrambling doesn’t apply. https://www.radioworld.com/news-and-business/examining-the-gotenna-communications-device Ah, I see. You were proposing it as an alternative to the aforementioned voice scrambling. Quote
WRYR550 Posted January 23, 2024 Author Report Posted January 23, 2024 I wish I could say I have obtained the source code or that I've given this 100 hours but I haven't. I have found out that if you hold in #1 on the hand mic when you cycle the power it does take you to a differenct menu. I'm hoping one of you all is a lot smarter than me and can take that and play around with it and see what you find. Quote
WRYZ926 Posted January 23, 2024 Report Posted January 23, 2024 I do believe the KG1000G is the same radio as the KG-UV980P. What I do not know is if the UV980 firmware will work on the KG1000G. I would hate to see anyone brick their radio though. Even the Wouxun amateur band radios seem to be more difficult to unlock and I too have not found a way to unlock the KG1000G. The TYT TH-7800 and TH9800 are simple to unlock using the TYT programming software. Not that I would tell or suggest anyone do that. WRUU653 and AdmiralCochrane 2 Quote
WSAM853 Posted April 30, 2024 Report Posted April 30, 2024 Software for the KG-UV950P is on the Internet.Sent from my Pixel 8 Pro using Tapatalk Quote
SvenMarbles Posted May 1, 2024 Report Posted May 1, 2024 Just have other radios that do other things. It’s fun to get new radios anyway . Quote
WRYZ926 Posted May 1, 2024 Report Posted May 1, 2024 The KG-Q10H is the only Wouxun radio that I have found that is easy to unlock. I think there might be sources for programs from Europe for unlocking Wouxun radios, but I haven't messed with any. Quote
OffRoaderX Posted May 1, 2024 Report Posted May 1, 2024 Just my little $0.02 of an update. According to the man that spec'd the KG-1000G with Wouxun, all of the GMRS rules & restrictions are burned into the firmware, and according to him, the radio cannot be unlocked. WSCH851, WRXB215 and gortex2 3 Quote
JBRPong Posted May 2, 2024 Report Posted May 2, 2024 18 hours ago, WRYZ926 said: The KG-Q10H is the only Wouxun radio that I have found that is easy to unlock. I think there might be sources for programs from Europe for unlocking Wouxun radios, but I haven't messed with any. I think I've seen on the interwebs that the KG-UV9PX can be expanded. Quote
WRYZ926 Posted May 2, 2024 Report Posted May 2, 2024 The KG-UV9PX very well could be capable of being unlocked. From what I could find, and as @OffRoaderX said, the Wouxun GMRS certified radios are locked down in the firmware. I also haven't found any easy way to unlock/modify any of the Wouxun amateur band mobile radios either. I was surprised on how easy it is to unlock the KG-Q10H hand held and how quickly that information came out. JBRPong 1 Quote
nokones Posted May 2, 2024 Report Posted May 2, 2024 Last year, I bought a KG-UV3X PRO for my RDF cache of equipment and it was factory locked down so it can't be programmed for GMRS freqs. The manual referenced that the radio can be unlocked but you had to consult with the dealer to unlock it. The dealer did not have a clue what I was talking about and I couldn't find anyone else that knew anything about this radio. After playing with the radio for a few minutes and trying different things pushing the buttons on the radio and with the software the radio somehow unlocked and I don't know what I did to unlock it. I guess I had to use the ol' PFM know-how in order to make it happen whatever that was. WRVC311 1 Quote
WRUU653 Posted May 2, 2024 Report Posted May 2, 2024 1 hour ago, JBRPong said: the KD-UV9PX can be expanded You are correct. Quote
