CyborgAlienWRYG738 Posted November 9, 2023 Report Posted November 9, 2023 What is a "Stun and Kill Function"?!? Quote
0 SteveShannon Posted November 9, 2023 Report Posted November 9, 2023 9 minutes ago, CyborgAlienWRYG738 said: How would one know if it had been or not? Like I said I heard someone saying they "had gotten a few radios". If it's not their radios how could they have? If they killed your radio it wouldn’t work. If they stunned your radio it wouldn’t work. There is no “deflate their ego” function. WRUU653 1 Quote
0 CyborgAlienWRYG738 Posted November 9, 2023 Author Report Posted November 9, 2023 1 minute ago, Sshannon said: If they killed your radio it wouldn’t work. If they stunned your radio it wouldn’t work. There is no “deflate their ego” function. it only received, out isn't happening... Quote
0 SteveShannon Posted November 9, 2023 Report Posted November 9, 2023 45 minutes ago, CyborgAlienWRYG738 said: My power has dropped from 4 something just a couple of days ago to low 3W's Actually in the second frequency you tried, when you first PTT your meter showed 3.96 watts. Then it started dropping off. Quote
0 SteveShannon Posted November 9, 2023 Report Posted November 9, 2023 4 minutes ago, CyborgAlienWRYG738 said: it only received, out isn't happening... It obviously is or your wattmeter wouldn’t register 3.96 watts. WRUU653 1 Quote
0 CyborgAlienWRYG738 Posted November 9, 2023 Author Report Posted November 9, 2023 I didn't get any proof but, before it was getting 4.5+ W on the channels, still much less than the advertised 5.5W it claims to do. Quote
0 CyborgAlienWRYG738 Posted November 9, 2023 Author Report Posted November 9, 2023 Just now, Sshannon said: It obviously is or your wattmeter wouldn’t register 3.96 watts. it doesn't have any fars, i'm no longer hitting my local repeater... Quote
0 WRWE456 Posted November 9, 2023 Report Posted November 9, 2023 For some reason I do not see the picture just audio so can't tell what is happening in your video. Quote
0 WRWE456 Posted November 9, 2023 Report Posted November 9, 2023 Could be the meter or connections? It happens. SteveShannon 1 Quote
0 SteveShannon Posted November 9, 2023 Report Posted November 9, 2023 30 minutes ago, CyborgAlienWRYG738 said: How would one know if it had been or not? Like I said I heard someone saying they "had gotten a few radios". If it's not their radios how could they have? Menu 45 will show you the setting for Stun/kill. In order to stun/kill you they have to send the same ANI code as set in your radio. The ANI code is set in menu 15. The menu numbers are for the kg1000, your model might be slightly different but this is all covered by the manual. Quote
0 CyborgAlienWRYG738 Posted November 9, 2023 Author Report Posted November 9, 2023 12 minutes ago, WRWE456 said: For some reason I do not see the picture just audio so can't tell what is happening in your video. Having the same problem on Chromebook, not on Android phone I posted from.... Dunno Trying again... VID_20231107_181636629.mp4 Quote
0 CyborgAlienWRYG738 Posted November 9, 2023 Author Report Posted November 9, 2023 14 minutes ago, WRWE456 said: Could be the meter or connections? It happens. Brand new just out of the box, dunno, maybe dud too... Unsure of Nissei, never heard of them before I ordered and could not get the Fars-o-Meter 2K Quote
0 CyborgAlienWRYG738 Posted November 9, 2023 Author Report Posted November 9, 2023 14 minutes ago, Sshannon said: Menu 45 will show you the setting for Stun/kill. In order to stun/kill you they have to send the same ANI code as set in your radio. The ANI code is set in menu 15. The menu numbers are for the kg1000, your model might be slightly different but this is all covered by the manual. Somehow, my radio had that, (Menu 22 on the KG-UV9GX,) changed from Off to DT-ANI, so I don't know... Quote
0 CyborgAlienWRYG738 Posted November 9, 2023 Author Report Posted November 9, 2023 20 minutes ago, Sshannon said: ...but this is all covered by the manual. Have you seen the manual for the KG-UV9GX.... Go check out Randy's video, it's not changed... Quote
0 SteveShannon Posted November 9, 2023 Report Posted November 9, 2023 8 minutes ago, CyborgAlienWRYG738 said: Have you seen the manual for the KG-UV9GX.... Go check out Randy's video, it's not changed... In the parent manual it’s section 4, Remote Control, which starts on page 49. Quote
0 CyborgAlienWRYG738 Posted November 9, 2023 Author Report Posted November 9, 2023 In my 4 page manual, I don't have a page 49, it barely goes to 16, if you fold it 4 ways... 7 minutes ago, Sshannon said: In the parent manual it’s section 4, Remote Control, which starts on page 49. Quote
0 SteveShannon Posted November 10, 2023 Report Posted November 10, 2023 4 minutes ago, CyborgAlienWRYG738 said: In my 4 page manual, I don't have a page 49, it barely goes to 16, if you fold it 4 ways... You must combine that with what’s called the “Parent Manual” https://bettersaferadio.com/wp-content/uploads/BSR-Wouxun-KG-UV9G-User-Manual.pdf WRUU653 1 Quote
0 CyborgAlienWRYG738 Posted November 10, 2023 Author Report Posted November 10, 2023 Sorry I hadn't seen that manual until just now... I've been trying to make heads/tails of it. I tried what it suggested in it and haven't noticed any difference. Test results haven't improved either. I also have heavily modified my unit since then too. I no longer use the default PTT-ID or anything to do with it. I'm wondering if the sun-spot activity could have anything to do with it? It's just got me so confused as to why I'm not able to get anything but, repeater tones when I key up, even after others just went "to the side and monitoring"... I'm not able to even get that on some of the other repeaters, even when I'm local to them... Even trying to respond to people who are also trying to get a response when they are doing radio checks, I'm not able to connect with them even though I hear them loud and clear... Quote
0 OffRoaderX Posted November 10, 2023 Report Posted November 10, 2023 13 minutes ago, CyborgAlienWRYG738 said: I'm wondering if the sun-spot activity could have anything to do with it? No, it doesn't have anything to do with it. CyborgAlienWRYG738 1 Quote
0 CyborgAlienWRYG738 Posted November 10, 2023 Author Report Posted November 10, 2023 Would a full reset of the device, do anything to improve anything? I have no problem loading up ChirpNext and reinstalling it, if I have to, I just don't want to deal with the hassel if it's not going to help. Quote
0 sjl777 Posted November 17, 2023 Report Posted November 17, 2023 The Btech GMRS 20V2 mobile will tell you when the radio has been killed. I had it happen to me several times. If your radio is setup to receive DTMF codes and you have not changed the default factory code, someone can send your radio the kill or stun code and lock up your radio. I recoved from the kill setting using CHIRP and reloading the initial factory setting image. I also reset all on the radio after it was restored. You adjust the DTMF settings in CHIRP. I suspect that there may be a bug in CHIRP for my radio and DTMF. I changed the factory code at a minimum and have not had an issue. CHIRP give the 20V2 the option to disable all TX and RX of DTMF codes with a check box. This may be the cause of my killed radio. It seems when I have the boxes checked i increase the odds of the radio being killed. Uncheck those boxes, no issue. I have not tried it out since the latest series of CHIRP updates. I dont use the BTech CPS so I do not know if there are other options or better ones. CyborgAlienWRYG738 and WRXB215 1 1 Quote
0 WRWE456 Posted November 17, 2023 Report Posted November 17, 2023 According to the KG-1000Gplus manual "To reactivate a killed radio send the kill sequence again". CyborgAlienWRYG738, SteveShannon and WRXB215 2 1 Quote
0 CyborgAlienWRYG738 Posted November 17, 2023 Author Report Posted November 17, 2023 1 hour ago, WRWE456 said: According to the KG-1000Gplus manual "To reactivate a killed radio send the kill sequence again". Says the same thing in the KG-UV9P manual that's supposed to be the parent manual for the KG-UV9GX. I did this too, as apparently, from what I read you do it on the affected device. Quote
0 CyborgAlienWRYG738 Posted November 17, 2023 Author Report Posted November 17, 2023 2 hours ago, sjl777 said: The Btech GMRS 20V2 mobile will tell you when the radio has been killed. I had it happen to me several times. If your radio is setup to receive DTMF codes and you have not changed the default factory code, someone can send your radio the kill or stun code and lock up your radio. I recovered from the kill setting using CHIRP and reloading the initial factory setting image. I also reset all on the radio after it was restored. I reset my device, loaded my defaults in ChirpNext and did what I mentioned below first. I noticed an uptick in my tx power but, still not full power. I'm going to have a look at those other settings and see if that does anything as well, I just recently stopped those settings as well I believe but, I'll have to double check to be certain. I also have the default settings in the official Wouxun app, I just have to borrow a Winblows to do it though. I want to do another Reset when I do it though, also, those codes your talking about, are they the same as the reset codes for the device? Quote
0 WRWE456 Posted November 17, 2023 Report Posted November 17, 2023 I seriously doubt that any setting or feature in the radio is going to decrease the power output other than the power settings and built in power limits of low, medium and high power channels. I think you need to move on from that idea. CyborgAlienWRYG738 1 Quote
0 CyborgAlienWRYG738 Posted November 17, 2023 Author Report Posted November 17, 2023 38 minutes ago, WRWE456 said: I seriously doubt that any setting or feature in the radio is going to decrease the power output other than the power settings and built in power limits of low, medium and high power channels. I think you need to move on from that idea. There's got to be a way to adjust those. The only one seemingly effected is the High power setting not reaching it's max power. Though I believe it did to begin with before I was able to get an SWR meter to check it with. Quote
CyborgAlienWRYG738
Top Posters For This Question
31
13
7
5
Popular Days
Nov 9
36
Nov 17
10
Nov 29
7
Nov 28
6
CyborgAlienWRYG738 31 posts
SteveShannon 13 posts
WRWE456 7 posts
WRQC527 5 posts
Popular Days
Nov 9 2023
Nov 17 2023
Nov 29 2023
Nov 28 2023
Popular Posts
SteveShannon
Here’s what a Reddit user said: Stun is a setting which will allow the radio to receive but not be controlled or used to transmit. It will listen for the revive command. It's a commercial ra
OffRoaderX
Are you transmitting on the same channel as you were when you were getting 4W? The output varies on most of these radios depending on the frequency.
WRWE456
Posted Images
65 answers to this question
