TNFrank Posted January 10, 2024 Report Posted January 10, 2024 For a short antenna do these work as well as something like the Nagoya 771G or similar or do you get a bit more range with the longer antennas? Thanks in advance for any info. Quote
SteveShannon Posted January 10, 2024 Report Posted January 10, 2024 Generally speaking a longer antenna will result in a stronger signal for both transmission and reception, as long as everything else is equal. Whether that results in greater range is debatable. Your range on UHF is more frequently limited by terrain than signal strength. WRHS218 and WRUU653 2 Quote
Hoppyjr Posted January 13, 2024 Report Posted January 13, 2024 I agree with SShannon that terrain is the main factor. This said, I have the 771G Nagoya antennas on a couple handhelds and it’s shorter siblings on a couple others. I also have the Smiley Slim Duck on two and generally find it performs better than the stock antenna or shorter Nagoya, but about the same as the 771G. I prefer the Smiley. WRUU653, SteveShannon and TNFrank 3 Quote
WRUW493 Posted January 21, 2024 Report Posted January 21, 2024 I hate to burst y'all's bubble, but the longer antenna on an HT won't help. That 771G Nagoya is a 5/8 wavelength antenna, which in order to have "gain" in the plane normal to the antenna would require a ground plane diameter of at least 1 wavelength. Obviously the radio is not that. What you really want is a simple 1/4 wavelength antenna (about 6 inches at GMRS) that has LOW LOSS, meaning it's efficient. With the GMRS HTs being also about 6 inches tall this makes for a really nice dipole antenna. A simple piece of heavy gauge copper wire would work just fine, but would not be so good mechanically. And that would not be so good for VHF, only tuned to UHF. I took a chance on this antenna and found it to be excellent since it's just a copper wire encased in flexible plastic. https://www.amazon.com/gp/product/B0855PVDWS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 You will find that Motorola uses this concept on their HT's and for a good reason: it works the best for a handheld. The bottom line: for a handheld radio, you want radiation efficiency. Any antenna that has fancy coils to tune them is by definition low efficiency. Radiation pattern make little to no difference, and radiation pattern is the only thing you get with an antenna system longer than 1/2 wave dipole. Consider that over a propagation path you have no idea what the best path is to the other station at any point in time. Consider an urban or forest environment: reflections off of a building, car, tree is frequently the best path, and that changes literally by the foot as you walk around. Hope this helps. SvenMarbles 1 Quote
SteveShannon Posted January 21, 2024 Report Posted January 21, 2024 2 hours ago, WRUW493 said: I hate to burst y'all's bubble, but the longer antenna on an HT won't help. Actual measurements of signal strength performed by swapping between the OEM antenna on my UHF radio and a clone of the Nagoya (Tid Radio 771) dispute that. Sitting at my kitchen table I transmitted to a DMR repeater 16 miles away. I watched the signal reports using a Brandmeister connected dashboard. When I transmitted using the factory rubber duck the signal strength was reported as s6. Then I removed the factory antenna and replaced it with the clone 771 antenna. The signal varied between s7 and s8. Going back to the original antenna the signal strength went back down. Those are reproducible data. Since then I have replaced the original antennas on two of my best radios with Diamond 771 antennas. I consistently get good signal reports from other hams on both 2 meters and 70 cm when using these antennas. As an aside, I don’t know what the number 771 indicates. AdmiralCochrane, WRWE456, Hoppyjr and 1 other 3 1 Quote
TNFrank Posted January 21, 2024 Author Report Posted January 21, 2024 On my BTech GMRS V2's I've been using the ABBREE 771C with is a GMRS antenna that's a nice orange color, LOL. They seem to work well enough. For the new KG-UV9D Plus I ordered a Nagoya 771G since it's a nice radio and deserves a nice antenna. Quote
TNFrank Posted January 21, 2024 Author Report Posted January 21, 2024 57 minutes ago, Sshannon said: As an aside, I don’t know what the number 771 indicates. Maybe it has something to do with the length of the antenna? I know they have a shorter 701 and the 771 is the longer of the two so it could be in mm or some such. SteveShannon 1 Quote
WRUW493 Posted January 22, 2024 Report Posted January 22, 2024 Hi Shannon, Thanks for the really good info and testing. Real world testing is always helpful. I see that the 771 antenna is 15.5 inches long, making it about 5/8 wavelength. The radiation pattern of a 5/8 wavelength with very little ground plane (the HT) is a rather high angle of radiation, probably 45 degrees or so. I don't know what the OEM antenna was. Couple of things to consider: 1- Since antennas do not create power, they only direct more in one direction than another direction. So without performing a similar experiment with the HT is quite a few orientations it's hard to say how the 771 (or any antenna for that matter) will behave in a variety of RF environments. This is why antennas are measured in RF anechoic chambers in dozens of orientations and then averaged together for a final evaluation. I have taken real world RF propagation data from a handheld (cell phone) to base station where not only does the best RF path change direction by 10's of degrees with every fraction of a foot change in location, but also inside of buildings with multiple reflections taking place it's not uncommon for the best RF path to be a TX polarization different or even orthogonal polarization to the RX antenna. 2- It's real easy to have poor radiation efficiency on dual band antennas. Loading coils and dual band related compromises all are opportunities for loss, read RF absorption. It could be as simple as the OEM antenna has poorer efficiency than the 771. This too would show up in a test of multiple orientations in a controlled environment. These are why that in the general case one wants a mostly spherical radiation pattern (read low "gain") and high efficiency. Then one has the best chance overall of having good radiation in the direction that the repeater/other mobile appears to be from the HT's perspective. Hope this helps, and keep up the good work Quote
WRYZ926 Posted January 22, 2024 Report Posted January 22, 2024 I have a few Abbree 771 and Nagoya 771 antennas for 2m/70cm and GMRS. The 771 antennas do make an improvement on my Baofeng and Explorer QRZ-1 (TYT UV-88). But I did not see any improvement with those antennas on my Wouxun KG935G or Icom IC-T10. WRUU653 and SteveShannon 2 Quote
SteveShannon Posted January 22, 2024 Report Posted January 22, 2024 12 hours ago, WRUW493 said: Hi Shannon, Thanks for the really good info and testing. Real world testing is always helpful. I see that the 771 antenna is 15.5 inches long, making it about 5/8 wavelength. The radiation pattern of a 5/8 wavelength with very little ground plane (the HT) is a rather high angle of radiation, probably 45 degrees or so. I don't know what the OEM antenna was. Couple of things to consider: 1- Since antennas do not create power, they only direct more in one direction than another direction. So without performing a similar experiment with the HT is quite a few orientations it's hard to say how the 771 (or any antenna for that matter) will behave in a variety of RF environments. This is why antennas are measured in RF anechoic chambers in dozens of orientations and then averaged together for a final evaluation. I have taken real world RF propagation data from a handheld (cell phone) to base station where not only does the best RF path change direction by 10's of degrees with every fraction of a foot change in location, but also inside of buildings with multiple reflections taking place it's not uncommon for the best RF path to be a TX polarization different or even orthogonal polarization to the RX antenna. 2- It's real easy to have poor radiation efficiency on dual band antennas. Loading coils and dual band related compromises all are opportunities for loss, read RF absorption. It could be as simple as the OEM antenna has poorer efficiency than the 771. This too would show up in a test of multiple orientations in a controlled environment. These are why that in the general case one wants a mostly spherical radiation pattern (read low "gain") and high efficiency. Then one has the best chance overall of having good radiation in the direction that the repeater/other mobile appears to be from the HT's perspective. Hope this helps, and keep up the good work I agree that antennas don’t create power and I understand gain. I use my radios with the antenna vertical. For me, having a spherical pattern, like an isentropic antenna, would be wasteful because I don’t typically communicate with something directly above or below me. But I understand your point that having a high gain antenna with the radiation directed in the wrong direction can be even worse. I also agree that a low efficiency antenna is a bad thing. Unfortunately most of us (definitely me) don’t have an easy way to assess efficiency. Real world testing like I conducted are the best I can do. WRYZ926, WRXB215 and Hoppyjr 3 Quote
WRUW493 Posted January 22, 2024 Report Posted January 22, 2024 Yes, this is all true, nicely said Sshannon. I went on and on a bit, my addiction to jabbering. Glad to hear that you tend to hold the radio vertical when using it. A lot of people do not. Have a great day SteveShannon 1 Quote
Guest Posted January 22, 2024 Report Posted January 22, 2024 My stock antennas on all my hand helds fell off at about 10-12miles. Some much less. My 771 antennas easily reach out over 20miles to one repeater and over 30to another repeater so I’d say the 771 just works better. Some one else can do all the sciency stuff and tell me how they don’t work but I know they work much better than any other I’ve tried for my hand helds. Quote
TNFrank Posted February 5, 2024 Author Report Posted February 5, 2024 From more videos that I've watched the 5/8 Smiley Duck is suppose to be 6db and be equal to the longer Nagoya 771. I ordered one for my UVD1P since the Abbree 771 didn't fit this radio properly. Knilc 1 Quote
TNFrank Posted February 16, 2024 Author Report Posted February 16, 2024 Update. Don't waste your money. I had one on my UVD1P and couldn't talk to a buddy that was only 3/4 of a mile away. The factory Wouxun antenna that came with the radio on the Baofeng UV-82 would reach him no problem and when I put the factory antenna back on the UVD1P I could reach him too so the Smiley Duck isn't worth it IMHO. WRXB215 1 Quote
back4more70 Posted February 16, 2024 Report Posted February 16, 2024 I don't have any GMRS traffic near me, so I just walk around with an HT and a dummy load and pretend WRUU653, TNFrank, WRWE456 and 2 others 1 4 Quote
SvenMarbles Posted February 26, 2024 Report Posted February 26, 2024 On 1/20/2024 at 7:56 PM, WRUW493 said: I hate to burst y'all's bubble, but the longer antenna on an HT won't help. That 771G Nagoya is a 5/8 wavelength antenna, which in order to have "gain" in the plane normal to the antenna would require a ground plane diameter of at least 1 wavelength. Obviously the radio is not that. What you really want is a simple 1/4 wavelength antenna (about 6 inches at GMRS) that has LOW LOSS, meaning it's efficient. With the GMRS HTs being also about 6 inches tall this makes for a really nice dipole antenna. A simple piece of heavy gauge copper wire would work just fine, but would not be so good mechanically. And that would not be so good for VHF, only tuned to UHF. I took a chance on this antenna and found it to be excellent since it's just a copper wire encased in flexible plastic. https://www.amazon.com/gp/product/B0855PVDWS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 You will find that Motorola uses this concept on their HT's and for a good reason: it works the best for a handheld. The bottom line: for a handheld radio, you want radiation efficiency. Any antenna that has fancy coils to tune them is by definition low efficiency. Radiation pattern make little to no difference, and radiation pattern is the only thing you get with an antenna system longer than 1/2 wave dipole. Consider that over a propagation path you have no idea what the best path is to the other station at any point in time. Consider an urban or forest environment: reflections off of a building, car, tree is frequently the best path, and that changes literally by the foot as you walk around. Hope this helps. Thanks for this.. Makes perfect sense. Simplicity, balance, and efficiency.. Have you ever messed around with pig tail counterpoising for HT antennas? If it works, I wonder why manufacturers haven’t incorporated it as a standard design.. Quote
SvenMarbles Posted February 26, 2024 Report Posted February 26, 2024 Also, the good news is that it’s GMRS that we’re discussing here. No need to “dual band” anything.. We should enjoy the luxury of only needing to target one resonant frequency “chunk” and making the best of it… For 462-467 the quarter wave, purpose cut for that specific frequency (shorter) would provide a better balanced dipole to the radio body… Knilc 1 Quote
TNFrank Posted February 26, 2024 Author Report Posted February 26, 2024 The Nagoya 701 I just picked up is GMRS tuned and is actually pretty compact. Knilc 1 Quote
WRUW493 Posted March 2, 2024 Report Posted March 2, 2024 On 2/26/2024 at 7:10 AM, WSAK691 said: Thanks for this.. Makes perfect sense. Simplicity, balance, and efficiency.. Have you ever messed around with pig tail counterpoising for HT antennas? If it works, I wonder why manufacturers haven’t incorporated it as a standard design.. Sorry for the late response. Yes, actually I have. This is a common method used on the older cell phones that had external and/or extendable antennas. In those cases there was a metal piece inside the phone that was tuned to 1/4 wave (at the lower freq band if there were multiple bands in use) that ran down the edge or side of the phone.) We would try to put it in an area where the hand was not likely to cover it (much) or come near the face when being held against the face. I have not tried it on a GMRS radio, but RF doesn't know anything about the name of the device of course, just the frequency that is being used and Maxwell's electromagnetics still works. To WSAK691 who also mentioned a 1/4 wave antenna being good: bingo. Get the total system to be a 1/2 wave dipole and you'll get a nice donut radiation pattern that on AVERAGE is going to radiate the best to the radio you are trying to talk to. If possible have both radios held vertically so as to match the polarization as much as possible. At 460MHz there is some cross polarization taking place depending on the propagation path. The good news is outdoor environments are not likely to have as much cross polarization as indoors, so you'll get best distance outdoors with co-polarized hand held orientations. It's a subtle difference, but vertical is less impacted by ground (earth) effects that horizontal is at these frequencies, and holding the radio vertical is going to minimize the ground impact. Hope this helps Knilc 1 Quote
