I'd like to eliminate my 2-25' sections of coax (One section is Andrew Heliax LDF4-50a and the other Andrew Heliax FSJ4-50b connected with good N connectors) and searching, I came across the TXM cable, which I have never heard of. The specs are about identical to the Andrew FSJ4-50b but a lot less money so I was wondering if anyone here has used or is currently using it on their repeater setup, and how it's working out.
Flameout
https://www.txmstore.com/1-2-super-flexible-50-ohm-coax-cable-per-foot-compare-to-commscope-fsj4-50b-spf12/
It will feed my Commscope DB404 from my Motorola Radius GR500 repeater
Link to comment
Share on other sites
17 answers to this question
