WSAW350 Posted March 2, 2024 Report Posted March 2, 2024 In the process of putting together a base station setup (first time), just wondered if making the cable is preferable to buying it already made. And what is the maximum length of coax you're comfortable with as far as signal loss? Is 50' too long for your tastes? Quote
SvenMarbles Posted March 2, 2024 Report Posted March 2, 2024 For GMRS, a 50ft run is what I'm comfortable with. It's at that point that I'd want to bring my radio nearer rather than run more coax. Buy "KMR-400" from Amazon. MookieRF. Get the 50ft piece. Quote
SvenMarbles Posted March 2, 2024 Report Posted March 2, 2024 1.4 DB loss at 50 ft on a 400 coax. Bit under 25%.. Then do a gain antenna to get it back.. Raybestos and WSAW350 2 Quote
Guest Posted March 2, 2024 Report Posted March 2, 2024 Depends on your radio watts and gain on the antenna. I have a 20w base with a 9db antenna and run 50’ of Lmr400. I get over 200miles. So I’m good at 50. Had no issues with 35milrs on a 5w hand held. Quote
WRUE951 Posted March 2, 2024 Report Posted March 2, 2024 if you are pulling wire through walls etc. make your own.. not that difficult to make the connectors, lots of videos on-line that shows some neat tricks making them... Quote
WSAM454 Posted March 2, 2024 Report Posted March 2, 2024 If you are concerned about cable loss, take a look at the 7th reference table here: https://0f03806ff3d3e74e9602-196c53d60dd8027754ef96352b4703ae.ssl.cf2.rackcdn.com/Magento/Live/Misc/m&p_vs_coax.pdf Not inexpensive, but the M and P cables currently have the lowest loss of the 'flexible' (not hardliine) cables available. As WSAK691 said, the LMR loss for 50 feet would be about 25%, and can be made up with a good gain antenna to actually get you over the initial output power of your radio. WSAW350 1 Quote
WSAW350 Posted March 2, 2024 Author Report Posted March 2, 2024 ^^^^^^^^^ So it appears that Messi & Paoloni's Ultraflex 10 can out perform LMR400 coax in the loss department. And it looks to be $95 at Buy Two Way Radios for a 50' length. Thanks for posting the PDF. Quote
SvenMarbles Posted March 2, 2024 Report Posted March 2, 2024 12 minutes ago, WSAW350 said: ^^^^^^^^^ So it appears that Messi & Paoloni's Ultraflex 10 can out perform LMR400 coax in the loss department. And it looks to be $95 at Buy Two Way Radios for a 50' length. Thanks for posting the PDF. I see it as nearly the same, maybe SLIGHTLY worse actually. But it has the added benefit of the more manageable cable... Quote
nokones Posted March 2, 2024 Report Posted March 2, 2024 I wouldn't buy any cable from Amazon. Go with M&P or Times Mirror. WSAW350, SteveShannon, WSAM454 and 2 others 5 Quote
WSAA254 Posted April 10, 2024 Report Posted April 10, 2024 I went with DX-engineering "build your own" cable. If your building alot, then maybe getting the correct tools etc would be worth it. If your just doing 1 or 2 then have it built. You can also pick the type of connector for any given cable. Just my 2 cents, best of luck. WRYZ926 and SteveShannon 2 Quote
nokones Posted April 10, 2024 Report Posted April 10, 2024 1 hour ago, WSAA254 said: I went with DX-engineering "build your own" cable. If your building alot, then maybe getting the correct tools etc would be worth it. If your just doing 1 or 2 then have it built. You can also pick the type of connector for any given cable. Just my 2 cents, best of luck. DX Engineering would be a good source to work with. SteveShannon, WRYZ926 and WSAA254 3 Quote
