WRXB215 Posted May 13, 2024 Report Posted May 13, 2024 21 minutes ago, koni13 said: although like the compact size to the 5 Same. koni13 1 Quote
Guest Posted May 13, 2024 Report Posted May 13, 2024 36 minutes ago, koni13 said: I have a set of Baofeng UV82 and appears working nicely once programming with Chirp software. Anyone care to add comments and or experience with this radio, sense an upgrade from the UV-5R although like the compact size to the 5. You opened up a can of worms for the sad ham, sad gmrs guys. You’re going to get the “it’s not a gmrs radio” ect blah blah. Also going to get the “cheap Chinese junk” guys. And the hyt receiver guys However It’s a fine radio and it works and transmits just as far as any other. If it has the feel, quality, features and budget YOU need and does the job you need it to do then great. I’m all for it. Send it and use it and let us know who it works. Quote
koni13 Posted May 14, 2024 Report Posted May 14, 2024 21 hours ago, WRXP381 said: You opened up a can of worms for the sad ham, sad gmrs guys. You’re going to get the “it’s not a gmrs radio” ect blah blah. Also going to get the “cheap Chinese junk” guys. And the hyt receiver guys However It’s a fine radio and it works and transmits just as far as any other. If it has the feel, quality, features and budget YOU need and does the job you need it to do then great. I’m all for it. Send it and use it and let us know who it works. 21 hours ago, WRXP381 said: You opened up a can of worms for the sad ham, sad gmrs guys. You’re going to get the “it’s not a gmrs radio” ect blah blah. Also going to get the “cheap Chinese junk” guys. And the hyt receiver guys However It’s a fine radio and it works and transmits just as far as any other. If it has the feel, quality, features and budget YOU need and does the job you need it to do then great. I’m all for it. Send it and use it and let us know who it works. Quote
koni13 Posted May 14, 2024 Report Posted May 14, 2024 Being new to the GMRS field, based on reviews my options were both the UV82 or UV5r radios. Issues at the time were backlog with orders so opted ordering the UV82 radios. So far having programmed on chirp and for usage on the farm, appears doing well for both receiving and communications on the property. WRXB215 1 Quote
OffRoaderX Posted May 14, 2024 Report Posted May 14, 2024 1 hour ago, koni13 said: Being new to the GMRS field, based on reviews my options were both the UV82 or UV5r radios You know those are H.A.M. radios and not GMRS radios, right? Unless you UNLocked the UV-82 and got the UV-5R "GMRS Edition" ? Quote
koni13 Posted May 14, 2024 Report Posted May 14, 2024 Almost all GMRS radios also support FRS frequencies, which can be used without a license. Channels 8-14 on a typical 22 channel consumer radio reserved exclusively for FRS. These channels can be used license-free, but are limited to a half watt of transmit power and will have limited range. The GMRS is available to an individual for short-distance two-way communications to facilitate the activities of licensees and their immediate family members. Each licensee manages a system consisting of one or more transmitting units (stations.) The rules for GMRS limit eligibility for new GMRS system licenses to individuals in order to make the service available to personal users. So if yes unlocked the radios will transmit establishing open communications and ensuring the operator has a established license and follows FCC rules. TrikeRadio 1 Quote
SteveShannon Posted May 14, 2024 Report Posted May 14, 2024 13 minutes ago, koni13 said: Almost all GMRS radios also support FRS frequencies, which can be used without a license. Channels 8-14 on a typical 22 channel consumer radio reserved exclusively for FRS. These channels can be used license-free, but are limited to a half watt of transmit power and will have limited range. The GMRS is available to an individual for short-distance two-way communications to facilitate the activities of licensees and their immediate family members. Each licensee manages a system consisting of one or more transmitting units (stations.) The rules for GMRS limit eligibility for new GMRS system licenses to individuals in order to make the service available to personal users. So if yes unlocked the radios will transmit establishing open communications and ensuring the operator has an established license and follows FCC rules. The 22 FRS frequencies are exactly the same as the first 22 GMRS frequencies. There’s absolutely no difference in the frequencies but there are differences in the power limits. None of the 22 are reserved exclusively for FRS. amaff, WRZD727, OffRoaderX and 2 others 2 3 Quote
OffRoaderX Posted May 14, 2024 Report Posted May 14, 2024 34 minutes ago, koni13 said: Almost all GMRS radios also support FRS frequencies, which can be used without a license. Channels 8-14 on a typical 22 channel consumer radio reserved exclusively for FRS. These channels can be used license-free, but are limited to a half watt of transmit power and will have limited range. The GMRS is available to an individual for short-distance two-way communications to facilitate the activities of licensees and their immediate family members. Each licensee manages a system consisting of one or more transmitting units (stations.) The rules for GMRS limit eligibility for new GMRS system licenses to individuals in order to make the service available to personal users. So if yes unlocked the radios will transmit establishing open communications and ensuring the operator has an established license and follows FCC rules. If there was supposed to be a point in there, you failed in addition to being wrong. Quote
dosw Posted May 14, 2024 Report Posted May 14, 2024 1 hour ago, koni13 said: Almost all GMRS radios also support FRS frequencies, which can be used without a license. Channels 8-14 on a typical 22 channel consumer radio reserved exclusively for FRS. These channels can be used license-free, but are limited to a half watt of transmit power and will have limited range. The GMRS is available to an individual for short-distance two-way communications to facilitate the activities of licensees and their immediate family members. Each licensee manages a system consisting of one or more transmitting units (stations.) The rules for GMRS limit eligibility for new GMRS system licenses to individuals in order to make the service available to personal users. So if yes unlocked the radios will transmit establishing open communications and ensuring the operator has a established license and follows FCC rules. Let's take that assertion by assertion: "Almost all GMRS radios also support FRS frequencies..." That would be true if you said that GMRS and FRS share the same frequencies entirely, except that FRS radios can't transmit on the repeater input frequencies. All current GMRS handheld radios support all FRS frequencies. FRS and GMRS use all of the same frequencies except for repeaters. GMRS mobile can't transmit on 8-14. "Channels 8-14 on a typical 22 channel consumer radio are reserved exclusively for FRS" That's just incorrect. GMRS handheld radios may transmit on all 22 channels so long as they don't exceed 500mw on 8-14 and stay narrowband on 8-14, or 5w on 1-7. Only handheld GMRS may transmit on 8-14 (and FRS). No mobiles. But GMRS handhelds are fine. Look it up. I did. "These channels can be license-free, ..." No. If you are operating a handheld GMRS radio on any GMRS channel, any of the 22, including 8-14, you are supposed to be licensed. If you are operating an FRS radio on those channels, you don't need a license. "So if yes unlocked the radios will transmit establishing open communications and ensuring the operator has a established license and follows FCC rules. " I can't quite make sense of what you're saying there. But an unlocked amateur radio isn't supposed to be used for GMRS. I'm talking about what is authorized, not what is possible, and not what is enforced. There's really nobody enforcing the use of a handheld ham radio that's been unlocked for GMRS, so long as it's following power limit rules, and not being used to cause a lot of trouble. But according to the rules of the FCCs, you're not supposed to use an unlocked device for GMRS. This is clear in the FCC spec. In practice, those who use any radio for GMRS, stay conformant in terms of bandwidth, power levels, frequency centers, and the stipulation that 8-14 is for handheld, not mobile, nobody really seems to actually care enough to try to enforce whether the radio was unlocked or not. koni13, Pilot4prophet, TrikeRadio and 1 other 3 1 Quote
back4more70 Posted May 14, 2024 Report Posted May 14, 2024 55 minutes ago, WRQW589 said: But according to the rules of the FCCs, you're not supposed to use an unlocked device for GMRS. This is clear in the FCC spec. Me and my Yaesu FTM-6000 with the MARS mod Raybestos, WRXR255, amaff and 2 others 3 2 Quote
koni13 Posted May 14, 2024 Report Posted May 14, 2024 Thanks for all the feeds good thing have attained a GMRS license. Earlier in the thread was alerted, having opened up a can of worms for the Ham, GMRS, HYT receiver guys alerting whom would define “it’s not a GMRS radio” should have listened.... oh well. In my opinion as a newbie sense a great addition radio, which works and transmits just as far as other more expensive brands. Ya'll have a good one, again thanks has been an entertaining topic of discussion. Quote
nokones Posted May 21, 2024 Report Posted May 21, 2024 I wouldn't overlook the Midland GXT67 Pro for a GMRS Handheld Portable radio. It would be a better quality radio, than any CCR. Just so you know, it's a simple radio with very few features but definitely will get the job done better in performance. And, you can ask the GMRS queen. SteveShannon and gortex2 1 1 Quote
WRXB215 Posted May 21, 2024 Report Posted May 21, 2024 3 hours ago, nokones said: better in performance I don't doubt that it's better but I do question whether or not it's 10 times better. amaff 1 Quote
nokones Posted May 22, 2024 Report Posted May 22, 2024 20 hours ago, WRXB215 said: I don't doubt that it's better but I do question whether or not it's 10 times better. Ok, maybe not 10 times better but it is close. Quote
FlatTop Posted June 22, 2024 Report Posted June 22, 2024 I have some GM-30's. They are prob not the best but they work for us. They were cheap, not Baofeng cheap, but close enough. Quote
WRDJ205 Posted June 22, 2024 Report Posted June 22, 2024 2 hours ago, JoCoBrian said: I have some GM-30's. They are prob not the best but they work for us. They were cheap, not Baofeng cheap, but close enough. I agree. The Baofeng equivalent is the GM-15 Pro. They use the same programming software. I’ve had good service with the GM-15 Pros. Quote
WRZD727 Posted July 7, 2024 Report Posted July 7, 2024 I’m using a Wouxun KG 905G. It’s basic HT with no bells & whistles, but suits my needs and works great. If I was to buy another one, I’d get the 935G. SteveShannon 1 Quote
WRYC373 Posted July 8, 2024 Report Posted July 8, 2024 The best GMRS radio is the one that fits your needs. There are so many decent GMRS radios now. And so many companies are investing R&D into GMRS and Ham radios currently its great so look up specs and watch some reviews and then decide. Also remember if you can stand a little to a lot of nonsense used UHF Part 90 HTs are often an amazing value just ensure if you buy one it comes with a charger and battery and its software is available. SteveShannon and amaff 2 Quote
kg4kpg Posted July 29, 2024 Report Posted July 29, 2024 For me, it's the TD-H8. Super easy to program, reasonable price and does great on our local repeater. I was talking back and forth with a buddy on the repeater, first he was using his Wouxun, then switched to his TD-H8, he was a lot clearer on the H8. TrikeRadio 1 Quote
Gunsmokenyc Posted July 30, 2024 Report Posted July 30, 2024 I go back and fourth between 3 radios, 2 Wouxun radios which are KG-905G, and one I just got the Wouxun KG-935G Plus, lastly my TD-H8. The TD-H8 has very clear audio. When I pair my TD-HD with a Nagoya 771G or my 701G which is the shorter variation, I get excellent results. I use the Wouxun KG-935G because I work at a summer camp and I'm outside all day in all types of weather, especially the florida heat . I at times bring my TD-H8 with me. WSGC763 1 Quote
steved28 Posted August 14, 2024 Report Posted August 14, 2024 My favorites would be the Vertex Standard radios or Kenwood, something like the TK-380. The caveat is that you need the software and cabling to program them. I always found these lines as good if not better than a Motorola, and less expensive to buy and program. I have had some for 20+ years. Obviously we are talking about the used market here. Quote
WRXW653 Posted August 17, 2024 Report Posted August 17, 2024 I love my BTECH GMRSPro for many reasons. Quote
brasda91 Posted January 3 Report Posted January 3 On 7/29/2024 at 8:59 PM, Gunsmokenyc said: I go back and fourth between 3 radios, 2 Wouxun radios which are KG-905G, and one I just got the Wouxun KG-935G Plus, lastly my TD-H8. The TD-H8 has very clear audio. When I pair my TD-HD with a Nagoya 771G or my 701G which is the shorter variation, I get excellent results. I use the Wouxun KG-935G because I work at a summer camp and I'm outside all day in all types of weather, especially the florida heat . I at times bring my TD-H8 with me. I have the 905G and I just bought the battery adapter for my truck, and now I have seen the 935G+. Part of me says "heck yeah new radio" and the other part of me says the 905G is fine and does what I need it to do. What is the arguement for the 935G+ ? Quote
brasda91 Posted January 3 Report Posted January 3 On 7/7/2024 at 3:26 PM, WRZD727 said: I’m using a Wouxun KG 905G. It’s basic HT with no bells & whistles, but suits my needs and works great. If I was to buy another one, I’d get the 935G. This post right here is what will get me in trouble. I too have the 905G and I'm trying to talk myself out of the 935G Quote
