UncleYoda Posted August 10, 2024 Report Posted August 10, 2024 Since the jokers here want to bury this with down votes in Technical Discussion, posting here instead. Some users try to stay "legal" while the enforcement agency still exists. The fact that someone you're talking to doesn't know what type of setup you're using (unless they ask, which they often do at least on HAM) doesn't make it OK. The rationale that you're not likely to get caught can be used for many other things if you choose to take the risk. But that won't-get-caught approach is not how our system of government is intended to operate. Quote
marcspaz Posted August 10, 2024 Report Posted August 10, 2024 I'm sorry bud... you're just wrong and people are messing with you because you won't let it go. I certainly won't give anyone grief for following the rules, but its not illegal or against the rules to talk to people through a repeater from a radio in your house. It's not a matter of people snubbing their nose at the rules, but the fact that what you are saying is not only wrong, but unenforceable for reasons presented elsewhere. You starting another thread isn't going to make it any less wrong. WRXB215, AdmiralCochrane, WSAK388 and 3 others 5 1 Quote
Guest Posted August 10, 2024 Report Posted August 10, 2024 1 hour ago, UncleYoda said: Since the jokers here want to bury this with down votes in Technical Discussion, posting here instead. Some users try to stay "legal" while the enforcement agency still exists. The fact that someone you're talking to doesn't know what type of setup you're using (unless they ask, which they often do at least on HAM) doesn't make it OK. The rationale that you're not likely to get caught can be used for many other things if you choose to take the risk. But that won't-get-caught approach is not how our system of government is intended to operate. What? And? Here’s another down vote 55 minutes ago, marcspaz said: I'm sorry bud... you're just wrong and people are messing with you because you won't let it go. I certainly won't give anyone grief for following the rules, but its not illegal or against the rules to talk to people through a repeater from a radio in your house. It's not a matter of people snubbing their nose at the rules, but the fact that what you are saying is not only wrong, but unenforceable for reasons presented elsewhere. You starting another thread isn't going to make it any less wrong. Yup. Here’s your up vote. Quote
WRUU653 Posted August 10, 2024 Report Posted August 10, 2024 Some people just got to create an imaginary problem where none exists. An endless debate of an issue that isn’t. Quote
WRYZ926 Posted August 10, 2024 Report Posted August 10, 2024 And what kind of oil should I be using to lube the antenna mast bolts???? The cat is out of the bag as far as people using unlocked/modified radios and the different services. As long as they aren't doing anything to draw attention to themselves or causing issues for other people, then no one will know any different. Quote
OffRoaderX Posted August 10, 2024 Report Posted August 10, 2024 37 minutes ago, WRYZ926 said: As long as they aren't doing anything to draw attention to themselves or causing issues for other people, then no one will know any different. THIS IS NOT TRUE!!!!1 STOP LYING!!! if you use an illegal radio the FCC will triangulate your position and WILL issue a $10,000 fine or you could face prison! Its your choice to take the risk! ...i have literally seen "licensed ham-radio operators" tell people this online, so it MUST be true.. because they have a license! WRYZ926, RodB, WSAK388 and 4 others 1 6 Quote
WRXR255 Posted August 10, 2024 Report Posted August 10, 2024 22 minutes ago, OffRoaderX said: THIS IS NOT TRUE!!!!1 STOP LYING!!! if you use an illegal radio the FCC will triangulate your position and WILL issue a $10,000 fine or you could face prison! Its your choice to take the risk! ...i have literally seen "licensed ham-radio operators" tell people this online, so it MUST be true.. because they have a license! Do you know where i can source a fake FCC license? Haven't had to think about a fake ID since I turned 21, so its been a while. All my sources from way back then are in jail. GreggInFL 1 Quote
SteveShannon Posted August 10, 2024 Report Posted August 10, 2024 33 minutes ago, WRXR255 said: Do you know where i can source a fake FCC license? Haven't had to think about a fake ID since I turned 21, so its been a while. All my sources from way back then are in jail. I can do better than that. For the low price of $35 you can get a real one! kirk5056, GreggInFL, WRXR255 and 1 other 3 1 Quote
WRXR255 Posted August 10, 2024 Report Posted August 10, 2024 31 minutes ago, SteveShannon said: I can do better than that. For the low price of $35 you can get a real one! I tried to go that route, but the links on the FCC website kept taking me here: https://cl.gy/XWop Quote
SteveShannon Posted August 10, 2024 Report Posted August 10, 2024 Just now, WRXR255 said: I tried to go that route, but the links on the FCC website kept taking me here: https://cl.gy/XWop I don’t dare look!!! WRUU653 1 Quote
marcspaz Posted August 10, 2024 Report Posted August 10, 2024 1 minute ago, SteveShannon said: I don’t dare look!!! I may have been born at night, but it wasn't last night. LoL WRUU653 and SteveShannon 2 Quote
nokones Posted August 10, 2024 Report Posted August 10, 2024 2 hours ago, WRYZ926 said: And what kind of oil should I be using to lube the antenna mast bolts???? The cat is out of the bag as far as people using unlocked/modified radios and the different services. As long as they aren't doing anything to draw attention to themselves or causing issues for other people, then no one will know any different. Pouring oil on tower bolts and guy wires is not a joke. Regular 30w got the job done to eliminate intermod at a couple of sites. If you need the name of those two sites, I'll be more than happy to provide them. Quote
WRUE951 Posted August 10, 2024 Report Posted August 10, 2024 5 hours ago, marcspaz said: I'm sorry bud... you're just wrong and people are messing with you because you won't let it go. I certainly won't give anyone grief for following the rules, but its not illegal or against the rules to talk to people through a repeater from a radio in your house. It's not a matter of people snubbing their nose at the rules, but the fact that what you are saying is not only wrong, but unenforceable for reasons presented elsewhere. You starting another thread isn't going to make it any less wrong. certainly a growing number of idiots willing to take a risk so you can talk to someone from your living room in New York to a friend in Penn. (hypothetically speaking of course, for you anyway). Some guys have 25-30 repeaters registered under their lic. Of course, since you and your friend (hypothetically) are talking 100's of miles apart, you have no clue how that is happening.. It's pure FM - right??? gortex2 1 Quote
OffRoaderX Posted August 10, 2024 Report Posted August 10, 2024 45 minutes ago, WRUE951 said: certainly a growing number of idiots willing to take a risk so you can talk to someone from your living room Considering that the risk is about 99.99999999999999999999999999999999998% in everyone's favor of NOT "getting caught", you'd have to be an idiot to not take that risk. and it is likely that very few "normal" people would even consider those odds a "risk" at all.. SteveShannon, marcspaz and AdmiralCochrane 3 Quote
WRKC935 Posted August 11, 2024 Report Posted August 11, 2024 WTF is this even about? Yoda posts some crap about another post getting voted down, that I can't seem to even find in the other forum. SO we are now discussing that post over here because WHY? Quote
WRYZ926 Posted August 11, 2024 Report Posted August 11, 2024 3 hours ago, nokones said: Pouring oil on tower bolts and guy wires is not a joke. Regular 30w got the job done to eliminate intermod at a couple of sites. If you need the name of those two sites, I'll be more than happy to provide them. It was a Joke, I say a joke son. ---- Foghorn Leghorn I brought up oil since the subject usually starts arguments on any and all automotive, watercraft, and firearm forums. And yes I know the importance of when and where to use the proper types of lubricant oils since I am a retired machinist and millwright. 5 hours ago, OffRoaderX said: THIS IS NOT TRUE!!!!1 STOP LYING!!! if you use an illegal radio the FCC will triangulate your position and WILL issue a $10,000 fine or you could face prison! Its your choice to take the risk! ...i have literally seen "licensed ham-radio operators" tell people this online, so it MUST be true.. because they have a license! But but but,, I heard it in a YouTube video and read it on forums so it must be true! I hear rumors that the Wouxun KG-Q10H quad band HT can actually be unlocked to also work well on MURS and GMRS. But I wouldn't know anything about that. WRUU653 1 Quote
WRUE951 Posted August 11, 2024 Report Posted August 11, 2024 2 hours ago, OffRoaderX said: Considering that the risk is about 99.99999999999999999999999999999999998% in everyone's favor of NOT "getting caught", you'd have to be an idiot to not take that risk. and it is likely that very few "normal" people would even consider those odds a "risk" at all.. Thats your opinion Randy..... Not always a safe one.. Sounds like your are promoting rule breaking,,, Are you? gortex2 1 Quote
OffRoaderX Posted August 11, 2024 Report Posted August 11, 2024 17 minutes ago, WRUE951 said: Thats your opinion Randy..... Not always a safe one.. Sounds like your are promoting rule breaking,,, Are you? It's not an opinion. it is fact based on the FCC's public (lack of) enforcement record. What I am doing is telling people to use their own brains and try not to be brainwashed bootlickers ALL the time. But if i do decide to promote rule-breaking I'll be sure to tell you first so we can watch you cry about it. mmhkay? WRXB215, kirk5056, marcspaz and 5 others 2 6 Quote
WRUE951 Posted August 11, 2024 Report Posted August 11, 2024 1 hour ago, OffRoaderX said: It's not an opinion. it is fact based on the FCC's public (lack of) enforcement record. And the Circus was created. I won't go as far to call you a 'Ring Leader' gortex2 1 Quote
WRYZ926 Posted August 11, 2024 Report Posted August 11, 2024 The FCC is like any other government agency, You can ask 10 agents the same exact question and get 20 different answers. Sometimes it will depend on time of day or day of the week on what answer you get. I dealt with that back when I had my FFL when talking to the ATF. Most will never get into trouble if they are NOT drawing any attention to themselves. CB is a perfect example. That band is limited to 4 watts output power but plenty of people use amplifiers and it is actually pretty rare that someone gets fined by the FCC for that. Those that we do see get into trouble were doing something to draw the FCC's attention or did something do get law enforcement to investigate . I am not condoning or condemning those that disregard FCC rules and regulations. It is well known that as long as you aren't causing any issues and/or drawing attention to yourself then the FCC will never bother you. One can look at the public records concerning FCC enforcement to see this is true. Amateur radio, GMRS, and CB operators are actually pretty low on the FCC's priority list. Quote
nokones Posted August 11, 2024 Report Posted August 11, 2024 10 hours ago, WRUE951 said: And the Circus was created. I won't go as far to call you a 'Ring Leader' Randy is several levels above a Ring Leader. Quote
nokones Posted August 11, 2024 Report Posted August 11, 2024 When "Some People" call a government agency and seek an answer for their question, in most cases they don't know how to properly address the question in the proper context. Quote
WRQC527 Posted August 11, 2024 Report Posted August 11, 2024 20 minutes ago, nokones said: When "Some People" call a government agency and seek an answer for their question, in most cases they don't know how to properly address the question in the proper context. I'm sure you have examples and statistics to back up this claim. Share with us, won't you? Quote
marcspaz Posted August 11, 2024 Report Posted August 11, 2024 1 hour ago, WRYZ926 said: Amateur radio, GMRS, and CB operators are actually pretty low on the FCC's priority list. There is no money in it. Quote
WRUE951 Posted August 11, 2024 Report Posted August 11, 2024 1 hour ago, nokones said: Randy is several levels above a Ring Leader. Sounds like you met Randy via the Grindr app Quote
