WSGD716 Posted December 26, 2024 Report Posted December 26, 2024 My two GMRS radios can connect to the repeater and communicate with other users, but they cannot hear each other. Even when I took both radios 100 meters from the repeater, they still couldn't hear each other. Both radios are identical, and I used the programming software to update them with the same settings. I have even replaced my radios, thinking that might resolve the issue. · Radioddity GM-30 Plus GMRS Radio (current one) Here are my channels 23 to 30 settings which I got permission for: Channel Frequency Name Tone 23 462.5500 / 467.5500 RPT-1 GCR 550 Spanish Fort 141.3 Hz / 141.3 Hz 24 462.5750 / 467.5750 RPT-2 GCR 575 Semmes 100 / 100 Hz 25 462.6000 / 467.6000 RPT-3 GCR 600 Perdido Beach 141.3 Hz / 141.3 Hz 26 462.6250 / 467.6250 RPT-4 GCR 625 BAY MINET 141.3 Hz / 141.3 Hz 27 462.6500 / 467.6500 RPT-5 GCR 650 Fairhope 67.0 Hz / 67.0 Hz 28 462.6750 / 467.6750 RPT-6 GCR 725 New Orleans 141.3 Hz / 141.3 Hz 29 462.7000 / 467.7000 RPT-7 Spanish Fort Hgh School 141.3 Hz / 141.3 Hz 30 462.7250 / 467.7250 RPT-8 GCR 725 Theodore, Al 141.3 Hz / 141.3 Hz I appreciate any suggestions you may have. Quote
0 OffRoaderX Posted December 26, 2024 Report Posted December 26, 2024 How far apart are the two radios from each other when you are testing? AdmiralCochrane 1 Quote
0 WSGD716 Posted December 26, 2024 Author Report Posted December 26, 2024 At 20 feet (6 meters), I watched your video about the radios' distance on YouTube and can try increasing the distance. How about 100 feet (30 meters)? Thank you Quote
0 OffRoaderX Posted December 26, 2024 Report Posted December 26, 2024 Yes, try to get more farz apart. If that fails, try removing the RX tones on both radios. AdmiralCochrane 1 Quote
0 WSGD716 Posted December 26, 2024 Author Report Posted December 26, 2024 Sure, I'll proceed with these tests. Thanks! Quote
0 WRYZ926 Posted December 26, 2024 Report Posted December 26, 2024 I've tested hand held radios in different rooms that are next to each other without issues. Normally a wall is enough to keep two hand held from defensing each other. If not then get more distance between the two radios. If more distance between the radios and/or turning the RX tones off does not help, then you will want to double and triple check the settings on the two radios and on the repeater. SteveShannon 1 Quote
0 AdmiralCochrane Posted December 27, 2024 Report Posted December 27, 2024 Dear Siri, I am tired of your shirt WRUE951 and SteveShannon 1 1 Quote
0 WSGD716 Posted December 28, 2024 Author Report Posted December 28, 2024 Troubleshooting feedback: I was able to get my Radioddity GM-30 Plus working successfully with the Mobile 675 * repeater in Mobile, AL: Home to GCR 675 - RPT - Mobile, AL = 16.85 mi (27.12 km) Frequency: 462.675/467.675 MHz Output Tone: 141.3 Hz /Input Tone: 141.3 Hz / Estimated Range: 50 Miles On my first try, the radios worked 284.02 ft (86.57 m) apart; on the second attempt, they connected at a distance of 1.68 mi (2.71 km). Both tests were done using a small antenna. However, I’m still trying to understand why the other repeaters didn’t work, despite being within the coverage area for GCR 550 Spanish Fort and GCR 650 Fairhope. Could a Baofeng UV-5G Plus offer a stronger signal and better performance? Home to GCR 550 - RPT - Spanish Fort, AL = 7.89 mi (12.70 km) Home to GCR 650 – RPT – Fairhope, AL = 5.39 mi (8.68 km) Here are my channels 23 to 30 settings which I got permission for: Channel Frequency Name Tone 23 462.5500 / 467.5500 RPT-1 GCR 550 Spanish Fort 141.3 Hz / 141.3 Hz 24 462.5750 / 467.5750 RPT-2 GCR 575 Semmes 100 / 100 Hz 25 462.6000 / 467.6000 RPT-3 GCR 600 Perdido Beach 141.3 Hz / 141.3 Hz 26 462.6250 / 467.6250 RPT-4 GCR 625 BAY MINET 141.3 Hz / 141.3 Hz 27 462.6500 / 467.6500 RPT-5 GCR 650 Fairhope 67.0 Hz / 67.0 Hz *28 462.6750 / 467.6750 RPT-6 Mobile 675, Mobile, AL 141.3 Hz / 141.3 Hz (WORKED FINE!) 29 462.7000 / 467.7000 RPT-7 Spanish Fort Hgh School 141.3 Hz / 141.3 Hz 30 462.7250 / 467.7250 RPT-8 GCR 725 Theodore, Al 141.3 Hz / 141.3 Hz I sincerely appreciate all your suggestions and insights. Thank you! Quote
0 AdmiralCochrane Posted December 28, 2024 Report Posted December 28, 2024 "Coverage area" is only an guesstimation. Anything that remotely resembles a wall (even trees, but especially hills) will block radio waves in the GMRS/UHF frequency range. WRUE951 1 Quote
0 JJM Posted December 29, 2024 Report Posted December 29, 2024 "connectivity issues" lol Nerd. What you're experiencing is called "defense". They'll hear each other just fine when used as they normally word be. In other words: when they're not in the same room. As for the repeater issue: coverage area is a guesstimate and lots of factors influence it. Terrain, weather, atmospheric conditions, etc. Try a better antenna or move closer to the repeater. Quote
0 WRYS709 Posted December 29, 2024 Report Posted December 29, 2024 1 hour ago, JJM said: What you're experiencing is called "defense". Some of us refer to it as: "desense!" Picky, Picky, Picky! AdmiralCochrane, SteveShannon and amaff 3 Quote
0 WRYS709 Posted December 29, 2024 Report Posted December 29, 2024 22 hours ago, WSGD716 said: Troubleshooting feedback: ... I sincerely appreciate all your suggestions and insights. Thank you! Take your Radioddity GM-30 for a road trip! Quote
0 AdmiralCochrane Posted December 29, 2024 Report Posted December 29, 2024 2 hours ago, WRYS709 said: Some of us refer to it as: "desense!" Picky, Picky, Picky! Like I said, I'm tired of Siri's shirt JJM and SteveShannon 1 1 Quote
0 JJM Posted January 12 Report Posted January 12 On 12/29/2024 at 1:42 PM, WRYS709 said: Some of us refer to it as: "desense!" Picky, Picky, Picky! autocorrect did me dirty. AdmiralCochrane 1 Quote
WSGD716
13 answers to this question
