WRYS709 Posted January 18 Report Posted January 18 At long last... RT Systems has delivered their $25 (download) software for the DB20-G/AT-779UV mini mobile radios (Version 5.00.04). It orders easily from their website and installs easily into Windows (11 in my case) and works with my USB to RJ-45 cable. RT indicates that the delay to engineer this software was due to some "incompatibility" in the OEM USB cable wiring, but indicates that it works with the OEM USB cables. I suggest that they may have been using the original Anytone USB cables, which has Windows 10 and 11 issues. But both Radioddity and newer Anyones now have an updated USB cable (albeit it looks exactly the same as the legacy Anytone cable!). RT does sell its own USB to RJ-45 cable for these radios, either separately or as a bundled combo. It is currently only available for Windows 8 and above. I have imported my current codeplug into their software very easily, saved it and now will begin the process of exploring it capabilities. For years, I have kept a CSV (Comma-Separated-Values) file as a master list of all of those frequencies I want to use in some or all of my various wireless radios. It easily opens in Microsoft Excel and now with the RT Systems CPS software, I can "import" and/or copy/paste these channels at will. This software now plugs the major hole that these wonderful radios had since their release. My other minor concern is that they do not "tone scan" but a $22 Baofeng UV-13Pro Ham Radio took care of that problem for me. If anyone has specific operational questions, shoot them at me, and I will be happy to test them out! NOTE: There is another new thread on this topic that insists on using the "Technical Discussion" - "sort by votes" system of discussion, which I abhor! These posts are all about date relevance and I, for one, do not want to subject other's posts, to be "down-voted" and hence pushed to the bottom of the thread. This is radio technology; not a popularity contest! Enjoy! tcp2525 and SteveShannon 2 Quote
WRYS709 Posted January 19 Author Report Posted January 19 I have converted my GMRS Part 95E code plug to the new RT System software. This code plug allows the user to "open" their DB20-G or AT-779UV and yet restore full Part 95E compatibility and restrictions See this post to open your radio: AT-779UV GMRS 202501191140.AT779UV Quote
WRYS709 Posted January 20 Author Report Posted January 20 On 1/18/2025 at 3:17 AM, tcp2525 said: Cool! RT comes to the rescues once again. I'm just curious of what problems they are talking about with the cable? My OEM cable always worked flawlessly. From their site, "For a long while we could not get into this radio for programming only to find out the cable that came with the radio was not right for that purpose." RT Systems is referring to how the OEM USB cable, while wired correctly for the purposes of the radio communicating with their CPS software, was not properly wired for the purposes of reverse engineering how their software communicates with the computer. Quote
SvenMarbles Posted January 20 Report Posted January 20 I figured out the eccentricities of Radioddity's own program. It actually works fine. When you set CTCSS/DCS tones, you also have to change the squelch method as well.. Quote
WRYS709 Posted January 20 Author Report Posted January 20 21 hours ago, UncleYoda said: I'm assuming you didn't try it in GMRS mode. It seems like it would be most useful for people switching back and forth which requires reloading all the channels. I reset my Anytone to US-GMRS, and downloaded the radio into RT Systems for you to view and even use the attached RTS code plug, as you desire: AT-779UV GMRS.default 202501191600.AT779UV Quote
WRYS709 Posted January 20 Author Report Posted January 20 24 minutes ago, SvenMarbles said: I figured out the eccentricities of Radioddity's own program. It actually works fine. When you set CTCSS/DCS tones, you also have to change the squelch method as well.. Actually the Radioddity software, for free, is very versatile; but is very limited in capabilities for: import, export and copy & paste. So the RT Systems addition Is now very welcome! As to your noted point, yes, once you use the Radioddity software to change Tones, it is helpful to change the Squelch setting to match as well. Quote
SvenMarbles Posted January 20 Report Posted January 20 38 minutes ago, WRYS709 said: I reset my Anytone to US-GMRS, and downloaded the radio into RT Systems for you to view and even use the attached RTS code plug, as you desire: AT-779UV GMRS.default 202501191600.AT779UV 189.6 kB · 0 downloads Unlock the radio and then you dont have to skip 8-14. plus you can add the ham repeaters as well as police and fire for monitor.. Quote
UncleYoda Posted January 20 Report Posted January 20 48 minutes ago, WRYS709 said: I reset my Anytone to US-GMRS, and downloaded the radio into RT Systems for you to view and even use the attached RTS code plug, as you desire: I haven't switched my DB20-G out of GMRS mode yet, so I should only need to read from my radio if I get the RT software. But wouldn't the default (factory) channels automatically be restored when resetting back to GMRS mode? I know any extra channels I had added would be gone and having a backup of that would be the reason for using the software, whether it's the RT Systems or Radioddity program. Quote
WRYS709 Posted January 20 Author Report Posted January 20 4 minutes ago, UncleYoda said: I haven't switched my DB20-G out of GMRS mode yet, so I should only need to read from my radio if I get the RT software. But wouldn't the default (factory) channels automatically be restored when resetting back to GMRS mode? I know any extra channels I had added would be gone and having a backup of that would be the reason for using the software, whether it's the RT Systems or Radioddity program. Yes, it automatically restores the basic 30 channels. You should do a backup of your current library of channels now using the Radioddity/Anytone software and again when you acquire RT’s software. Then you will have the ability to easily restore your library of repeaters/settings, etc Rather than overwrite my code plugs as I modify them, I just save a new file with date and time. This way I can always go back to an earlier code plug, if I screw the new one up for any reason SteveShannon 1 Quote
WRYS709 Posted January 20 Author Report Posted January 20 32 minutes ago, SvenMarbles said: Unlock the radio and then you dont have to skip 8-14. plus you can add the ham repeaters as well as police and fire for monitor.. Using channels 8 through 14 on a mobile is somewhat controversial as a violation of part 95E rules The reason being that you are transmitting higher power than was intended on these interstitial channels very close to repeater input channels SteveShannon and WRXB215 2 Quote
UncleYoda Posted January 20 Report Posted January 20 2 minutes ago, WRYS709 said: Using channels 8 through 14 on a mobile is somewhat controversial as a violation of part 95E rules Not only that but having a radio that can transmit on ham and GMRS is non-compliant. That's why I was referring to switching modes. I wish they would change their stance on that when we have both licenses, but that ain't gonna happen. brasda91 1 Quote
SvenMarbles Posted January 20 Report Posted January 20 There's not much of a controversy.. You can be a "good boy" for literally noones's sake, because nobody cares, FCC included. Or you can just get on with having a radio that services you better.. Quote
amaff Posted January 20 Report Posted January 20 Or you can do what I do I have 8-14 programmed in with transmit off selected...but know that it can be enabled pretty quickly through the menu in a pinch SteveShannon, WRUU653, WRXB215 and 1 other 4 Quote
SvenMarbles Posted January 20 Report Posted January 20 11 minutes ago, amaff said: Or you can do what I do I have 8-14 programmed in with transmit off selected...but know that it can be enabled pretty quickly through the menu in a pinch Are we worried about a field search of the FCC police? I wonder why so many people running LMR Motorola aren’t so skiddish,.. Or nearly EVERY gmrs repeater setup, running on Motorola. All type cert scofflaws.. If you have your Gemers license, and operate on the gemers frequencies, nobody cares…. Quote
UncleYoda Posted January 20 Report Posted January 20 "NOBODY CARES" is not correct. It's a secondary offense, like being pulled over for speeding and then getting a ticket for not wearing a seat belt. And me and lots of other hams (and I assume some GMRS licensees) do try to follow the rules even when we don't like them regardless of whether we expect to be warned/fined. SteveShannon and WRXB215 2 Quote
amaff Posted January 20 Report Posted January 20 32 minutes ago, SvenMarbles said: Are we worried about a field search of the FCC police? No, but I did agree to follow a set of rules and generally speaking I like to stick to that unless there's a real good reason not to. SteveShannon, WRXB215 and WRUU653 3 Quote
SvenMarbles Posted January 20 Report Posted January 20 15 minutes ago, UncleYoda said: "NOBODY CARES" is not correct. It's a secondary offense, like being pulled over for speeding and then getting a ticket for not wearing a seat belt. And me and lots of other hams (and I assume some GMRS licensees) do try to follow the rules even when we don't like them regardless of whether we expect to be warned/fined. It’s not in any order of offense, because it technically isn’t even law. It’s FCC rules. Quote
WRYS709 Posted January 20 Author Report Posted January 20 18 hours ago, WRYS709 said: Using channels 8 through 14 on a mobile is somewhat controversial as a violation of part 95E rules The reason being that you are transmitting higher power than was intended on these interstitial channels very close to repeater input channels My mistake for using language that was not clear. I would hope that this thread does not get bogged down in the “FCC Rules Police” debate. As noted by some, there are easy ways to open these radios and yet keep them operating within the structures of FCC Rules. That is their power, versatility and abilities for such a bargain price! Let’s get back to programming questions about the RT Software for these versatile radios Quote
UncleYoda Posted January 20 Report Posted January 20 1 hour ago, WRYS709 said: open these radios and yet keep them operating within the structures of FCC Rules. Sorry, but you can't have both services on the radio at the same time if you want to follow the rules. There was some guy at FCC a few years ago who said even having the capability to transmit on both using VFO (like a typical open UV5R) violated the regs. I was surprised at that, but reprogrammed my radios, and bougght a GT-5R that was limited to ham. Never did find any final word on that. Quote
WRYS709 Posted January 20 Author Report Posted January 20 3 minutes ago, UncleYoda said: Sorry, but you can't have both services on the radio at the same time if you want to follow the rules. There was some guy at FCC a few years ago who said even having the capability to transmit on both using VFO (like a typical open UV5R) violated the regs. I was surprised at that, but reprogrammed my radios, and bougght a GT-5R that was limited to ham. Never did find any final word on that. And yet, you took time from your busy day to repeat your point when nowhere did I say anything about “both services!” Quote
UncleYoda Posted January 20 Report Posted January 20 You did say "open" though, and and the frequency range specified in the instructions includes both. Open is widely used to mean more than just locked to one service. (Don't worry about how busy I am - I'm watching the show in DC.) SteveShannon 1 Quote
WRYS709 Posted January 20 Author Report Posted January 20 7 minutes ago, UncleYoda said: You did say "open" though, and and the frequency range specified in the instructions includes both. Open is widely used to mean more than just locked to one service. (Don't worry about how busy I am - I'm watching the show in DC.) Last time I checked your Ham Radio license is still active until 2030 and and you are coming dangerously close to Randy's definition of a "sad Ham!" Quote
WSEN940 Posted May 6 Report Posted May 6 I don't know if this helps anyone, but I decided that I can't be bothered to pay RT systems when the provided software works just fine. That said, entering data is a pain so I wrote two python scripts. Now, what I did is not very complicated. The first script enters the two frequencies, the name and sets the tx power to high. All of this data comes from a simple csv file You then save the .dat file The second script then loads the .dat file, searches for the entries and then amends it for the CTS and DCS codes. The .dat file uses a four digit hex value to determine the displayed value. If anyone wants the scripts, DCS/CTS lookup and my excel sheet that does the lookups. Let me know. it's rough and ready and needs a little prep to share. But as it is, it allows me to edit the spreadsheet, copy some formulas and then export the data for use. While this took me about as long to 'develop' as entering the values. And it took me longest to build the DCS/CTS to four digit lookup table. Of course this requires a 'little' knowledge of python (enough to have python installed and be able to run it) and excel. WRXB215 and amaff 2 Quote
