WREJ285 Posted April 12 Report Posted April 12 I am wanting to mount a gmrs radio in my skid steer. I need a really flexible heavy duty antenna like a rubber ducky that can handle 50 watts. The factory am/fm is a rubber ducky type. Any input is appreciated. Quote
SteveShannon Posted April 12 Report Posted April 12 I haven’t used one, but I would consider something like this. I use an mxta26 and like it. https://midlandusa.com/products/mxat05vp-3-db-heavy-duty-bullbar-antenna?variant=42539707302065&campaign_id=17727845030&ad_id=&gad_source=1&gbraid=0AAAAADAFdQglRxyShGFPXLNzwa6UtbZFt&gclid=Cj0KCQjwnui_BhDlARIsAEo9GusL9Y1FOKx1quX2PSNYMUM_aiJJ6i8Iq0p8mSonjpv2M4D7XH3-gwsaAnZ2EALw_wcB Quote
WRUE951 Posted April 12 Report Posted April 12 52 minutes ago, SteveShannon said: I haven’t used one, but I would consider something like this. I use an mxta26 and like it. https://midlandusa.com/products/mxat05vp-3-db-heavy-duty-bullbar-antenna?variant=42539707302065&campaign_id=17727845030&ad_id=&gad_source=1&gbraid=0AAAAADAFdQglRxyShGFPXLNzwa6UtbZFt&gclid=Cj0KCQjwnui_BhDlARIsAEo9GusL9Y1FOKx1quX2PSNYMUM_aiJJ6i8Iq0p8mSonjpv2M4D7XH3-gwsaAnZ2EALw_wcB Wow,, that thing is made with Platinum RIPPER238 1 Quote
WREJ285 Posted April 12 Author Report Posted April 12 I looked at that one. I don’t think it will last forestry mulching. I regularly have 5” diameter trees fall on the machine. Quote
nokones Posted April 12 Report Posted April 12 What about a Midland MXTA 25 Phantom antenna? SteveShannon 1 Quote
BoxCar Posted April 12 Report Posted April 12 31 minutes ago, WREJ285 said: I looked at that one. I don’t think it will last forestry mulching. I regularly have 5” diameter trees fall on the machine. I don't think any antenna would survive that kind of abuse. Think about a 1/4 wave stubby like a Laird or similar that's about 6" high. They're relatively inexpensive but work well. WRUU653, GrouserPad and WRYZ926 3 Quote
WRYZ926 Posted April 12 Report Posted April 12 I agree with @BoxCar, you are going to be hard pressed to find an antenna that will handle that kind of abuse. Something like the Midland ghost or Melowave Shadow might have a better chance of surviving. WRUU653 1 Quote
WREJ285 Posted April 13 Author Report Posted April 13 Thank you for the input. I have a ghost antennae… I guess I will try to strategically mount it unless a better option comes up. Quote
GrouserPad Posted April 13 Report Posted April 13 First off blueloctite ALL threaded connections. Mount and antenna! My opinion is an antenna on a spring hard mounted to an nmo directly to the machine somewhere would be my reccomendation. Even if you have to weld a mount tab to the machine. The antenna will be able to bend and deflect alot of impacts that way at least until the very base of it gets smashed. Im currently running two mxta26 antennas on heavy iron, one on a 390 size trackhoe, and another on d6 dozer. Both of which have held up fine but concrete dust is starting to corrode one of them pretty badly. I'm a big fan of the mxta26. My two have been going for about 3 months now no issues. But I really like the idea of a ghost mount as well as that would be easy to fit on a skidsteer but I feel like if it hit something it wouldn't be resilient at all. WREJ285 1 Quote
amaff Posted April 13 Report Posted April 13 1 hour ago, WREJ285 said: Thank you for the input. I have a ghost antennae… I guess I will try to strategically mount it unless a better option comes up. Ok, now I'm confused as to what you're *actually* asking. First it sounded like you were looking for an antenna recommendation that could deal with moving around. Now it sounds like you HAVE an antenna and are looking for alternate mounting solutions? What's the problem you're actually trying to solve here? Quote
WREJ285 Posted April 13 Author Report Posted April 13 2 hours ago, amaff said: Ok, now I'm confused as to what you're *actually* asking. First it sounded like you were looking for an antenna recommendation that could deal with moving around. Now it sounds like you HAVE an antenna and are looking for alternate mounting solutions? What's the problem you're actually trying to solve here? I have five mobile gmrs units and several handhelds. The skid steer really blocks the signal from a handheld and I need an external antenna. I have reservations that a ghost antennae will survive and was hoping someone has already fought this battle. amaff 1 Quote
WREJ285 Posted April 13 Author Report Posted April 13 I have not mounted the radio in the skid steer yet… planning ahead… Quote
WRUI365 Posted April 13 Report Posted April 13 Problem is because of the way a skidsteer operates, there is only 1 mounting solution which is the roof cab of the skidsteer in which will be hard pressed for anything to survive up there with falling debris. Dozer and Hoes have different operations for which hardly anything goes over the cab. How do I know this? You work for United Rentals long enough and you learn the intricacies of the equipment you deliver and set up. Quote
nokones Posted April 13 Report Posted April 13 I would try mounting a quarterwave antenna inside the Skidsteer cabin in order to protect the antenna from being damaged. Just make sure that the antenna is mounted vertically. Quote
Hoppyjr Posted April 13 Report Posted April 13 I’d think the noise of the machine would make it difficult to use a mobile rig. What about using a handheld, which you could tuck in a shirt pocket or put over your shoulder like those firefighter radio carrier things? A handheld would allow you to use an earphone too, making it easier to hear. Quote
Radioguy7268 Posted April 13 Report Posted April 13 Do not mount antennas with 50 watts or more ERP inside the cab within inches of your head. Read up on Specific Absorption Rates and RF safety. Also realize that transmitting at 50 watts to someone who is holding a 4 or 5 watt portable is overkill. SteveShannon 1 Quote
tcp2525 Posted April 13 Report Posted April 13 Keep it extremely simple, just use a 1/4 wave magnetic mount and needn't worry. WRUU653 1 Quote
nokones Posted April 13 Report Posted April 13 2 hours ago, Hoppyjr said: I’d think the noise of the machine would make it difficult to use a mobile rig. What about using a handheld, which you could tuck in a shirt pocket or put over your shoulder like those firefighter radio carrier things? A handheld would allow you to use an earphone too, making it easier to hear. The noise factor is an easy fix, high noise environment external speaker or a high noise with noise canceling boom mic headset. Quote
Hoppyjr Posted April 13 Report Posted April 13 The noise factor is an easy fix, high noise environment external speaker or a high noise with noise canceling boom mic headset.The headset solution would also work with the HT, but cheaper, more portable, and no antenna or mounting issues. It’s what I’d do. Quote
WREJ285 Posted April 14 Author Report Posted April 14 I absolutely need an external antennae. I can barely talk 50 yards with a handheld in the machine. The dominant area I work in allows me to use a repeater. When I am out of range from the repeater, I use simplex to another micromobile for directional supports, sometimes drone guidance. The mulching head seems to generate a magnetic field. I have not had success mounting a functional compass in the unit. Hoppyjr 1 Quote
gortex2 Posted April 14 Report Posted April 14 As was mentioned a single quarter wave is our best bet. I installed those on many machines over hte years for logging and highway departments. Yes it may get destroyed but they are $10 at most. Unscrew NMO and replace it when needed. GrouserPad, WREJ285, Radioguy7268 and 1 other 3 1 Quote
GrouserPad Posted April 14 Report Posted April 14 On 4/13/2025 at 1:35 AM, Socalgmrs said: Midland and others make off road antennas. I have abused the heck out of them with no issues. AND they don’t need a ground plane like a ghost or mx26 You’ll have plenty of gp on any skidsteer. OP get a mag mounted 1/4 wave if the height of a 5/8 wave is too much, put it behind the cab glass. Done. Prolly fish the cable through the left or right sliding window and carefully shut it on the coax. We do this with strobes and work lights on our skid steers. Could also lift the cab access the engine bay and run the coax along the foot plate up through the floor holes. Drill hole through the floor mat edge or something of that sort. Pretty awesome your trying to mount a gmrs mobile inside a skid steer. I’ve never been that brave cuz our skidsteer operators are absolute savages and not in a good way lol also the tid h3 is the only radio loud enough for me to hear in a work environment and I still have to wear it on a jacket with a nylon radio clip area right next to my ear WREJ285 1 Quote
LeoG Posted April 21 Report Posted April 21 You can get a microphone with a speaker for the H3. Put the clip right near your ear and you can use the mic too. It also has a VOX headset you can use if you are in need of communication regularly. GrouserPad 1 Quote
GrouserPad Posted April 25 Report Posted April 25 OP what route did you go and how is it working?? Quote
RIPPER238 Posted April 25 Report Posted April 25 A mag mount Midland ghost antenna may be the best bet. You can move it easily or it will get nocked off vs breaking. And you can buy 4-5 of them for the price of a heavy duty one. You can get creative with placement depending on the skid steer as well. Quote
