  2. Today
  3. I have been able to make contacts on the KCARC-Gold MT repeater 462.6000 (RPT-03) on my radio. Now when I press the PPT it does not TX. On other channel when I press PPT, it stays in TX mode and when I release the key I can RX or if a repeater I get get the response. I cannot see where I might have made a change in the set up.
  4. It seems like this year everyone buying illegal fireworks got a buy 1 get 50 free deal. All night last night and thru most of the day.. Boom Boom Boom.. Less aerial flashy stuff but a lot of a aerial booms this year..
  5. Yesterday
  6. LMR Services certified transmitters do not have to be certified for Part 95 services in order to be legally used on Part 95 freqs. Part 95.335(a) allows the use of LMR transmitters on Part 95 services providing that the user operates that LMR transmitter in accordance with the Part 95 rules and regs insofar as freq tolerance, power output, bandwidth, etc. The use of my Motorola radios on GMRS freqs is totally legal if I do not exceed the power and frequency limitations described in Part 95, subpart E, and they don't need to be Part 95 certified.
  7. Happy 4th of July WEEKEND!!! Saw my town fireworks display a week ago when they hold the fair. Went to my BILs for the 4th and my sisters for the 5th for outdoor parties. Great weather both days. Did work for 2 hours on the 4th because.. It's just Friday. Let the fireworks fly.
  8. Thank you very much!!
  9. Ah! Thanks
  10. PMR (Professional Mobile Radio) is basically the European version of LMR
  11. Then what is PMR?
  12. LMR will be for the entire business frequency pool.
  13. I recently purchased a used ICOM F-6020 and have successfully programmed it using the ICOM software. On the menu bar of the software there is a selection for “Model” LMR or PMR, I can find nothing in the software or owners manual that addresses this setting. I did my programming with the LMR selection which seemed to be the default. Radio seems to work fine but was just curious what the difference between the 2 settings are. Anybody? Anybody? Beuler? thanks for any advice. WRWN495
  14. I know the last post was almost a year ago. I just received my RA86 with an antenna upgrade over the little one. Here is my findings. It comes with privacy tones pre-programmed. You can delete them by turning the radio on while holding the PTT and Scan buttons. You can program up to 99 channels, simplex or repeater. After programming repeaters, you need to turn on the repeater function from any channel. I programmed some public safety frequencies, but the RA86 will not allow the program to install the transmit frequency. This is where labeling the channel would be nice, but it doesn't have the capability. The setting scan is done from the microphone. If you update the radio, you have to start over and set the scan and repeater functions. Scroll using the menu button and change the selected setting with the volume buttons, press menu again, and then wait for it to time out. I downloaded both the programming software and driver from the Retevis website. I needed the driver for the programming software to work.
  15. Best wishes for you 521. I'm glad you are here to post.
  16. 100 miles is nothing. There is one of the Queen's favorite viewers in California that can do 200 miles with ease. Seriously, the average terrain elevation in the area of the Maljamar is somewhat flat and approximately 4,000 AMSL and the Maljamar repeater site appears to be sitting at the 4,121 ft level. With the curvature of this great planet and the fact that the propagation of the UHF signal essentially requires a " Line-of -Sight", I highly doubt that the area of coverage footprint is anywhere near a hundred miles. You would essentially, need a site approx. 10-13K in elevation above the average elevation of 4K to have the range of 100 miles with an UHF signal. Even a microwave control path, peak to peak would have difficulties in making it that distance because of the earth curvature. In this case, the 100 mile range of this site is very arbitrary.
  17. Both likely to work, the 50 watt radio will sound louder to those receiving your signal.
  18. Oh, my! That sounds serious! Can you tell us more about what will happen if he (or anyone) makes a pest of themself?
  19. That radio is currently the GOAT but it’s a ham radio, so be aware that it’s freebanding, and if you’re going to do that, you’re not allowed to make a pest of yourself or you might actually get in the shit — only break one rule at a time! BTech has a beastly 50 watt unit which uses the same software as the Vero, and a GMRS Pro, which is probably still more radio than you need, but Vero software is super easy compared to the alternative menu and manual stuff!
  20. yall are too funny....lol
  21. Went to the website and found this. And then found this about the HDG antenna So much for the informational insert inside the box
  22. Btech RPT50
  23. Beautiful dog.
  24. It sounds like the Baofeng just doesn't have the "legs" to reach the repeater. Even given the same nominal wattage, some radios just have a little better reach than others.
  25. I believe the kenwood TKR-830 was part 95 according to repeaterbuilder.com, however the tkr-830 is a full duplex radio meant for a trunking system; takes some hacking to make it a stand alone repeater.
  26. Last week
  27. Ah, thanks! So that means my first Tx hit the repeater and it responded with its call-sign in Morse-code. The Baofeng also received the call-sign, but it is not receiving the Tx from the Wouxun KGS-88G. Nor does the Wouxun receive transmission from the Baofeng. All is well in simplex land.
  28. Yawn, looks like you got me, Einstein! I would never directly ground a radio with 500 MCM as it's best to feed your primary bonding plate with 500 MCM and then, yes then, reduce to a home run of 250 MCM to each fixed equipment rack. https://www.gordonelectricsupply.com/p/Harger-223T-Tin-Flange-Bonding-Plate/6096051 But, we ground each of our Baofeng handhelds with 4/0 THHN for maximum flexibility.
