WRYS709
Everything posted by WRYS709
  1. My Baofeng UV-13Pro (the Amateur Radio version of their UV-15Pro) works on MURS as well. I purchased it from AliExpress for about $20.
  2. Are there any similar VHF 2 watt HTs that you could just program the MURS channels into?
  3. Perhaps but using the same directions, it can be returned to GMRS Mode for those concerned. I purposely left out that discussion...
  4. As this topic comes up now and then, I thought I would summarize, again, how to expand the versatility of these inexpensive mini-mobile devices for use on GMRS: 1) With the power off, hold down the V/M button and turn the power on 2) Note the firmware version number and jot it down for future reference, such as "V3.0" 3) Note that the MODE is GMRS. Using the Up and Down arrow buttons, change the Mode to (136-174)(400-470) and turn off the Power. 4) Using the CPS programming software (I prefer version 2.02 of the Radioddity programming software which works on both radios), install the GMRS code plug attached below. You now have more control over the radio using the microphone buttons, as well as other expanded features, such as full 500 programmable channels available for many more repeaters as you travel. Enjoy! Anytone AT-779UV GMRS 202310130140.dat
  5. My prayers have been answered!
  6. My mother taught me that it is better to remain silent and be thought a moron, than to speak up and remove all doubt!
  7. I am going to say this really slowly, so you can better understand: If they want MY advice, I prefer that they NOT use these Voting threads. AND last time I checked, YOU have NOT given the OP ANY advice about his question regarding the 5 MHz split on the GM-30 or DB20-G!
  8. And yet, after @Elbowmacread my suggestion to him as a newbie, his subsequent questions are posted as I suggested.
  9. If it was easy, I would have no reason for living!?! C.f., Lenny Bruce's classic bit: Thank You, Masked Man!
  10. No wonder, someone on the GMRS SubReddit advises us to "Ignore" you!
  11. My consulting fee doubles when you do NOT try out my advice before questioning its efficacy! BTW: In the future, I just HATE this Technical Discussion thread that lists responses by Votes and YES, I know I can select by Date; but I am not here to win a popularity contest (and I frequently DON'T). So for MY advice in the future, especially for the DB20-G, please avoid these Vote threads...
  12. Yes, I already had a 120v to 12v power supply in the house, that I use to power my DB20-G on a permanent basis. But since you asked about Jackery and since I DO use my Jackery Explorer 300 to power my DB20-G when portable, I wanted to give you the benefit of that knowledge.
  13. Did you try it? Are you in GMRS mode, or have you "opened" your DB20-G? I may have to return mine to GMRS mode to duplicate your efforts if that is your mode.
  14. Last year's Black Friday, I could not resist purchasing a Jackery Explorer 300 from Amazon. It powers my DB20-G just fine!
  15. Push the FUN button to enter the Menu Mode Use the V/M (Up) and MAN (Down) buttons to go to Menu Item #29: DSPCHANNEL Use the Up Arrow and Down Arrow buttons to change your setting from "CH" to either "NAME" or "FREQ" as you desire Push the FUN bottom to exit the Menu Mode
  16. Which make/model is that 2 meter radio?
  17. I am a BIG FAN of the Jerry Ziliak High Speed Morse Code System. These were originally on cassette tape, but after Jerry Ziliak passed away, his estate must have licensed the transfer to CD and now Amazon sells them. His theory is simple: He teaches you each letter, number and character one at a time at 20 WPM sending of the dots and dashes. But as he expands to words, he sends each character at 20 WPM, but by putting in more space between letters, he starts out at 5 WPM. Then as you get comfortable, he starts to "increase" the speed by deleting some of the spacing. In this way, your brain hears 20 WPM right from the start, instead of other teaching methods that make you relearn each letter, etc., as your speed increases. I can send you a sample if you like; send me a PM.
  18. I would love to hear your method of flashing UV-13Pro firmware over to the GM-30 a/k/a UV-15Pro a/k/a Pofung UV-15UV The link to Chirp by the previous "ghost" poster does list many people wanting to help out, but so far none of them has cracked the problem why Chirp does not support these radios. The Radioddity GM-30 cps programming software (windows only) does work.
  19. [I moved my post over to the new thread on Amateur Radio]
  20. I will let @WRUU653 answer your questions, instead of just complain about my complaining about the format and meta-structure of this type of thread. And, hopefully he will be specific about his answers on your use of the GM-30 and DB20-G on split repeaters! Good luck and see you on your next question!
  21. I never thought about stretching this Transverter from 450 to 467 to see if an Icom IC-7300 can operate on the GMRS channels. Nice challenge!
  22. Repost on another thread that is not "Sort by Votes" and I will be happy to respond... If it is a ham radio repeater, post on that topic please.
  23. "Sort by VOTES" - Good luck!
  24. Good to see that these cost effective little units are still selling and getting a larger fan base!
  25. I am having trouble following your grammatical use of negatives here, perhaps... Then it is not a TOT timer shut off. I just set my DB20-G timer for 1 minute and held my microphone transmit button on: At 52 seconds, it began emitting a tone for about 5 seconds. At 60 seconds, it shut down the transmission. As I continued to hold the microphone button down, it did not regain transmission. Once I released my microphone button, I was able to then immediately push it down again and regain the ability to transmit.
