WRYS709
3
Everything posted by WRYS709
Yes, it automatically restores the basic 30 channels. You should do a backup of your current library of channels now using the Radioddity/Anytone software and again when you acquire RT’s software. Then you will have the ability to easily restore your library of repeaters/settings, etc Rather than overwrite my code plugs as I modify them, I just save a new file with date and time. This way I can always go back to an earlier code plug, if I screw the new one up for any reason
Actually the Radioddity software, for free, is very versatile; but is very limited in capabilities for: import, export and copy & paste. So the RT Systems addition Is now very welcome! As to your noted point, yes, once you use the Radioddity software to change Tones, it is helpful to change the Squelch setting to match as well.
I reset my Anytone to US-GMRS, and downloaded the radio into RT Systems for you to view and even use the attached RTS code plug, as you desire: AT-779UV GMRS.default 202501191600.AT779UV
RT Systems is referring to how the OEM USB cable, while wired correctly for the purposes of the radio communicating with their CPS software, was not properly wired for the purposes of reverse engineering how their software communicates with the computer.
I have converted my GMRS Part 95E code plug to the new RT System software. This code plug allows the user to "open" their DB20-G or AT-779UV and yet restore full Part 95E compatibility and restrictions See this post to open your radio: AT-779UV GMRS 202501191140.AT779UV
At long last... RT Systems has delivered their $25 (download) software for the DB20-G/AT-779UV mini mobile radios (Version 5.00.04). It orders easily from their website and installs easily into Windows (11 in my case) and works with my USB to RJ-45 cable. RT indicates that the delay to engineer this software was due to some "incompatibility" in the OEM USB cable wiring, but indicates that it works with the OEM USB cables. I suggest that they may have been using the original Anytone USB cables, which has Windows 10 and 11 issues. But both Radioddity and newer Anyones now have an updated USB cable (albeit it looks exactly the same as the legacy Anytone cable!). RT does sell its own USB to RJ-45 cable for these radios, either separately or as a bundled combo. It is currently only available for Windows 8 and above. I have imported my current codeplug into their software very easily, saved it and now will begin the process of exploring it capabilities. For years, I have kept a CSV (Comma-Separated-Values) file as a master list of all of those frequencies I want to use in some or all of my various wireless radios. It easily opens in Microsoft Excel and now with the RT Systems CPS software, I can "import" and/or copy/paste these channels at will. This software now plugs the major hole that these wonderful radios had since their release. My other minor concern is that they do not "tone scan" but a $22 Baofeng UV-13Pro Ham Radio took care of that problem for me. If anyone has specific operational questions, shoot them at me, and I will be happy to test them out! NOTE: There is another new thread on this topic that insists on using the "Technical Discussion" - "sort by votes" system of discussion, which I abhor! These posts are all about date relevance and I, for one, do not want to subject other's posts, to be "down-voted" and hence pushed to the bottom of the thread. This is radio technology; not a popularity contest! Enjoy!
Is that before or after you snipped off the cigarette lighter plugs?
At this point I am turning my focus to DMR radios that are currently compatible with OpenGD77 since it appears they are not going to reverse engineer newly released radios. I just acquired a Baofeng DM-1701 for $50 from China and am about to install OpenGD77. I hope it will qualify as the new lowcost option that I can recommend to others interested in getting involved in DMR inexpensively.
But I believe it does not support OpenGD77 DMR, which is a game changer
And 60% more expensive than the DB20G it replaced, as well! So I hope it's "far better..."
You sure it doesn't come with a cigarette lighter plug already crimped on its tinned and stripped wires?!? hahaha
HTs are the "gateway drug" of the Compulsive Radio Owners fetish (a known BTSM subcategory)!
Not one reported DB20-G/AT-779UV cigarette lighter plug melting to the date of this post...
I’d bet dollars to donuts that most DB20-G users use their cigarette lighter plug for power. In my vehicle, I do, and why not?! It’s so easy to unplug and hide the equipment in a zone where I am concerned about someone breaking a window to steal it when it’s in plain sight. And for the one in my shack: the Powerwerx adapter makes it plug and play without losing the versatility of having the cigarette lighter plug, when needed.
Somewhere on one of these threads, I posted my code plug that follows Part 95E rules, after opening up this radio.
Is there a better one for $200? $300?
Retry your experiment with Input Tones on these channels if you have time, and report bach.
Having owned a Pofung UV-30, the clone of the Radioddity GM-30 since about Day one, here is my best advice: Buy two Baofeng UV-13s for about $22 each, They are the Ham Radio version of the Baofeng GM-15, which is also a clone of the GM-30. These are already open and can operate on GMRS. No firmware muss and fuss! USB-C charging and Tone Scanning, too! With my purchase of my UV-13, I retired my TYT TH-UV88, which is really long in the tooth!
I have my Yaesu FT-857d, so I am well aware of the shack in the box, but none of the truly portable ones are manufactured anymore. So there is nothing I can recommend. But I have my Radioddity DB20-G and I purchased a Quansheng UV-K5(8) and flashed the IJV3 Firmware and now for $20 I have a 2 meter/440 DSB HT that is compatible with SSB. I made a 65 mile contact with my legacy AEA 5/8 telescoping antenna on 2 meters SSB.
The Radioddity GM-30 CPS software is the "go-to" software for the Baofeng GM-15. You are having Windows USB Cable/driver issues which is a dark art on Windows! Did your programming cable come with your GM-15, or did you acquire it separately? All facts would be helpful to diagnose!
Now if there was only a quad band radio that supports SSB as well as FM (and hence, even digital!)
Which mobile do you use?
I avoided this problem by getting the UV-13 pro which is the Ham radio version of that radio and since it’s already open it transmits on GMRS $20 from AliExpress from AliExpress I retired my TYT-88UV
