WRUE951
    4
Everything posted by WRUE951
  1. one of my RV friends struggles with the ghost antenna when trying to talk to traffic behind him when he is pulling his 5th wheel. His is mounted on his truck roof about 3 inches in front of his third brake light. It works pretty good to the front where there is no blockage or line of site. I have a midland whip mounted on the roof and don't have those same issues..
  2. It seems like this year everyone buying illegal fireworks got a buy 1 get 50 free deal. All night last night and thru most of the day.. Boom Boom Boom.. Less aerial flashy stuff but a lot of a aerial booms this year..
  3. Those will work just fine.
  4. 10-4 big buddy you;re right.. 10 codes came along after voice where as q codes were used primaly for Morse code..
  5. and 10-4 was around WAAAy before QSL
  6. Interesting,, are you seeing issues when you use your VPN? I just recently started using Nord and i've been seeing all kinds of HTML issues after i started using it, not just here but with other sites too.. I never suspected the VPN but next time will toggle it off to see if VPN is causing problems.
  7. The forum knows 'everything' Just ask
  8. No, it’s not browser related. I didn’t change my password thru the alert page. I went to my profile and re-set my password and the alert disappeared. A browser would not know to do that.
  9. I don't think Iran ever did depend on the U.S. for anything electronic.. China and Russian has been their main supplier and that doesent appear to be changning anytime soon..
  10. Kind of a weird notice. I’m curious what the time out factor is set at.. I’ve been here close to four years and that was a first. I went to my profile and changed it there and used the same password.
  11. I talk 90 miles with a J-Pole for a remote portable repeater mounted on a fibergalss RV. Just as good as my Midland whip mounted on my truck roof.. Performace wise and depending on they type of no ground plane antenna, there is no difference.. Some no-ground plane antennas peerform pretty bad, just as some ground plane whip... Do some research on your antenna choice and see if you can get some perfoamce tips
  12. I see that.. He did register 16 different coordinates for each site, probably 5-10 feet apart. If you filter out the last name you find overall they have 35 repeaters. Hella set up and no doubt range. And investment GMRS Repeaters ver 7_30_25.pdf
  13. I think California is gonna win that one
  14. I'll get right on that...
  15. Wow,,,,, Checking the new report today... WRZC921 added 16 repeaters this week.. That's being very busy.. Hell that would take me a week just to add them into the database.. Is this for real??
  16. i used a cowl mount on my JK that worked well. Check out Cool-Tech, i belive that have one for the Gladiator.
  17. I used to use ARC but i lost my account access when i retired 3 years ago.. Now i use a KML version of this data base for repeater access info etc, which also works great on the mobile app.
  18. Big 'Pop' vs small 'Pop' .. Love Shooting and i love Parump, my Ammo Depot
  19. Google Earth works great for a heading..
  20. Yup,, pretty much what you see used for Repeaters with Duplexers built into them. . Keep the lengths as short as possible, defiantly no longer than 3'
  21. I programed my AR-10 today.. Its dead center in tune.
  22. When choosing between horizontal and vertical polarization for GMRS antennas, vertical polarization is generally preferred. This is because GMRS is primarily a mobile and portable radio service, and most mobile and portable antennas are vertically polarized. Therefore, repeaters are also typically equipped with vertically polarized antennas. Using a horizontally polarized antenna to communicate with vertically polarized antennas on repeaters, mobiles, and portables can result in a loss of signal. This is due to the mismatch in polarization, which can lead to reduced signal strength and potentially poor communication quality. If you are considering a horizontally polarized antenna, it would be most effective if all other stations you are communicating with also use horizontal polarization, which is more common in fixed links rather than in mobile or portable setups. In a line-of-sight situation with a direct, unobstructed path to the repeater antenna, a horizontally polarized antenna might offer more gain. However, this potential gain must be weighed against the likelihood of encountering mixed polarization in the field, which can negate any benefits. For general GMRS use, sticking with a vertically polarized setup is recommended to ensure compatibility and optimal performance with the existing infrastructure and other users' equipment. If you are setting up a base station and are concerned about antenna polarization, it is also important to consider the height and placement of the antenna. Antenna height is often more critical than the length or type of antenna used. A higher antenna can provide better coverage and signal strength, which can be more beneficial than the polarization type in many scenarios.
