WRUU653
    42
Everything posted by WRUU653
  1. I don't know about best but a lot of people (myself included) like the Nagoya NA-771G. It's a bit long though (about 15") so I use the NA-701G mostly (about 5.5").
  2. @Tiercel as an example of things talked about above the connector on your Baofeng UV-9G is a Male SMA, the antenna that screws into it is a Female SMA..
  3. It depends on what the radio has. Many are SMA (male or female). Check these adapter kits. For examples.
  4. I have both the radios you mentioned. The Baofeng UV-9G and the Wouxun KG-935G Plus. KG-935G Plus hands down is my favorite GMRS Radio. If you gotta have quality and waterproof as well as even more frequencies to receive you could spend even more and get the Wouxun KG-Q10G, then you can jump in the hot tub and with quality. The ladies can see a cheap radio a mile away. In all seriousness I like the Baofeng and if I am worried about damaging a radio that's the one I'll grab but I've bounced my KG-935 off the pavement and not a scratch. I started to do a list of the differences but the most important difference is this. Which one do I grab when I want to use a GMRS radio? KG-935G Plus at least 99 out of 100 times. Ask anyone who has both and I'll bet that's their answer.
  5. A little internet search and it would seem Jerald may be living in a Big House, if you catch my drift. I can’t help but wonder if Shauna is even aware. Even her FCC license has an address with the attention to Jerald. That’s as far as I’m going with this. Best colloquialism of the morning. ️
  6. On 9/9/23 I was driving in Santa Barbra along the coast and had my radio on scan and I picked up a live surf competition being broadcast from San Clemente. I believe it was on 450.500 which is one of the local PD frequencies near my home about an hour north of where I was. The broadcast was a good 150-160 miles from me staight across the water. Zero obstructions. I confirmed what I was hearing when I got home by the names of the surfers and where they surfed that day. Radio waves be crazy. Why do I remember the day? It was the day I took my ham test.
  7. The only time my “upload to radio” is grayed out is when there is no file downloaded. If I have a file open it doesn’t matter if the radio is plugged in or not, the “upload to radio” isn’t grayed out. Based on this I would say Chirp isn’t seeing a file. For context I am using Chirp on a Mac. No file, upload grayed out File but no radio plugged in, upload not grayed out Edit: the programming cables were plugged into the computer but not the radio. I then removed cables from computer and there were no changes in results.
  8. This could be right ^^^ I keep two different programming cables plugged into my computer and sometimes select the wrong one in Chirp which becomes immediately apparent when it won’t see the radio I’m attempting to connect with.
  9. Are you sure you are uploading the correct radio file? Try downloading from the radio again and make changes to that file and upload to radio. I’m in the habit now of downloading from the radio twice, using one file to change and one to bail me out when I screw something up. Hope this helps.
  10. None of which is official or even remotely a standard other than the basic channel set up as lined out by the FCC. Just saying. I can hazard a guess at where you got your radio (BSR). I wouldn’t put much belief in thinking everyone else has a radio that is set up this way or that there are some hard fast rules to its program. I have one from there as well. First thing I did was dump most of the preprogrammed channels and load my own.
  11. WRUU653
    Chirp
    Haa, lol what he said. You are quick
  12. WRUU653
    Chirp
    That's what you will see when you open the program. Now hook up your radio and select download from radio and choose your radio make and model from the drop down menu at the top of your screen .
  13. WRUU653
    Chirp
    that's for windows is it not?
  14. WRUU653
    Chirp
    macOS Intel and Apple Silicon macOS, but requires installation of Python 2.7 this is what worked for me.
  15. As another Mac user I prefer Chirp. I have an old XP laptop if I need it. When I use Chirp on a Mac I just don't have any issues like when using the manufactures software on Windows (getting the damn program to recognize a port, finding the correct driver). Chirp just works.
  16. Something you may or may not have thought of take a look at the map and click on stale or offline repeaters (small gear upper left). This could avoid choosing a frequency that potentially might come back on line or be on line. I see this one that looks offline near you LAKE NORMAN CORNELIUS and of course this one is active HUNTERSVILLE BIRKDALE 675.
  17. Mine seems to be painted black and it looks like Blue Loctite was used. If it rust I'll hit it with some Scotch Brite and give it a blast of paint.
  18. In addition to info from @OffRoaderX and because you mentioned that you can transmit in frequency mode, if you are transmitting on 462.675 you also won't hit a repeater. 462.675 is a repeater receive frequency (or simplex channel 20). Your repeater channels will have the +5 offset automatically set. In this case it puts your transmit at 467.675. When you transmit on a repeater channel your other radio won't hear it unless you hit the repeater because your other radio is not receiving on the frequency that you are transmitting on. I hope that helps.
  19. It is looking to me like the radio has issues that it likely came with. I would try doing a full reset (menu 40) and if that doesn't clear up the issue send it back.
  20. One more thought… you say you were entering a repeater in the radio. If you did this on channels 15 and 17, those are not repeater channels. They are the simplex channels that have the same RX as their repeater channel counterparts. It’s possible something is wrong in the programming.
  21. One possibility is some Baofeng radios have been coming without the ability to use channel 15. There is a post here of people having issues with channel 15. Do you know for sure that the problem wasn’t there before you changed anything in Chirp? You may have to send them back. If you suspect an issue in your Chirp programming if you show us a screenshot we can look it over. Another possibility that may be happening is if two radios are to close to each other they will desense each other and not receive. You may need to move them further apart. Go outside and get 30’ or 40’ between them. Though if it’s only a problem on the one channel I don’t think that’s your problem.
  22. At least in my area most ham repeater traffic is 70cm or 2m which there are countless duel band radios. One is exactly like the GMRS radio you have already. The ability to hit a simulcast repeater system that pretty much covers most of the county including areas that dont have cell or GMRS is a big plus for me. One reason I got my Ham license was because I was limited in my reach with GMRS when it came to hiking or rural offroad areas near me. One such area was just asked about in another thread. There's no GMRS repeater reaching out there but on Ham it's as good as at home. All that said I started with GMRS and see value in both and would recommend spending some time with it first. Get to know your area, maybe set some local ham repeaters in your GMRS radios to listen to and see if you find benefit in Ham down the road a bit. You will be the best judge of what you want. Mostly you don't have to do it all or do it all at once. As for HF, I haven't indulged as of yet but I keep hearing how 10 meters is going crazy right now... crap another radio purchase awaits.
  23. Ham offers more frequencies, more options to explore as a hobby, more repeater coverage, while GMRS offers ease of use with family and friends that have no interest in radios other than to communicate. One may help you get assistance where there is no cell coverage while the other may help you spot that tire placement off road or keep you in touch with your wife at camp while you paddle a kayak around the lake. Is one better? Sure the one you need to do the thing you want in the moment. I fully am in favor of both.
