Destro Posted May 19 Report Posted May 19 Alright, so I have a Retevis RA25 mounted in my Xterra. Right now I'm using an NMO mag mount MXT-A26 antenna. It works great for GMRS. I used to have the Nagoya UT-72G mag mount hooked up to a TD-H3. I seemed to be able to get a lot more reception on that set up, using both GMRS and HAM. With the UT-72G, I was able to get NOAA channel 5 in super clear, plus I think channels 4,3, and 1 a little bit. With the MXT-A26, I can only get NOAA channel 5, from the same spot. I know the MXT-A26 is tuned specifically for GMRS. My question is, should I get the Comet 2x4SRNMO antenna? I would like to be able to just screw it into the NMO mount and not switch out the whole thing. I'm not HAM licensed yet, but I like to listen. And also I would like to have it in case of emergency. Plus I probably will eventually get my HAM license. Quote
WRYZ926 Posted May 19 Report Posted May 19 Yes the Comet 2x4SR will be an improvement if you want multi band use. You are correct that you would not have to change the mag mount to go from the MXT-26 to the 2x4SR. All you have to do is swap them out on your mag mount. I would run the 2x4SR on my Ford Escape all of the time if I didn't have height restrictions to deal with. SteveShannon, Destro, Jaay and 1 other 3 1 Quote
WRTC928 Posted May 20 Report Posted May 20 The only reason I don't run the 2x4 on my truck is that it doesn't like the very limited ground plane I get on the back of the bed. It works like a dream on the roof of my car, though. It's probably the most versatile multi-band antenna available. Mine even shows excellent SWRs in the 220 MHz band. A good SWR doesn't necessarily mean it will transmit well on that band -- the ability to transmit is dependent upon the electrical and physical characteristics of the radiating element -- but it does mean that if I try it, it's very unlikely to damage my radio. I likely will try it sometime just out of curiosity. Quote
Jaay Posted May 20 Report Posted May 20 7 hours ago, WRTC928 said: The only reason I don't run the 2x4 on my truck is that it doesn't like the very limited ground plane I get on the back of the bed. It works like a dream on the roof of my car, though. It's probably the most versatile multi-band antenna available. Mine even shows excellent SWRs in the 220 MHz band. A good SWR doesn't necessarily mean it will transmit well on that band -- the ability to transmit is dependent upon the electrical and physical characteristics of the radiating element -- but it does mean that if I try it, it's very unlikely to damage my radio. I likely will try it sometime just out of curiosity. Agreed. Strangely my Comet 2X4 also shows acceptable swr readings on 222 mhz. 20 mile simplex @30watts out and 30 miles to my closest 222 mhz. repeater @ 50 footup up with steel mending plates for a ground plane. a usable signal was surprising. Quote
tcp2525 Posted May 20 Report Posted May 20 7 hours ago, WRTC928 said: The only reason I don't run the 2x4 on my truck is that it doesn't like the very limited ground plane I get on the back of the bed. It works like a dream on the roof of my car, though. It's probably the most versatile multi-band antenna available. Mine even shows excellent SWRs in the 220 MHz band. A good SWR doesn't necessarily mean it will transmit well on that band -- the ability to transmit is dependent upon the electrical and physical characteristics of the radiating element -- but it does mean that if I try it, it's very unlikely to damage my radio. I likely will try it sometime just out of curiosity. You guys are lucky that you have 220 activity. I have four repeaters in my area that I can get into and they are totally devoid of any human life. What a great but wasted band. Quote
WRTC928 Posted May 20 Report Posted May 20 46 minutes ago, Jaay said: Agreed. Strangely my Comet 2X4 also shows acceptable swr readings on 222 mhz. 20 mile simplex @30watts out and 30 miles to my closest 222 mhz. repeater @ 50 footup up with steel mending plates for a ground plane. a usable signal was surprising. Since it seems to have worked for you, I'll give it a try. It's the only antenna I have that has good readings on 2m, 70cm, GMRS, MURS, and 1.25m. It has good signal on 70cm, GMRS, and 2m; I've never keyed up on MURS since I had a pair of MURS radios about 12-15 years ago. It would be convenient if it worked on 1.25m, because my car has limited real estate for antennas. I could have one antenna that did it all. On the truck, I have 3 antenna mounts, so it's no problem to have one antenna for GMRS/2m/70cm and another one for 1.25m. Jaay 1 Quote
WRTC928 Posted May 20 Report Posted May 20 25 minutes ago, tcp2525 said: You guys are lucky that you have 220 activity. I have four repeaters in my area that I can get into and they are totally devoid of any human life. What a great but wasted band. The one in Oklahoma City appears unused, but I'm trying to breathe some life back into it. The problem is that people ignore it because nobody uses it, but if everyone ignores it, there will never be any activity on it. I do know a guy who said he and his wife use it to stay in touch when they go to the state fair in the fall, so I guess it isn't completely devoid of life. I throw out my call sign every time I'm within range but haven't gotten a response yet. However, Tulsa has four 1.25m repeaters which get quite a bit of use, and I travel there fairly often, so I want to have that capability. tcp2525 1 Quote
WRYZ926 Posted May 20 Report Posted May 20 There are few areas where the 1.25m/220 MHz band is pretty active,. But those areas seem few and far between. I can only find one 1.25m repeater here in Missouri and it is permanently linked to a 2m repeater. There are two reasons why the 1.25m band is not more popular. One is that there are only two 50 watt mobile radios available on the market and both are from China. All the tri and quad band radios with 1.25m are limited to 5 or 10 watts max. Wouxun has released their KG-XS20H that is 20 watts on 220 MHz but they are not in stock at this time. The flip side is that the big three aren't interested in making a 1.25m radio with more than 5-10 watts since no one really uses the band and North America is the only market for it. It's a vicious circle. I have found that even expanded metal like what most hitch mounted luggage racks are made of makes a good ground plane for the 2x4SR. I cut down one of these racks to fit the back of my SxS and have the 2x4SR on a Midland mag mount on the rack and it works well. I'm using a 20 watt radio on the SxS. Lscott, tcp2525 and Jaay 3 Quote
AdmiralCochrane Posted May 21 Report Posted May 21 I used my 220 radio twice today WRTC928 and Jaay 2 Quote
WRTC928 Posted May 21 Report Posted May 21 On 5/20/2025 at 9:12 AM, WRYZ926 said: I have found that even expanded metal like what most hitch mounted luggage racks are made of makes a good ground plane for the 2x4SR. That makes sense. If three radials can provide a ground plane, expanded metal should work as well or better. AdmiralCochrane 1 Quote
nokones Posted July 6 Report Posted July 6 With both of these two antennae, I am able to hit a GMRS Repeater on Mt Lemmon near Tucson from Sun City West that is northwest of Phoenix. The air miles between the two points is at least 110 miles. The Larsen Glass-mount antenna is connected to a Motorola XTL5000 remote with 48 watts and the Laird Phantom is connected to a Motorola XPR5550e with 44 watts. Quote
WRUE951 Posted July 6 Report Posted July 6 one of my RV friends struggles with the ghost antenna when trying to talk to traffic behind him when he is pulling his 5th wheel. His is mounted on his truck roof about 3 inches in front of his third brake light. It works pretty good to the front where there is no blockage or line of site. I have a midland whip mounted on the roof and don't have those same issues.. Quote
BoxCar Posted July 6 Report Posted July 6 Well, that trailer makes a darn good RF block. WRUE951 1 Quote
