Guest Junior Posted February 8, 2022 Report Posted February 8, 2022 "Hello" everyone, I was just curious. Does "Skip" happen on GMRS, like it does on CB radio? I have never heard, the GMRS community talking about skip. Also, if it does not happen...why not? Regards Quote
wayoverthere Posted February 8, 2022 Report Posted February 8, 2022 34 minutes ago, Guest Junior said: "Hello" everyone, I was just curious. Does "Skip" happen on GMRS, like it does on CB radio? I have never heard, the GMRS community talking about skip. Also, if it does not happen...why not? Regards From what I've read, the shorter wavelengths of gmrs pass through the atmosphere rather than bouncing back like the longer wavelengths of cb and similar longer wavelengths. Gmrs can experience some tropospheric ducting similar to 2m frequencies, though usually not to the same extent. Quote
JohnE Posted February 8, 2022 Report Posted February 8, 2022 its called ducting and yes it can and does happen under the right conditions. mostly weather related. Quote
PACNWComms Posted February 8, 2022 Report Posted February 8, 2022 There is a thread going on about this right now. Quote
oldjeep30 Posted February 24, 2022 Report Posted February 24, 2022 I have noticed on the vhf propagation map when it is red in my area. I get better coverage on gmrs. Quote
oldjeep30 Posted February 24, 2022 Report Posted February 24, 2022 2 minutes ago, MichaelLAX said: Link for that map please? just google vhf propagation map and you should see it. Quote
wayoverthere Posted February 24, 2022 Report Posted February 24, 2022 6 minutes ago, MichaelLAX said: Link for that map please? http://aprs.mennolink.org/ MichaelLAX 1 Quote
MichaelLAX Posted February 24, 2022 Report Posted February 24, 2022 9 hours ago, wayoverthere said: http://aprs.mennolink.org/ Thank you! Do you have links to propagation maps for HF other than: DXMAPS 4.2 - QSO/SWL real time information Quote
wayoverthere Posted February 24, 2022 Report Posted February 24, 2022 4 hours ago, MichaelLAX said: Thank you! Do you have links to propagation maps for HF other than: DXMAPS 4.2 - QSO/SWL real time information I haven't run across any, but I'll keep an eye out..Google found https://www.voacap.com/hf/ via https://www.ke6mgb.com/dx-and-propagation-maps/ if those are any help. Quote
MichaelLAX Posted February 24, 2022 Report Posted February 24, 2022 That is helpful, now that I am getting more active with better solar propogation on HF! wayoverthere 1 Quote
AdmiralCochrane Posted February 25, 2022 Report Posted February 25, 2022 GMRS is more closely related to ham UHF. It actually is in the UHF frequency range, just not in the assigned band. Quote
Guest MikeD Posted 3 hours ago Report Posted 3 hours ago I have heard skip that I believe is coming from an airliner passing overhead. I was recently listening to gmrs channel 16, which is also the repeater downlink for a local repeater. I heard a person key up and give his position 186 miles from me. I suspect he was either on channel 16 and the signal bounced off the bottom of an airliner, or he was using a repeater locally and his uplink bounced. It is the second time in about a year I've had very similar experience. Quote
SteveShannon Posted 1 hour ago Report Posted 1 hour ago 2 hours ago, Guest MikeD said: I have heard skip that I believe is coming from an airliner passing overhead. I was recently listening to gmrs channel 16, which is also the repeater downlink for a local repeater. I heard a person key up and give his position 186 miles from me. I suspect he was either on channel 16 and the signal bounced off the bottom of an airliner, or he was using a repeater locally and his uplink bounced. It is the second time in about a year I've had very similar experience. More likely tropospheric ducting which is caused by an atmospheric condition and affects UHF signals. Quote
WRYZ926 Posted 1 hour ago Report Posted 1 hour ago A big change in atmospheric temps like in spring and fall mornings can also cause ducting. Low cloud cover during storms is another example. I live in Mid Missouri about an hour east of Columbia and 1 1/2 hours west of St Louis. When atmospheric conditions are just right we can hear the Pacific. Mo GMRS repeater just as strong as our GMRS repeater. Both are on the same channel and use the same tones. There has also been times that I have talked on the GMRS repeater 50 miles west of me with a guy around Springfield Il. Conditions have to be just right for that to happen. And that usually happens in the spring and fall due to temperature inversions. Another example happened last week. My brother and I both have UHF Allstar nodes. We were using the same frequency and tones since we live 19 miles apart and never had an issue until then. We use no more than 5 watts when using our nodes. That day there was a heavy storm in between us which was bouncing our low power signals so that I could hear him at 1 watt and he could hear me at 5 watts. We couldn't hear each other once the storm moved out. And yes I changed the frequency my node uses after that. SteveShannon 1 Quote
