APRS software for GMRS
I just got a BTech GMRS Pro Radio last month.  It can do aprs with other Pro radios but is there any software available that I can use with a tnc on another standard GMRS radio to receive messages.  I am looking at this more for emergency services usage and would like to be able to setup on the fly another radio to send and receive aprs.  I've seen a lot of how to for Ham radios but most of the software I find wants a Ham call sign to use and my GMRS call sign won't work.   Was curious about other folks setups.
Well, technically by NAME, APRS is Amateur (Packet/Position) Reporting System, so it is no surprise that most APRS software wants an Amateur call sign. That BTech is using the APRS protocol to send position just makes it another position reporting format -- like some Garmin GPS/FRS radios.
The other matter is if they are using AX.25 data packets -- that's what Amateur TNCs are using for analog APRS (D-Star and DMR /digital/ modes send position reports in a different format -- D-Star embeds position data within the non-voice portion of each packet)
APRSDroid will gladly eat your GMRS callsign and will allow sending and receiving packets from air. Of course, no injection of data will be allowed into the APRS database over the internet. For this you must have ham callsign.
I'm regular APRS user, but always on 144.390 and never on GMRS.
I did download APRSDroid, tried to get to work with my GMRS radio using my phone connected via APRS adapter that changes from k1 format to 3.5mm.  Maybe I am missing something, I'll have to mess around with it a little more.  I was trying to see if I could see the messages to show up through my GMRS radio to the GMRS Pro Radio.  Just wasn't sure if there were other software to try like Xastir on a Raspberry Pi that might work.  Figured this would come in useful in emergency conditions to get a message out quickly to someone listening along with GPS data etc.  I am working on studying for Technician Class license but got my GMRS license couple of months ago and have been tinkering around with it.
It is not clear if Baofeng follows APRS spec. They may very well do not. To determine, you probably need to set up a receiver with APRS decoder (APRSDrois will do) to see what exactly Btech Pro sends. It may not be compatible with bona fide APRS.
That's what I was kinda wondering.  BTech may be using something similar but different, I was to understand from the info they gave that it was APRS but on GMRS frequencies.  I guess this will be my project this weekend to try and see if I can setup APRS through another radio and APRSDoid.  I will try and see if I can see if it is indeed APRS or something proprietary they came up with.  Thank you for the suggestions on this.
The A in APRS does not for amateur, but Automatic.  The initialism APRS was derived from WB4APR the call sigh for Bob Bruninga.
https://en.wikipedia.org/wiki/Automatic_Packet_Reporting_System
The BTECH GMRS Pro does not do APRS but has an APRS-like capability to send position information over the HT app.  I originally bought one hoping it would be compatible with my Garmin RINO and was disappointed it was not.  Admittedly I never ended up looking into it further using Rattlegram or something like that to decipher the different formats being sent.
It’s similar to the Garmin Rino’s (GPS/GMRS radio combo) of the late 1990’s and early 2000’s. It only sends data to other radio units. Only the Garmin units allowed you to send text messages to other folks close by without needing a phone.
I have this same question. i have a HAM and GMRS license, but my family members do not have HAM licenses, so I would like to get GMRS radios that transmit position data to a central system (with a nice, high, antenna) so as people are out and about, especially up in the mountains where there is no cell service, I could see where they are at, especially if there are any problems they need help with.
Here’s the problem: while there are GMRS radios that send location information, best among them being the Garmin Rhino radios in my opinion, regulations prohibit radios which send digital location data from having a replaceable antenna or transmitting location data through a repeater, which will make it more difficult to build the “central system (with a nice, high, antenna).
Im not sure that APRS, specifically, is being used.  I can't find anything that the FCC published that specifies authorized protocols, only emission types.  Im curious what protocols are being used, but don't have the correct tools to test for it and too tired to do anymore research. Knowing that would really determine how to proceed with aftermarket decoding.
On 4/20/2024 at 5:23 PM, jwilkers said:
If you want APRS, get an amateur license and quit trying to make GMRS into something it wasn't meant to be.
All you people wanting to turn GMRS into a clone of amateur radio need to just get their licenses.
Sent from my SM-S911U1 using Tapatalk
APRS Is not even legal for GMRS use unless your are using the bubble pack (non removable antenna)...   And in very very short burst.
https://members.swcrs.org/2021/01/05/fcc-letter-aprs-on-gmrs/
While not digital, you could try Rattlegram if you want to send text. Use-case is GPS coordinates and other difficult to hand-enter data. The app supports copy and paste and I have used it to pass GPS coordinates to others which they paste into OSMand for finding locations while no cell tower available. The app encodes your message into an audio stream much like the tones used by a telephone modem and waits for you to push-to-talk. Then, while your radio is "open" you tap the send button and the phone makes a horrible sound. The reverse is used when you are expecting a message. Ready the app and when it "hears" the horrible sound you get your message on the phone. Party trick is, you can send messages across the gaming table causing disruption and possible punishment from your DM. "Roll a save"
Actually, APRS is more then just throwing out a position report for which the BTech Pro is doing for which only other BTech Pro users can see. Though APRS is used primarily in VHF at 144.390mhz US at 1200 baud, can be used at 9600 baud UHF, and 300 Baud HF. Position reporting, weather, telemetry, messaging, and other uses like IGATE, Digipeaters relaying others beacons and messages over airwaves and thru the internet back to airwaves world wide. So people might be getting confused about the terms and what can be done with it. APRS in Amateur radio is just another form of packet radio that is used in the spectrum area of VHF that can be used for AX.25 packet protocol. Position reporting is one thing, heck my Harris XG100P can give and receive position reports from other Harris users on P25 protocol which is called SA"situation awareness" just by keying up mic button. That is just postion reporting, not APRS. So people have to realize that there are huge differences with certain gear and should not confuse the terms.
