First I'm not sure which is the better antenna ¼,⅝, or ½ wave and which of them should I use on my home for a base for a GMRS/MURS/NOAA reception/transmitting antenna and why?
Which antenna is the best low price option for what I'm trying to do?
Can I use a splitter to hook up my Wouxun KG-UV9GX as well to the same antenna? Which one?
I'm looking at making a base out of the Wouxun KG-1000G+ mobile, that I can also use in the vehicle for a bug out mobile, would I need to ground the antenna if I'm using a mag mount from either Midland or Tram, (Which is better?), and either the Midland or Nagoya NMO antennas?
Which combo would be better, Midland all the way, Midland-Tram, Nagoya-Midland, Nagoya-Tram, or just use the Wouxun AMO/NMO setup?
Can I power all of this with a IOTA DLS-15 Series M? If not, which should I go with and why?
My ultimate goal is to eventually build this out to be a solar backed up repeater eventually as I can afford it, so keeping that in mind, I can also use some suggestions for that as well as can I use a duplexer with 2 radios and get full 50W output?
With a Duplexer would I require 2 radios or must I just use 1?
What if I went with 2 radios what's the difference in doing it that way? (Both with and without the duplexer?)
What's the best way to get the best range and the most power output, (as close to 50W as I can legally get), for the least amount of funds?
I'm in the USA, if that matters. I know my area is lacking in the repeater area for GMRS and I'm wanting help to increase the footprint here.
CyborgAlienWRYG738
25 answers to this question
