TacticalTodd Posted February 17, 2024 Report Posted February 17, 2024 Was interested in purchasing the TYT TH-9800D for summer travels. But before I but it.... I have read that the newer version of the TYT TH-9800D does not work [tx/rx] with all GRMS channels. A very knowledgeable friend agreed with that. THEN, i read that you can unlock the TYT in the software. And another knowledgeable friend stated thah it will work [tx/rx] on all GMRS channels. Can anyone clear this up for a nube before i pluck down a couple of hundred $$. Thank you in advance Quote
0 dugcyn Posted February 17, 2024 Report Posted February 17, 2024 I too would be interested in the answer to this. Currently own one of 1.5 years. jail break was easy software mod. honestly do not know what would be in it for the manufacturer to block this but?? Quote
0 WRYZ926 Posted February 17, 2024 Report Posted February 17, 2024 The same software unlock for the TYT TH-9800 also works on the TYT TH-7800. I know it works on the 7800 the I bought about 4 months ago. Quote
0 WRWE456 Posted February 18, 2024 Report Posted February 18, 2024 16 hours ago, dugcyn said: honestly do not know what would be in it for the manufacturer to block this but?? Because it is not a GMRS radio. It is not certified by the FCC to operate on GMRS frequencies. SteveShannon and WRUU653 2 Quote
0 WRYZ926 Posted February 18, 2024 Report Posted February 18, 2024 A lot of different radios can have the MARS mod done to them through either a hardware modification or software hack. One is suppose to be a member of MARS or CAP to use an amateur radio outside of the amateur bands. The MARS mod on UHF radios just happens to allow transmission on GMRS channels. That does not mean that the modded radio is legal to use on GMRS channels because it isn't since it is not Part 95 certified. A lot of people do the MARS mod and don't worry about the radio not being Part 95 certified. And as long as one is not doing anything to draw attention to themselves will never get in trouble for it. Radioddity even has the TYT TH-9800 unlock steps on their website. https://www.radioddity.com/blogs/all/th-9800-unlock And yes the same procedure also works on the TH-7800 using the TH-9800 instructions and password. Use at your own discretion. WRUU653, SteveShannon and TacticalTodd 2 1 Quote
0 WRJR741 Posted March 23, 2024 Report Posted March 23, 2024 Interesting discussion. Thanks! I recently bought a TYT TH-9800 and I'm enjoying the 10m FM repeaters. I also enjoy listening to a few of the local GMRS repeaters here in the region. I have both a ham and GMRS license. 73 DE GERRY N2GJ/WRJR741 ABQ NM USA AdmiralCochrane 1 Quote
0 MrCoffee Posted July 11, 2024 Report Posted July 11, 2024 Hello, Is this model the same as just the "D" model without the word "Plus" attached? I cannot find a D Plus model all but in one place. If there is such a model, will it do GMRS. Thank you, but I'm not asking about Part 95 or 97. Anyway, thank you to anyone who can help. Quote
0 SteveShannon Posted July 11, 2024 Report Posted July 11, 2024 3 hours ago, MrCoffee said: Hello, Is this model the same as just the "D" model without the word "Plus" attached? I cannot find a D Plus model all but in one place. If there is such a model, will it do GMRS. Thank you, but I'm not asking about Part 95 or 97. Anyway, thank you to anyone who can help. The TYT 9800 being sold now is the same as the TYT-9800 plus. I have no idea what the differences between these and the D model. There’s at least one video that demonstrates how to unlock the radio. From the website: Note: TYT TH-9800 is the same as TH-9800 Plus after 2018, all the stock from Radioddity is the latest version of TH-9800 with the latest firmware and cross-band function. WRUU653 1 Quote
0 AdmiralCochrane Posted July 12, 2024 Report Posted July 12, 2024 A year or two ago (much later than 2018) when I purchased my 9800 both were available and after evaluating and looking at specs and reviews I decided to go with the Plus. Earlier models have trouble with one side of the radio going bad, but I haven't heard any examples of this happening with the 9800 Plus. If you have real concerns buy the cat, not the copycat: Yeasu 8900 I own an older 9800 with one side bad, a newer 9800 Plus and a Yeasu 8900 (the 9800 Plus Plus Plus, LOL) Quote
0 WSBZ540 Posted July 13, 2024 Report Posted July 13, 2024 The older 9800s had a 3.3v chip being fed 5v and eventually it would burn up. This usually hapoened to one side of the radio, and then the other. Newer versions have a hw change that corrects this and they were originally sold as the plus. Out of the box mine worked on gmrs frequencies. There is a change you can make with their cps to change 70cm to 1.25m if you want that for ham. You can also expand the freq range to the hw limits, ut running them at the hw limits does lead to some out of band emissions/harmonics. Out of 7 radios, I've had one fail due to the 3.3v/5v issue. AdmiralCochrane and WRXB215 2 Quote
0 WROA412 Posted July 17, 2024 Report Posted July 17, 2024 Howdy. Just bought a 9800D Plus to practice for my technician license, and I figured out why people say it cant be used with GMRS. (besides legal issues) It works very well for simplex, duplex and CTCSS codes. It does not play nice with DCS. You can not duplex the DCS code. A bunch of repeaters around me are not accessible with this radio because of it. My GMRS specific radios have no issues. Even a cheap UV5R does it in testing. I found this thread looking for solutions. I have not tried the RT Systems software but it might be able to set the radio up to do so. My current solution is to listen on one side and transmit on the others. Not a big issue since I have GMRS radios that do, and this radio is not for that anyhow. I did try to ask AI about it. It knew the radio and all about it. It said it can specifically do split DCS and to look online or the manual, but I can not find a reference and the manual is not the best. Quote
0 SteveShannon Posted July 17, 2024 Report Posted July 17, 2024 1 hour ago, WROA412 said: Howdy. Just bought a 9800D Plus to practice for my technician license, and I figured out why people say it cant be used with GMRS. (besides legal issues) It works very well for simplex, duplex and CTCSS codes. It does not play nice with DCS. You can not duplex the DCS code. A bunch of repeaters around me are not accessible with this radio because of it. My GMRS specific radios have no issues. Even a cheap UV5R does it in testing. I found this thread looking for solutions. I have not tried the RT Systems software but it might be able to set the radio up to do so. My current solution is to listen on one side and transmit on the others. Not a big issue since I have GMRS radios that do, and this radio is not for that anyhow. I did try to ask AI about it. It knew the radio and all about it. It said it can specifically do split DCS and to look online or the manual, but I can not find a reference and the manual is not the best. Set it to TONE, not TSQL, and it will transmit using a tone and receive anything regardless of the tone. WRXB215 1 Quote
0 WSCP222 Posted July 17, 2024 Report Posted July 17, 2024 There are two gmrs repeaters in my area that specify different codes for Tx DCS and Rx DCS. Is there a work around for this? Where can I find the RT Software? Also note sure how setting it to Tone not TSQL helps anything. I really don't want to have to TX on one band and Rx on the other. Quote
0 SteveShannon Posted July 17, 2024 Report Posted July 17, 2024 2 hours ago, WSCP222 said: There are two gmrs repeaters in my area that specify different codes for Tx DCS and Rx DCS. Is there a work around for this? Where can I find the RT Software? Also note sure how setting it to Tone not TSQL helps anything. I really don't want to have to TX on one band and Rx on the other. I just read through the manual. On some radios, you set the Tone Mode to TONE instead of TSQL, it doesn’t expect or use the Rx DCS. On your radio, that’s set with menu 29, SPK. When SPK is set to SQ, it doesn’t require a code or tone to receive. It reproduces all signals it receives on the RX frequency. Unfortunately, your radio doesn’t appear to allow different codes for TX and RX DCS. For the 9800, if you’re set for DCS it expects both transmit and receive DCS codes to either be the same code or inverted versions of each other. You didn’t say what the two DCS codes are. So, try setting menu #7 DCS.COD to the tx code, menu #8 to match the normal or inverted value needed, #29 SPK to SQ, and #23 RF SQL to a squelch level that you can live with, since your radio won’t be breaking squelch based on a received DCS Code. If that doesn’t work for you, then you may have to use one side of the radio to transmit using one DCS code and the other receiver to receive using a different DCS code. Sorry if this doesn’t work. AdmiralCochrane 1 Quote
0 WSCP222 Posted July 18, 2024 Report Posted July 18, 2024 Ty for the reply I will try that. The RX Dtcs is 036 and Dtcs 145 SteveShannon 1 Quote
0 WSCP222 Posted July 20, 2024 Report Posted July 20, 2024 OK I have decided not to buy the TYT9800 because of this problem but instead I bought the Anytone AT588 which at least allows me to program with their software the DTONE and RxDCS but I would like to use Chirp instead however in Chirp it will not let me select DCTS>DTCS as in option from the cross mode column it doesnt even show up as a choice when trying to program my Anytone AT588 radio. I have no problems in other radio programs such as Baofeng. I have tried with standard and GMRS frequencies but no luck any ideas. The values I have to put in are Tx DCS=152N & Rx DCS=32N. Quote
0 MrCoffee Posted August 1, 2024 Report Posted August 1, 2024 On 7/11/2024 at 6:52 PM, SteveShannon said: The TYT 9800 being sold now is the same as the TYT-9800 plus. I have no idea what the differences between these and the D model. There’s at least one video that demonstrates how to unlock the radio. From the website: Note: TYT TH-9800 is the same as TH-9800 Plus after 2018, all the stock from Radioddity is the latest version of TH-9800 with the latest firmware and cross-band function. Thank you Steve, that helps clear things up. SteveShannon 1 Quote
TacticalTodd
16 answers to this question
