CTCSS and DCS, Does it make a difference?
Good morning ole' wise members of knowledge.
When it comes to configuring tones for a repeater, does it matter whether I use CTCSS or DCS tones. My repeater will do either and I currently have it set up for a CTCSS tone, both broadcast and receive. Are there pros and cons to using either? Or just personal preference?
19 answers to this question
Expand
Some radios cheap, older, ect do not do digital tones so that may help make a decision. I think it’s more important to have cross tones so the input is different than the output.  That way it’s harder for some one to scan and get your input tone if that’s something you care about.
Expand
In some cases helps to prevent intermod interference from your own station
  On 8/28/2024 at 4:27 PM, TrikeRadio said:
Besides some older radios not being able to use DCS...
Are there any other real differences? Is DCS possibly more reliable or able to overcome static or interference more so than CTCSS ?
Expand
There are technical differences, but I have never observed any actual, real-world difference - in the real-world, they both do the job just fine.
also, FYI, I have owned/used virtually every GMRS radio manufactured since ~2017 and I do not recall ever seeing one that does not support DPL/DTC/DCS tones.  Not saying those radios do not exist, but if they do, they are very old, very rare, or, both.
Expand
Can you elaborate on that? I have two antennas in my attic (HOA). Both are TRAM 1486's separated by 15ft. One attached to a repeater/duplexer and the other to my KG1000+ (used as a base). I have wondered if the base would interfere with the repeater antenna while on deferent frequencies. Obviously, I don't use the base to hit my own repeater but would it interfere with someone trying to use the repeater at the same time? Or is this a totally different question?
Expand
  On 8/29/2024 at 9:22 PM, LeoG said:
Good chance that when you are transmitting on your radio your repeater goes deaf and vice versa.  That's a lot of rejection needed.
Expand
If you're transmitting on the 462 MHz main channels from your KG1000, your duplexer and repeater must be able to reject it, or it couldn't function as a full duplex repeater.
If you're transmitting on the 467 MHz main channels that are the input channels for the repeater, then I agree with Leo, you could interfere with reception at the repeater.
Expand
Ok, so as I understand it, transmitting in simplex from the KG1000 on channels 1-7 and 15-22 (462.xxx MHz) should be ok. 8-14 (467.xxx MHz) blocked on KG1000 due to output wattage anyhow.
However, if I'm using the KG1000 in duplex (467.xxx MHz) on other repeaters it could cause deafening of my own repeater, especially around my repeaters input frequency as it is not a high-end duplexer. Good food for thought. Radio traffic is always light in my area anyhow, so I don't see it as an issue, but this good knowledge to have. Thank you, guys, for your input. I appreciate it. I guess one last question I have is, if I upgraded the duplexer to a higher quality can type, would I still have the same issues with deafening of my repeater due to the proximity of the two antennas?
Closer the antennas are to each other, the more possibility they might interfere.  When you have a repeater without a duplexer the antennas are usually put at different heights along with keeping the space between them as much as possible.  The height part makes a big difference.
Question for you GMRS Pro's.
I got my KG1000t today and my power supply. I am waiting on the antenna to arrive.
Can I turn it on without antenna and use programming cable to get it set up and that not hurt the radio? Or should I just wait for the antenna?
Expand
Yes.. AND... Even if you accidentally hit the PTT button without the antenna connected, the radio will be fine..
AND...
Even if you accidentally hold-down the PTT button for a few minutes without the antenna connected, the radio will be fine - doing this is not recommended, but contrary to what "some people" will tell you lies about, nothing will happen other than heating up the innards.
AND...
Expand
I was "thinking" that, but wanted to confirm. Thank you.
  On 12/6/2024 at 9:30 PM, WRXB215 said:
@WRQC527 I've seen some pretty big car fires but that one takes the cake. Surely that picture is from a movie right? right? 😳
Expand
No I think that's a deep-fake AI-generated image by a sad ham who was trying to get everyone to believe in the explosive force of an overheated final transistor. Or it could have been from a movie idk.
